Good morning everybody,
I'm playing with TMR1 on my Teensy 4, and following the NXP reference manuel.
For now I trying to make a fix frequency PWM like documentation describe on page 54.4.5.13 "Fixed-Frequency PWM Mode "
But I only have a high level signal instead having a 50% duty cycle.
Is there someone who can take time to explain me what I'm doing wrong ? I
Here below the example from NXP reference manual
Thank you
Fred
#include <Arduino.h>
void resetTimer()
// enable timer1 clock
CCM_CCGR6 |= 0XC000000;
//reset TMR1 as it should be @reset state
TMR1_COMP10 = 0x0000;
TMR1_COMP20 = 0x0000;
TMR1_CAPT0 = 0x0000;
TMR1_LOAD0 = 0x0000;
TMR1_HOLD0 = 0x0000;
TMR1_CNTR0 = 0x0000;
TMR1_CTRL0 = 0x0000;
TMR1_SCTRL0 = 0x0000;
TMR1_CMPLD10 = 0x0000;
TMR1_CMPLD20 = 0x0000;
TMR1_CSCTRL0 = 0x0000;
TMR1_FILT0 = 0x0000;
TMR1_DMA0 = 0x0000;
TMR1_ENBL = 0x000f;
// output 10 (GPIO_B0_00) attached to QTIMER1_TIMER0 output
IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_00 = 0x00000001;
resetTimer(); // config timer as reset state, enable clock, and setup output pin
TMR1_SCTRL0 = 0x00005; // TMR output enable
TMR1_COMP10 = 0x8000; // compare @half to have 50% duty cycle
TMR1_CTRL0 = 0x3006; // source 1 prescaler = 1, count on rising edge of source 1, set OFLAG @ COMP, reset @ rollOver
// if =0x3003 output frequency is 1.14KHz whith 0X3006 High level on ooutput pin
TMR1_CSCTRL0 = 0x0000; //no load at compare
// do nothing
// This example uses TMR0 for Fixed-Frequency PWM mode timing.
// The timer will count IP_bus clocks continuously until it rolls over.
// This results in a PWM period of 65536 / 60e6 = 1092.267 usec
// Initially, an output pulse width of 25 usec is generated ( 1500 / 60e6 )
giving a PWM ratio of 1500 / 65536 = 2.289%
// This pulse width can be changed by changing the COMP1 register value (using CMPLD1).
void PWM1_Init(void)
[B]setReg(TMR0_CNTR,0); [/B] /* Reset counter */
/* TMR0_SCTRL: TCF=0,TCFIE=0,TOF=0,TOFIE=0,IEF=0,IEFIE=0,IPS=0,INPUT=0,
Capture_Mode=0,MSTR=0,EEOF=0,VAL=0,FORCE=1,OPS=0,OEN=1 */
[B]setReg(TMR0_SCTRL,0x05); [/B]/* Enable output */
[B]setReg(TMR0_COMP1,1500-1);[/B]/* Store initial value to the duty-compare register */
/* TMR0_CTRL: CM=1,PCS=8,SCS=0,ONCE=0,LENGTH=0,DIR=0,COINIT=0,OUTMODE=6 */
[B]setReg(TMR0_CTRL,0x3006);[/B]/* Run counter */
Fred
