Help with using 4067 mux input in effect unit code with teensy 4.1.
livingsteel
New member
Hi!
I am trying to put together an effect unit that can process incoming audio with a variety of effects. I am using a teensy 4.1 with audio adapter and a 4067 multiplexer in the arduino ide. I have 16 pots connected to the multiplexer along with 4 toggle buttons connected to the teensy pins. I am using the pot readings to control the parameters of the effects and using the buttons to turn them on or off. I have successfully read the incoming signals from the 4067 and printed them to serial. The function muxRead () in my code works well. I have also successfully read the high and low states of the buttons and they effect the audio appropriately. The big problem I'm having is that I cannot figure out how to combine the muxRead () function with my button update code. The buttons work if I have disabled the muxRead () portion of the code but then I have no pot information. The muxRead () function works if I have disabled the button update code. That is my problem in a nutshell. If there is any generous soul out there who could take a look at my code and let me know what is going wrong, I would really appreciate it. THANKS!
#include <SerialFlash.h>
#include <Bounce.h>
#include "effect_platervbstereo.h"
AudioInputI2S            i2s2;           //xy=169,883
AudioMixer4              mixer1;         //xy=614,739
AudioEffectChorus        chorus1;        //xy=620,875
AudioEffectChorus        chorus2;        //xy=621,813
AudioEffectPlateReverb   verb1;        //xy=621,813
AudioMixer4              mixer4;         //xy=626,1023
AudioMixer4              mixer2;         //xy=835,851
AudioMixer4              mixer3;         //xy=863,947
AudioEffectGranular      granular1;      //xy=888,744
AudioEffectFreeverb      freeverb1;      //xy=929,1036
AudioMixer4              mixer5;         //xy=1092,881
AudioFilterStateVariable filter1;        //xy=1236,881
AudioSynthWaveformSine   sine1;
AudioConnection          patchCord23(sine1, 0, filter1, 1);
AudioOutputI2S           i2s1;           //xy=1367,884
AudioConnection          patchCord1(i2s2, 0, mixer1, 0);
AudioConnection          patchCord2(i2s2, 0, mixer4, 0);
AudioConnection          patchCord3(i2s2, 0, chorus1, 0);
AudioConnection          patchCord21(i2s2, 0, verb1, 0);
AudioConnection          patchCord22(i2s2, 1, verb1, 1);
AudioConnection          patchCord4(i2s2, 1, mixer1, 1);
AudioConnection          patchCord5(i2s2, 1, mixer4, 1);
AudioConnection          patchCord6(i2s2, 1, chorus2, 0);
AudioConnection          patchCord7(mixer1, granular1);
AudioConnection          patchCord8(chorus2, 0, mixer2, 1);
AudioConnection          patchCord9(chorus1, 0, mixer2, 0);
AudioConnection          patchCord19(verb1, 0, mixer3, 0);
AudioConnection          patchCord20(verb1, 1, mixer3, 1);
AudioConnection          patchCord10(mixer4, freeverb1);
AudioConnection          patchCord11(mixer2, 0, mixer5, 1);
AudioConnection          patchCord12(mixer3, 0, mixer5, 2);
AudioConnection          patchCord13(granular1, 0, mixer5, 0);
AudioConnection          patchCord14(freeverb1, 0, mixer5, 3);
AudioConnection          patchCord15(mixer5, 0, filter1, 0);
AudioConnection          patchCord16(mixer5, 0, filter1, 1);
AudioConnection          patchCord17(filter1, 0, i2s1, 0);
AudioConnection          patchCord18(filter1, 1, i2s1, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=678,1182
#define chorusDelayLength (16*AUDIO_BLOCK_SAMPLES)  // Number of samples in each delay line
short l_delayline[chorusDelayLength]; // Allocate the delay lines for left and right channels
short r_delayline[chorusDelayLength];
int   n_chorus = 2;                   // number of "voices" in the chorus including the original voice
bool  chorusActive      = false;      // track if chorus effect is on or off
#define GRANULAR_MEMORY_SIZE 12800  // enough for 290 ms at 44.1 kHz
int16_t granularMemory[GRANULAR_MEMORY_SIZE];
#define PASSTHRU_PIN 1
Bounce b_passthru = Bounce(PASSTHRU_PIN,15);
#define MS0 31 //These pins are connected to S0-S3 and Z on the 4067 multiplexer
#define MS1 30
#define MS2 29
#define MS3 28
#define MZ  A13
#define MnumControls 16
//#define Button0  33
//#define Button1  34
//#define Button2  35
//#define Button3  36
#define MUXchorus_1  0
#define MUXchorus_2  1
#define MUXfilterRes  2
#define MUXfilterFreq  3
#define MUXlfo_1Freq  4
#define MUXlfo_1Amp  5
#define MUXplate_1  6
#define MUXplate_2  7
#define MUXplate_3  8
#define MUXplate_4 9
#define MUXplate_5 10
#define MUXfreeverb_1 11
#define MUXfreeverb_2  12
#define MUXgranular_1   13
#define MUXgranular_2  14
#define MUXflange_3     15
//#define button0          33
//#define button1          34
//#define button2          35
//#define button3          36
#ifndef _BV
#define _BV(bit) (1 << (bit))
Bounce button0 = Bounce(33, 15);
Bounce button1 = Bounce(34, 15);
Bounce button2 = Bounce(35, 15);
Bounce button3 = Bounce(36, 15);
  AudioMemory(18);
  pinMode(MS0, OUTPUT);
  pinMode(MS1, OUTPUT);
  pinMode(MS2, OUTPUT);
  pinMode(MS3, OUTPUT);
  pinMode(33, INPUT_PULLDOWN);
  pinMode(34, INPUT_PULLDOWN);
  pinMode(35, INPUT_PULLDOWN);
  pinMode(36, INPUT_PULLDOWN);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.7);
  mixer1.gain(0, 0.5);
  mixer1.gain(1, 0.5);
  mixer2.gain(0, 0.5);
  mixer2.gain(1, 0.5);
  mixer3.gain(0, 0.5);
  mixer3.gain(1, 0.5);
  mixer4.gain(0, 0.5);
  mixer4.gain(1, 0.5);
  mixer5.gain(0, 0.5);
  mixer5.gain(1, 0.5);
  // the Granular effect requires memory to operate
  granular1.begin(granularMemory, GRANULAR_MEMORY_SIZE);
  if (!chorus1.begin(r_delayline, chorusDelayLength, n_chorus)) {
    Serial.println("AudioEffectChorus - left channel begin failed");
    while (1);
  Serial.println("done.");
  // initially the effect is off.
  chorus1.voices(0);
  chorus2.voices(0);
  Serial.println("Waiting for control input...");
  // reset audio resource usage stats.
  // useful if tracking max usage in main program
  AudioProcessorUsageMaxReset();
  AudioMemoryUsageMaxReset();
    checkMux ();
    button0.update();
  button1.update();
  button2.update();
  button3.update();
  if (button1.risingEdge()) {
        mixer4.gain(0, .5);
        mixer4.gain(1, .5);
        Serial.print("Reverb: mix=");
        Serial.print(MUXfreeverb_1 * 100.0);
        Serial.print("%, roomsize=");
        Serial.print("%, damping=");
        Serial.print(MUXfreeverb_2 * 100.0);
        Serial.print("%, CPU Usage=");
        Serial.print(MUXfreeverb_1);
        Serial.println("%");
      if (button1.fallingEdge()) {
      freeverb1.roomsize(0);
      freeverb1.damping(0);
      mixer4.gain(1, 0);
      mixer4.gain(0, 0);
      Serial.print("stop reverb");
 /* if (button0.fallingEdge()) {
        granular1.beginPitchShift(msec);
        mixer1.gain(0, .5);
        mixer1.gain(1, .5);
        Serial.print("Begin granular pitch phift using ");
        Serial.print(MUXgranular_1);
        Serial.println(" grains");
  if (button0.risingEdge()) {
        granular1.stop();
        mixer1.gain(0, .0);
        mixer1.gain(1, .0);
        Serial.println(" pitch stop");
 if (button2.risingEdge()) {
        mixer2.gain(0, .5);
        mixer2.gain(1, .5);
        Serial.print("chorus");
        chorus1.begin(l_delayline, chorusDelayLength, n_chorus);
        chorus2.begin(l_delayline, chorusDelayLength, n_chorus);
        chorusActive = !chorusActive;
  if (button2.fallingEdge()) {
        mixer2.gain(0, 0);
        mixer2.gain(1, 0);
        Serial.print("chorus stop");
if (button3.risingEdge()) {
        mixer3.gain(0, .5);
        mixer3.gain(1, .5);
        Serial.print("plate");
  if (button3.fallingEdge()) {
        mixer3.gain(0, 0);
        mixer3.gain(1, 0);
        Serial.print("plate stop");
  void checkMux() {
  static byte muxInput = 0;
  static int muxValues[MnumControls] = {};
  unsigned long currentMicros = micros();
  if (currentMicros >= 1000) {
    float muxRead = (float)analogRead(MZ) / 1023;
      muxValues[muxInput] = muxRead;
      switch (muxInput) {
        case MUXfreeverb_1:
          freeverb1.roomsize(muxRead);
          Serial.print("freeverb= ");
          Serial.print(muxRead);
        case MUXfreeverb_2:
          freeverb1.damping(muxRead);
          Serial.print("freeverb2= ");
        case MUXplate_1:
          verb1.size(muxRead);
          Serial.print("plate1= ");
        case MUXplate_2:
          verb1.lodamp(muxRead);
          Serial.print("plate2= ");
        case MUXplate_3:
          verb1.lowpass(muxRead);
          Serial.print("plate3= ");
        case MUXplate_4:
          verb1.hidamp(muxRead);
          Serial.print("plate4= ");
        case MUXplate_5:
          verb1.diffusion(muxRead);
          Serial.print("plate5= ");
        /*case MUXchorus_1:
          int(ottowa) = int(muxRead * 10);
          Serial.print("chorus1= ");
        case MUXchorus_2:
          short(manitoba) = short(muxRead * 16);
          Serial.print("chorus2= ");
          Serial.print(manitoba);
          break;/*
        case MUXgranular_1:
          float(msec) = float(25.0 + (muxRead * 75.0));
          Serial.print("gran1= ");
          Serial.print(msec);
        case MUXgranular_2:
          granular1.setSpeed(powf(2.0, muxread * 2.0 - 1.0);
          Serial.print("gran2= ");
          Serial.print(Ratio);
          break;/*/
        case MUXfilterRes:
          //muxRead = muxRead * 5;
          filter1.resonance(muxRead * 5);
          Serial.print("filterres= ");
        case MUXfilterFreq:
          //muxRead = muxRead * 1000;
          filter1.frequency(muxRead * 1000);
          Serial.print("filterfreq= ");
        case MUXlfo_1Freq:
          //muxRead = muxRead * 10;
          sine1.frequency(muxRead * 10);
          Serial.print("lfofreq= ");
        case MUXlfo_1Amp:
          sine1.amplitude(muxRead);
          Serial.print("lfoamop= ");
    muxInput++;
    if (muxInput >= MnumControls) muxInput = 0;
    digitalWrite(MS0, muxInput & B0001);
    digitalWrite(MS1, muxInput & B0010);
    digitalWrite(MS2, muxInput & B0100);
    digitalWrite(MS3, muxInput & B1000);
