Hi all,
I'm relatively new to this but have spent some time working on a Teensy project last year so I know some basics.
I have this CO2 sensor (https://sandboxelectronics.com/?pro...art-5v3-3v-interface-for-arduinoraspeberry-pi) for which they have recommended using a 12V power supply (if you're on an arduino) rather than relying only on USB power. This is explained here: http://sandboxelectronics.com/?p=1126.
Since the teensy 4.1 does not have a 12V jack, I bought an MB102 breadboard power supply module to power both the teensy and the sensor. The teensy uses 3V3 for I2C logic levels, but the sensor is 5V, hence I have a bi-directional logic level shifter too. I have wired power from the MB102 to both the teensy, and the sensor, and have connected the I2C lines to either side of the logic level shifter. My question is: do I also need to connect 3V3 power from the teensy 4.1 to the 'low-voltage' pin in the level shifter?
