It is possible to disconnect power to a port on a device, depending on the device and the port in question. Here are a few ways this can be done:
Unplug the device: Depending on the device, you may be able to simply unplug it from the wall or power strip to cut power to all of the ports.
Use a power strip: If the device is plugged into a power strip with a switch, you can flip the switch to cut power to all of the devices connected to the power strip.
Use a smart power strip: Some power strips have the ability to control power to individual outlets or ports. You can use the app or control panel for the power strip to cut power to the specific port you want.
Use a power outlet timer: Some power outlet timers can be programmed to turn off power to a specific outlet at a certain time. This can be used to cut power to a specific port on a device.
Regard:
sportsurge
