I have a Teensy 4.1, no Ethernet, not lockable, that I attached a new, not prior used PJRC audio shield to and am having some troubles/issues. I am using Arduino 1.8.19 with the Teensy libs/loader 1.57. USB type of serial. I am using a good SD card loaded with the test files. This is on a 64bit Win11 Home version 22H2 system. This same setup/configuration is used for all of the below test.
The steps/issues/problems are:
- I can reset the Teensy back to factory (by holding the program mode button) and the board reverts to the built-in blink program.
- I can load the Arduino blink test program to the board.
- I can load and run the SdCardTest, results at bottom of post.
- If I load the Guitar.ino test (or really any other that tries to use the audio shield like PlaySynthMusic.ino), I get 9 red LED blinks after a successful load. According to this page (https://www.pjrc.com/store/ic_mkl02_t4.html), that is very unlikely AND the other programs work fine. All done on the same combination of Teensy & audio-shield. I would swear though that sometimes right after the program load is complete the Teensy will blink 7 times. Not always but some. When I power cycle it blinks 9 and will blink 9 there after until I load a program that does NOT include audio.h.
- I can then load blink.ino and it will work fine (go back to blinking).
So it seems to be specifically a Teensy/audio shield use OF audio.h?!? The compiler logs for Gutar.ino are below. This is driving me NUTS! I hope it is a simple thing that I have done as that is easier to fix.
Thoughts? Thanks.
Guitar.ino Arduino compiler logs:
SD card test results:Code:C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Home\Documents\Arduino\libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10819 -build-path C:\Users\Home\AppData\Local\Temp\arduino_build_468259 -warnings=default -build-cache C:\Users\Home\AppData\Local\Temp\arduino_cache_97259 -verbose C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\examples\Synthesis\Guitar\Guitar.ino C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Home\Documents\Arduino\libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10819 -build-path C:\Users\Home\AppData\Local\Temp\arduino_build_468259 -warnings=default -build-cache C:\Users\Home\AppData\Local\Temp\arduino_cache_97259 -verbose C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\examples\Synthesis\Guitar\Guitar.ino Using board 'teensy41' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr Detecting libraries used... "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o nul Alternatives for Audio.h: [Audio@1.3] ResolveLibrary(Audio.h) -> candidates: [Audio@1.3] "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o nul Alternatives for SPI.h: [SPI@1.0] ResolveLibrary(SPI.h) -> candidates: [SPI@1.0] "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o nul Alternatives for SD.h: [SD@1.2.4 SD@2.0.0] ResolveLibrary(SD.h) -> candidates: [SD@1.2.4 SD@2.0.0] "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\src" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o nul Alternatives for SdFat.h: [SdFat@2.1.2] ResolveLibrary(SdFat.h) -> candidates: [SdFat@2.1.2] "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o nul Alternatives for SerialFlash.h: [SerialFlash@0.5] ResolveLibrary(SerialFlash.h) -> candidates: [SerialFlash@0.5] "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o nul Alternatives for Wire.h: [Wire@1.0] ResolveLibrary(Wire.h) -> candidates: [Wire@1.0] "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o nul Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\Quantizer.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\Resampler.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft1024.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft256.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_notefreq.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_peak.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_print.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_rms.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_tonedetect.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\async_input_spdif3.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_ak4558.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_cs42448.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_cs4272.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_sgtl5000.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_tlv320aic3206.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_wm8731.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_bandlimit_step.c Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_spdif.c Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_ulaw.c Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_waveforms.c Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_windows.c Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_bitcrusher.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_chorus.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_combine.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_delay.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_delay_ext.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_envelope.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_fade.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_flange.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_freeverb.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_granular.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_multiply.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_rectifier.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_reverb.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_wavefolder.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_waveshaper.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\filter_biquad.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\filter_fir.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\filter_ladder.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\filter_variable.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adcs.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s2.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_hex.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_oct.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_quad.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_pdm.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_pdm_i2s2.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_spdif3.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_tdm.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_tdm2.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\mixer.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_adat.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_dac.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_dacs.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s2.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_hex.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_oct.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_quad.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_mqs.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211_2.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pwm.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif2.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif3.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm2.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_memory.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_queue.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_raw.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_wav.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_serialflash_raw.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\record_queue.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\spi_interrupt.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_dc.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_karplusstrong.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_pinknoise.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_pwm.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_sine.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_tonesweep.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_waveform.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_wavetable.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_whitenoise.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\utility\imxrt_hw.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\utility\sqrt_integer.c Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\src\SD.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatDbg.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFile.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFilePrint.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFileWrite.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFormatter.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatName.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatPartition.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatVolume.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatDbg.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFile.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFileLFN.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFilePrint.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFileSFN.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFormatter.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatName.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatPartition.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatVolume.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FreeStack.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsFile.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsNew.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsVolume.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\MinimumSerial.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdCardInfo.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdSpiCard.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdioTeensy.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiArtemis.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiChipSelect.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiDue.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiESP.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiParticle.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiSTM32.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiSTM32Core.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiTeensy3.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FmtNumber.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsCache.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsDateTime.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsName.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsStructs.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsUtf.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\PrintBasic.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\upcase.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\StdioStream.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\StreamBaseClass.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\istream.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\ostream.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash\SerialFlashChip.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash\SerialFlashDirectory.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\WireIMXRT.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\WireKinetis.cpp Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c Generating function prototypes... "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\preproc\\ctags_target_for_gcc_minus_e.cpp" "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\preproc\\ctags_target_for_gcc_minus_e.cpp" Compiling sketch... "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/pch/Arduino.h" -o "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/pch/Arduino.h.gch" Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\pch\Arduino.h.gch "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp" -o "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp.o" Compiling libraries... Compiling library "Audio" Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\memcpy_audio.S.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\data_bandlimit_step.c.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\data_ulaw.c.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\data_spdif.c.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\data_windows.c.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\data_waveforms.c.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\control_wm8731.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\Quantizer.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\control_ak4558.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_bitcrusher.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_combine.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\analyze_print.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\analyze_peak.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_delay_ext.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\control_cs4272.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\analyze_fft1024.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\analyze_fft256.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\control_cs42448.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\analyze_rms.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_flange.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_freeverb.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_granular.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\control_tlv320aic3206.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_chorus.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_rectifier.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\analyze_tonedetect.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\filter_ladder.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\control_sgtl5000.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_midside.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_fade.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\Resampler.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_i2s_hex.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\filter_biquad.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\analyze_notefreq.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_multiply.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\filter_variable.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_adcs.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\filter_fir.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_envelope.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\async_input_spdif3.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_i2s2.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_i2s_quad.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_waveshaper.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_delay.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_tdm.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_adc.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\mixer.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_i2s_hex.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_i2s_oct.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_dac.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_i2s.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_i2s_quad.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_pdm.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_dacs.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_pwm.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_i2s.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_mqs.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_pdm_i2s2.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_wavefolder.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_spdif2.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_spdif3.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_i2s2.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_spdif.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\play_memory.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_tdm2.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\effect_reverb.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\input_spdif3.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_tdm.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\play_serialflash_raw.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_i2s_oct.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\play_queue.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\spi_interrupt.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\record_queue.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_simple_drum.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_pwm.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_pinknoise.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_tonesweep.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_whitenoise.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_wavetable.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_waveform.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_pt8211_2.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_adat.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_tdm2.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_karplusstrong.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\play_sd_wav.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\output_pt8211.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_sine.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\synth_dc.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\play_sd_raw.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\utility\sqrt_integer.c.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Audio\utility\imxrt_hw.cpp.o Compiling library "SPI" Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SPI\SPI.cpp.o Compiling library "SD" Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SD\SD.cpp.o Compiling library "SdFat" Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FreeStack.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\MinimumSerial.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\upcase.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\ExFatPartition.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\ExFatFilePrint.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\ExFatName.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\ExFatDbg.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\ExFatFileWrite.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\ExFatFile.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\ExFatVolume.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\ExFatLib\ExFatFormatter.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatFilePrint.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatDbg.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatFile.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatFileSFN.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatVolume.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatName.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatFormatter.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatFileLFN.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FatLib\FatPartition.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FsLib\FsNew.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FsLib\FsFile.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\FsLib\FsVolume.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SdCard\SdCardInfo.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SdCard\SdioTeensy.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SdCard\SdSpiCard.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SpiDriver\SdSpiChipSelect.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SpiDriver\SdSpiArtemis.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SpiDriver\SdSpiTeensy3.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SpiDriver\SdSpiSTM32.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SpiDriver\SdSpiESP.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SpiDriver\SdSpiParticle.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SpiDriver\SdSpiDue.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\SpiDriver\SdSpiSTM32Core.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\common\FmtNumber.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\common\FsUtf.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\common\upcase.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\common\FsName.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\common\FsDateTime.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\common\FsCache.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\common\FsStructs.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\common\PrintBasic.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\iostream\istream.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\iostream\StreamBaseClass.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\iostream\ostream.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SdFat\iostream\StdioStream.cpp.o Compiling library "SerialFlash" Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SerialFlash\SerialFlashDirectory.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\SerialFlash\SerialFlashChip.cpp.o Compiling library "Wire" Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Wire\Wire.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Wire\WireKinetis.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Wire\WireIMXRT.cpp.o Using previously compiled file: C:\Users\Home\AppData\Local\Temp\arduino_build_468259\libraries\Wire\utility\twi.c.o Compiling core... Using precompiled core: C:\Users\Home\AppData\Local\Temp\arduino_cache_97259\core\core_3c79d0f39d0d1b6b64af9518e113e3fa.a Linking everything together... "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -Og -Wl,--gc-sections,--relax "-TC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.elf" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\sketch\\Guitar.ino.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\memcpy_audio.S.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\data_bandlimit_step.c.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\data_spdif.c.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\data_ulaw.c.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\data_waveforms.c.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\data_windows.c.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\Quantizer.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\Resampler.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\analyze_fft1024.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\analyze_fft256.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\analyze_notefreq.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\analyze_peak.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\analyze_print.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\analyze_rms.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\analyze_tonedetect.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\async_input_spdif3.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\control_ak4558.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\control_cs42448.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\control_cs4272.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\control_sgtl5000.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\control_tlv320aic3206.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\control_wm8731.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_bitcrusher.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_chorus.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_combine.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_delay.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_delay_ext.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_envelope.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_fade.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_flange.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_freeverb.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_granular.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_midside.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_multiply.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_rectifier.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_reverb.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_wavefolder.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\effect_waveshaper.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\filter_biquad.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\filter_fir.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\filter_ladder.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\filter_variable.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_adc.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_adcs.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_i2s.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_i2s2.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_i2s_hex.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_i2s_oct.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_i2s_quad.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_pdm.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_pdm_i2s2.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_spdif3.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_tdm.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\input_tdm2.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\mixer.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_adat.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_dac.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_dacs.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_i2s.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_i2s2.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_i2s_hex.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_i2s_oct.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_i2s_quad.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_mqs.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_pt8211.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_pt8211_2.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_pwm.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_spdif.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_spdif2.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_spdif3.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_tdm.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\output_tdm2.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\play_memory.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\play_queue.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\play_sd_raw.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\play_sd_wav.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\play_serialflash_raw.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\record_queue.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\spi_interrupt.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_dc.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_karplusstrong.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_pinknoise.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_pwm.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_simple_drum.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_sine.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_tonesweep.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_waveform.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_wavetable.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\synth_whitenoise.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\utility\\sqrt_integer.c.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Audio\\utility\\imxrt_hw.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SD\\SD.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FreeStack.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\MinimumSerial.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\ExFatDbg.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\ExFatFile.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\ExFatFilePrint.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\ExFatFileWrite.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\ExFatFormatter.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\ExFatName.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\ExFatPartition.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\ExFatVolume.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\ExFatLib\\upcase.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatDbg.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatFile.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatFileLFN.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatFilePrint.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatFileSFN.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatFormatter.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatName.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatPartition.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FatLib\\FatVolume.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FsLib\\FsFile.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FsLib\\FsNew.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\FsLib\\FsVolume.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SdCard\\SdCardInfo.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SdCard\\SdSpiCard.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SdCard\\SdioTeensy.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SpiDriver\\SdSpiArtemis.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SpiDriver\\SdSpiChipSelect.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SpiDriver\\SdSpiDue.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SpiDriver\\SdSpiESP.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SpiDriver\\SdSpiParticle.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SpiDriver\\SdSpiSTM32.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SpiDriver\\SdSpiSTM32Core.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\SpiDriver\\SdSpiTeensy3.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\common\\FmtNumber.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\common\\FsCache.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\common\\FsDateTime.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\common\\FsName.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\common\\FsStructs.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\common\\FsUtf.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\common\\PrintBasic.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\common\\upcase.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\iostream\\StdioStream.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\iostream\\StreamBaseClass.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\iostream\\istream.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SdFat\\iostream\\ostream.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SerialFlash\\SerialFlashChip.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\SerialFlash\\SerialFlashDirectory.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Wire\\WireIMXRT.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Wire\\WireKinetis.cpp.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/..\\arduino_cache_97259\\core\\core_3c79d0f39d0d1b6b64af9518e113e3fa.a" "-LC:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259" -larm_cortexM7lfsp_math -lm -lstdc++ "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.elf" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.eep" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.elf" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.hex" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/teensy_secure" encrypthex TEENSY41 "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.hex" No key .pem file found, skipping .ehex encryption "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/teensy_post_compile" -file=Guitar.ino "-path=C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259" "-tools=C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/" -board=TEENSY41 "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.sym" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.elf" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/teensy_size" "C:\\Users\\Home\\AppData\\Local\\Temp\\arduino_build_468259/Guitar.ino.elf" Memory Usage on Teensy 4.1: FLASH: code:56340, data:8328, headers:9056 free for files:8052740 RAM1: variables:17376, code:53192, padding:12344 free for local variables:441376 RAM2: variables:16800 free for malloc/new:507488 Multiple libraries were found for "SD.h" Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD Not used: C:\Program Files (x86)\Arduino\libraries\SD Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI Using library SD at version 2.0.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD Using library SdFat at version 2.1.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire C:\Program Files (x86)\Arduino\hardware\teensy/../tools/teensy_post_compile -file=Guitar.ino -path=C:\Users\Home\AppData\Local\Temp\arduino_build_468259 -tools=C:\Program Files (x86)\Arduino\hardware\teensy/../tools -board=TEENSY41 -reboot -port=COM5 -portlabel=COM5 -portprotocol=serial No Teensy boards were found on any USB ports of your computer. Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch.
14:23:41.286 -> SD Card Test
14:23:41.286 -> ------------
14:23:41.427 -> SD card is connected :-)
14:23:41.427 -> Card type is SDHC
14:23:41.427 -> File system space is 260.05 Mbytes.
14:23:41.427 -> SD library is able to access the filesystem
14:23:41.427 ->
14:23:41.427 -> Reading SDTEST1.WAV:
14:23:42.085 -> Overall speed = 0.74 Mbyte/sec
14:23:42.085 -> Worst block time = 1.58 ms
14:23:42.085 -> 54.35% of audio frame time
14:23:42.085 ->
14:23:42.085 -> Reading SDTEST1.WAV & SDTEST2.WAV:
14:23:44.865 -> Overall speed = 0.37 Mbyte/sec
14:23:44.865 -> Worst block time = 2.82 ms
14:23:44.865 -> 97.20% of audio frame time
14:23:44.865 ->
14:23:44.865 -> Reading SDTEST1.WAV & SDTEST2.WAV staggered:
14:23:47.596 -> Overall speed = 0.37 Mbyte/sec
14:23:47.596 -> Worst block time = 2.81 ms
14:23:47.596 -> 96.92% of audio frame time
14:23:47.596 ->
14:23:47.596 -> Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV:
14:23:51.741 -> Overall speed = 0.37 Mbyte/sec
14:23:51.741 -> Worst block time = 4.23 ms
14:23:51.741 -> 145.86% of audio frame time
14:23:51.741 ->
14:23:51.741 -> Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV staggered:
14:23:55.887 -> Overall speed = 0.37 Mbyte/sec
14:23:55.887 -> Worst block time = 4.22 ms
14:23:55.887 -> 145.38% of audio frame time
14:23:55.887 ->
14:23:55.887 -> Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV:
14:24:01.428 -> Overall speed = 0.37 Mbyte/sec
14:24:01.428 -> Worst block time = 5.69 ms
14:24:01.428 -> 196.25% of audio frame time
14:24:01.428 ->
14:24:01.428 -> Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV staggered:
14:24:06.996 -> Overall speed = 0.37 Mbyte/sec
14:24:06.996 -> Worst block time = 5.70 ms
14:24:06.996 -> 196.36% of audio frame time
