Error compiling for board Teensy 4.0
Hey Everyone,
I am building a Audio Guest Book with a Teensy 4.0 with an Audio Shield. I keep getting this error???
Arduino: 1.8.16 (Windows 10), TD: 1.57, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English, Normal"
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:30:24: fatal error: MTP_Teensy.h: No such file or directory
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
compilation terminated.
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Error compiling for board Teensy 4.0.
Originally Posted by
Ronnie Rock
See <this> forum post . . . maybe you are seeing the same problem ?!?
Mark J Culross
KD5RXT
kd5rxt-mark
See
Mark J Culross
KD5RXT
Hi Mark,
I followed that link, Downloaded the MTP_Teensy-main. I dropped the whole folder in the SD folder, following the path leading to the error. I am getting the same error..
You may want to try TeensyDuino 1.58b3. The last post in the linked thread says
compiled just fine using TeensyDuino 1.58b3.
Senior Member+
Ronnie Rock
Hi Mark,
MTP_Teensy is its own library - not to be placed within the SD library folder.
That download folder should go into <sketchbook>\libraries.
New Error... Please help
joepasquariello
Arduino: 1.8.16 (Windows 10), TD: 1.58-beta2, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English, Normal"
Here are my New Errors:
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:49:15: warning: missing terminating ' character
49 | AudioPlaySdWav' playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:49:15: error: missing terminating ' character
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:50:29: error: expected initializer before 'queue1'
50 | AudioRecordQueue queue1; // Creating an audio buffer in memory before saving to SD
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:54:28: error: 'playWav1' was not declared in this scope
54 | AudioConnection patchCord3(playWav1, 0, mixer, 1); // wav file playback mixer
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:57:37: error: 'queue1' was not declared in this scope
57 | AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void loop()':
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:185:7: error: 'playWav1' was not declared in this scope
185 | playWav1.play("greeting.wav");
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void startRecording()':
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:282:5: error: 'queue1' was not declared in this scope
282 | queue1.begin();
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void continueRecording()':
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:297:7: error: 'queue1' was not declared in this scope
297 | if (queue1.available() >= NBLOX) {
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void stopRecording()':
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:329:3: error: 'queue1' was not declared in this scope
329 | queue1.end();
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void playAllRecordings()':
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:374:7: error: 'playWav1' was not declared in this scope
374 | playWav1.play(entry.name());
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:380:13: error: 'playWav1' was not declared in this scope
380 | while (!playWav1.isStopped()) { // this works for playWav
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void playLastRecording()':
C:\Program Files (x86)\Arduino\tools\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:411:3: error: 'playWav1' was not declared in this scope
411 | playWav1.play(filename);
Using library Bounce in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce (legacy)
Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 2.0.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Using library SdFat at version 2.1.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat
Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Serial Flash
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
Using library Time at version 1.6.1 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Time
There should not be a single quote in that statement.
If there are any other errors, post all your code (in code tags please).
Pete
YES!!!! Thank You Pete! It worked... Thank you everyone who helped me with this project..
MORE ERRORS - Why Am I getting this?
Arduino: 1.8.16 (Windows 10), TD: 1.57, Board: "Teensy 4.0, MTP Disk (Experimental), 600 MHz, Faster, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Program Files (x86)\Arduino\audio-guestbook\libraries -fqbn=teensy:avr:teensy40:usb=mtp,speed=600,opt=o2s td,keys=en-us -ide-version=10816 -build-path C:\Users\ronni\AppData\Local\Temp\arduino_build_26 6043 -warnings=none -build-cache C:\Users\ronni\AppData\Local\Temp\arduino_cache_55 964 -verbose C:\Users\ronni\Desktop\audio-guestbook\audio-guestbook.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Program Files (x86)\Arduino\audio-guestbook\libraries -fqbn=teensy:avr:teensy40:usb=mtp,speed=600,opt=o2s td,keys=en-us -ide-version=10816 -build-path C:\Users\ronni\AppData\Local\Temp\arduino_build_26 6043 -warnings=none -build-cache C:\Users\ronni\AppData\Local\Temp\arduino_cache_55 964 -verbose C:\Users\ronni\Desktop\audio-guestbook\audio-guestbook.ino
Using board 'teensy40' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10816 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_MTPDISK -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "C:\\Users\\ronni\\AppData\\Local\\Temp\\arduino_b uild_266043\\sketch\\audio-guestbook.ino.cpp" -o nul
Alternatives for Bounce.h: [Bounce]
ResolveLibrary(Bounce.h)
-> candidates: [Bounce]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10816 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_MTPDISK -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Bounce" "C:\\Users\\ronni\\AppData\\Local\\Temp\\arduino_b uild_266043\\sketch\\audio-guestbook.ino.cpp" -o nul
Alternatives for Audio.h: [Audio@1.3]
ResolveLibrary(Audio.h)
-> candidates: [Audio@1.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10816 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_MTPDISK -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "C:\\Users\\ronni\\AppData\\Local\\Temp\\arduino_b uild_266043\\sketch\\audio-guestbook.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10816 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_MTPDISK -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "C:\\Users\\ronni\\AppData\\Local\\Temp\\arduino_b uild_266043\\sketch\\audio-guestbook.ino.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD@2.0.0]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.4 SD@2.0.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10816 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_MTPDISK -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\src" "C:\\Users\\ronni\\AppData\\Local\\Temp\\arduino_b uild_266043\\sketch\\audio-guestbook.ino.cpp" -o nul
Alternatives for SdFat.h: [SdFat@2.1.2]
ResolveLibrary(SdFat.h)
-> candidates: [SdFat@2.1.2]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10816 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_MTPDISK -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SdFat\\src" "C:\\Users\\ronni\\AppData\\Local\\Temp\\arduino_b uild_266043\\sketch\\audio-guestbook.ino.cpp" -o nul
Alternatives for SerialFlash.h: []
ResolveLibrary(SerialFlash.h)ram Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/Audio.h:129:0,
-> candidates: [] from C:\Users\ronni\Desktop\audio-guestbook\audio-guestbook.ino:25:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/play_serialflash_raw.h:33:25: fatal error: SerialFlash.h: No such file or directory
Invalid library found in C:\Users\ronni\Documents\Arduino\libraries\librari es: no headers files (.h) found in C:\Users\ronni\Documents\Arduino\libraries\librari es
Can you try a fresh install of Arduino 1.8.19 and the latest TD?
Pete
All too often Arduino will print a critical error message together with a lot of unimportant warnings or just info messages.
This this case, the critical error message is this:
Ronnie Rock
This means you copied things to the wrong place when you tried to manually install a library, and Arduino is now confused because it's seeing a nonsensical set of folders and files. Since the problem is in your Documents folder, reinstalling Arduino and Teensyduino will not help.
I can't see your hard drive or your screen, so helping you involves some guesswork based only on info show here. My best guess is you meant to copy some library into {Documents}/Arduino/libraries. Maybe it was in a folder called "libraries" somewhere else on your PC where you downloaded it? Perhaps instead of opening that "libraries" folder and dragging its contents to the "libraries" folder at {Documents}/Arduino, maybe you copied the entire "libraries" folder from the source location to {Documents}/Arduino/libraries, which had the result to creating *ANOTHER* "libraries" folder inside {Documents}/Arduino/libraries?
If you can't figure out how to fix this, and if you don't have any really important work inside that {Documents}/Arduino/libraries (eg, all the libraries are things you've obtained from the internet, not anything you've personally written or modified) then the simplest solution might be the go to {Documents}/Arduino and just completely delete "libraries" and everything inside it, then create a new empty "libraries" folder, and repeat (hopefully correctly) the process of copying all the libraries you need.
Just to explain a bit more, so you can understand better (if you even want that...) and have the ability to check your work, Arduino expects every folder it finds in {Documents}/Arduino/libraries to be a valid library. If you create empty folders or anything else in that location which isn't a valid library, Arduino will get confused. While the set of files and folders that constitute a "valid library" can vary, usually there is a "library.properties" file. Many libraries have a "src" folder with all the library's code, but others have it in the main folder. Either way, Arduino expects to find at least one .h file, inside the "src" folder if it exists, or otherwise in the main folder.
When you copy stuff into {Documents}/Arduino/libraries, everything you put there must actually be a library. If you create more sub-folders (like another folder called "libraries" inside "libraries") you'll get this error from Arduino.
- You may not post replies
- You may not edit your posts
Forum Rules
