Results 1 to 16 of 16
Thread: Teensy4.1: optimisation -0g, -00 fails to start.
    Hi Guys,
    I'm seeing this with platformIO and the Arduino ide.
    I am seeing the issue with hurts ILI9341_t3n library but am pretty sure this is not causing this, I have seen other similar issues on the internet with different libs.
    If I take the following code:
    #include <Arduino.h>
    #include <ILI9341_t3n.h>
    #define TFT_DC 9
    #define TFT_CS 10
    ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC);
      Serial.printf("Started\n");
      tft.begin(); // Remove this and it starts fine
      Serial.printf("running\n");
    If compiled with -O1, -O2 or -O3 then after flashing the teensy starts up and we see the log messages.
    When compiled with -Og or -O0 then the teensy does not start up, the serial port is not there and to re-flash it you need to press the button.
    Kurt told me to define PRINT_DEBUG_STUFF and look at the uart4 output.
    With -O1, -O2 and -O3 I see:
    ***********IMXRT Startup**********
    test 1 -1234567 3
    CCM_ANALOG_PLL_USB1=80003000
      enable USB clocks
    CCM_ANALOG_PLL_USB1=80003040
    Increasing voltage to 1250 mV
    need to switch to alternate clock during reconfigure of ARM PLL
    USB PLL is running, so we can use 120 MHz
    Freq: 12 MHz * 100 / 2 / 1
    ARM PLL=80002042
    ARM PLL needs reconfigure
    ARM PLL=80002064
    New Frequency: ARM=600000000, IPG=150000000
    analogInit
    BURSTSIZE=00000808
    BURSTSIZE=00000808
    USB1_TXFILLTUNING=00000000
    USB reset took 6 loops
    usb_serial_reset
    usb_serial_configure
    rx queue i=0
    rx queue i=1
    rx queue i=2
    rx queue i=3
    rx queue i=4
    rx queue i=5
    rx queue i=6
    rx queue i=7
    With -Og, -O0 I see no output at all, totally dead.
    Has anyone got any ideas of what might be going wrong here?
    Many thanks
    Andy
    Senior Member h4yn0nnym0u5e's Avatar
    Apr 2021
    Cambridgeshire, UK
    623
    I've had what could be a similar problem using Arduino IDE, audio library and TeensyDebug. You might want to try finding the cores\teensy4\startup.c file, and commenting out the reset_PFD() call around line 92 or so. This has worked a treat for me in the past, and currently! There's another call at line 120, so I don't think there's likely to be any adverse effects.
    Thanks, I will try that tomorrow and let you know how it goes...
    Hi h4yn0nnym0u5e,
    You are a genius
    I did find that removing this line stopped -O1 builds working, same issue with the hanging.
    So I put the line back in and added at the top of startup.c:
    #pragma GCC optimize ("O2")
    Now all optimisation levels start fine.
    Thanks very much for the help here, really appreciated.
    Apr 2021
    Cambridgeshire, UK
    623
    No problem, glad it’s working for you now. If I remember I’ll have to see what the Arduino IDE uses as the optimisation level for startup.c, it may be different from platformIO (which I’ve never used), and a pragma might work to the same effect.
    Apr 2021
    Cambridgeshire, UK
    623
    Further exploration yields the discovery that it's sufficient (for me) to add __attribute__((optimize("O2"))) before the definition of reset_PFD(), so the rest of startup.c can use whatever optimisation level is in force generally. Not sure if this makes much difference, given the code is only run once at boot, but it feels better ... even if I still don't know why it works!
    I've put in PR #673, on the assumption that this has probably bitten quite a few people over time, and seems benign.
    Mar 2019
    Karlsruhe, Germany
    6
    Lightbulb
    I've had a similar problem when compiling with -Os and LTO. I think the root cause for these startup issues is the way the stack pointer is setup in ResetHandler(). If the compiler inserts some stack or frame handling code before __asm__ volatile("mov sp, %0" :: "r" ((uint32_t)&_estack));, the stack or frame setup gets messed up later on. If the compiler actually inserts stack-related code depends on optimization settings, function inlining during LTO, if startup_early_hook() is used, etc. In most cases the startup code just works fine.
    But to resolve this, you IMHO have to setup the stack pointer in assembler before calling a C function. What works for me with several compiler optimization settings is the following reset handler:
    __attribute__((section(".startup"), naked, noreturn))
    void ResetHandler(void) {
    	__asm__ volatile("str %1, [%0] \n\t" :: "r" (&IOMUXC_GPR_GPR17), "r" (&_flexram_bank_config) : "memory");
    	__asm__ volatile("str %1, [%0] \n\t" :: "r" (&IOMUXC_GPR_GPR16), "r" (0x00200007) : "memory");
    	__asm__ volatile("str %1, [%0] \n\t" :: "r" (&IOMUXC_GPR_GPR14), "r" (0x00AA0000) : "memory");
    	__asm__ volatile("dsb" ::: "memory");
    	__asm__ volatile("isb" ::: "memory");
    	__asm__ volatile("msr msp, %0" :: "r" (&_estack) : "memory");
    	ResetHandlerC();
    It initializes DTCM, sets the stack pointer and then calls the original reset handler code (renamed to ResetHandlerC() here).
    If that makes sense to you guys, I can create a pull request. But before merging it should be reviewed and tested by others, too
    Timo
    16,878
    Quote Originally Posted by timo42 View Post
    Interesting note. Since T_4.0 beta hardware, the LTO that worked well with new T_3.6, it regularly failed so it just never got used. And looking at optimized options LTO has been removed at this time. Perhaps due to the toolchain update and issues as follows.
    Enabling it in boards.txt and building CoreMark and BLINK fails IDE 1.8.19 and TSET using IDE 2.0 build:
    lto-wrapper.exe: fatal error: C:\T_Drive\arduino-1.8.19\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc returned 1 exit status
    compilation terminated.
    c:/t_drive/arduino-1.8.19/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: error: lto-wrapper failed
    Error compiling for board Teensy 4.1.
    Mar 2019
    Karlsruhe, Germany
    6
    To use LTO you need at least this update of the cores library, because of this gcc bug.
    But unfortunately this has another issue I reported here.
    Definitely heading to the "can of worms" here!
    Mar 2017
    Oakland, CA, USA
    624
    I made a PR here that addresses the issue. Thanks for pointing out my oversight.
    27,670
    Committed a fix for this startup with other optimizations levels.
    https://github.com/PaulStoffregen/co...def92fa791191d
    Hopefully this covers all the cases?
    Mar 2019
    Karlsruhe, Germany
    6
    Unfortunately, no.
    I did a quick test with a blink example and had to add "noinline" as attribute for ResetHandler2() to make it built with -O2 -flto.
    Maybe I did not declare the C-ResetHandler static in my previous tests and therefore didn't run into that issue...
    27,670
    Ok, will look at this again for LTO. Yesterday I tested only with the 5 optimization levels we're currently offering in the Arduino menu, which doesn't (yet) have LTO.
    Mar 2017
    Oakland, CA, USA
    624
    You probably already saw this, but here’s a link directly to my last PR comment (I don’t want it to get lost in the shuffle since it fixes my original LTO “fix”), to make your life easier:
    https://github.com/PaulStoffregen/co...ent-1407494793
    16,878
    Was going to put that together here (p#8) to see if LTO changed ... but too many moving parts ... if they get aligned, will do some test builds.
