Results 1 to 6 of 6
Thread: Audio GUI : Newbie problem
    Exporting a design ready for the Teensyduino/Arduino IDE, I see a collection of objects apparently inherited from previous projects in the Export file.
    I can't figure out how to get rid of the unwanted nodes and start over from fresh. I tried wiping the Browser cache plus everything else I can see but they're still in the Export file. Tried different browsers too (Safari, Brave, Firefox) and the result is the same.
    Any suggestions? What am I missing?
    David
    Apr 2020
    DFW area in Texas
    559
    Quote Originally Posted by ThinkingMetal View Post
    Any suggestions?
    Try the following: open the audio design tool, press CTRL-A (to select all), and finally DELETE (to remove all). Then, create your new design.
    Hope that helps . . .
    Mark J Culross
    KD5RXT
    27,659
    Mark's way should work fine.
    But to dig into the detail, the design tool uses HTML5 localStorage. Here's a page about how to delete it on Safari.
    https://superuser.com/questions/2365...ge-from-safari
    I always assumed this storage was specific to each browser, so I'm pretty surprised to hear you saw the same stored data in 3 other browsers. But hopefully at least knowing how it's storing the data can help you search for info.
    Hi Paul & Mark,
    Thanks for your help. I tried Mark's solution without success. Each time I export, the modules from the previous session are included in the GUI build.
    Following on from the above comments, I tried opening a Private window and that has worked as it should consistently. I'll stick with this solution as I'd rather spend my time coding than sorting out browser issues!
    David
    Dec 2022
    Lyon (France)
    19
    David: You can try to clear it in Chrome here:
    Paul : I think the storage is specific to each browser, but David has on each browser the same problem (browser keeps memory of what you did last time on same browser)
    27,659
    Quote Originally Posted by samyrabih View Post
    That was my understanding too.
    Guess the words "Tried different browsers too (Safari, Brave, Firefox) and the result is the same" leave a lot of unknowns when we can't what really happened on David's screen. Somehow I read this to mean the same data reappeared in different browsers, but yeah, it could mean all 4 had their own extra stuff which couldn't be deleted.
    But why CTRL-A to select all and then Del to delete them all didn't get rid of extra stuff is also quite a mystery. It really should work.
