I connected my Teensy 4.1 to this https://www.az-delivery.de/en/products/adapter-fur-nrf24l01 breakout board and the corresponding RF module. I connected the VCC and GND of the board to the 5V and GND supplied via USB and the signal cables to arbitrary Digital Pins. I checked that the voltage from the signal pins of the board does not exceed 3.3V. Then I connected the teensy to my computer and noticed that the computer doesn't recognize it. I used a different USB cable from before so I replaced it by the working one but it didn't help. The 3.3V line shows very little voltage and the GND to 3.3V shows 0Ohm resistance so I guess it is shorted. I will get a new Teensy but obviously I would like to avoid that in the future. Again, the only differences to before was a different USB cable and the breakout board. Is it maybe not compatible?
EDIT: I just remembered that today also I tested this https://www.az-delivery.de/products/lm2596s-dc-dc-step-down-modul-1 step down module. I configured it before to deliver 4.992V (checked with multimeter) and connected it to the VIN pin. I didn't check functionality then so I can't determine whether this could have been the cause either.
