* Linux 4.18.0-25-generic #26~18.04.1-Ubuntu x86_64
* 18.04.3 LTS (Bionic Beaver)
* Teensy 4.1
On reboot, I can see /dev/ttyACM0 (Teensy), /dev/ttyACM1 (other device)
When I run a third party application (based on FLIR Spinnaker SDK), I can no longer see /dev/ttyACM0.
In the kernel logs (relevant snippets below), I see
[ 1.232364] hub 2-0:1.0: USB hub found
[ 2.012066] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.172730] usb 1-1: New USB device found, idVendor=16c0, idProduct=0483, bcdDevice= 2.80
[ 2.172731] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.172732] usb 1-1: Product: USB Serial
[ 2.172734] usb 1-1: Manufacturer: Teensyduino
[ 2.172735] usb 1-1: SerialNumber: 12487990
[ 5.503703] usbcore: registered new interface driver usbhid
[ 5.503705] usbhid: USB HID core driver
[ 5.580862] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 5.581849] cdc_acm 1-2:1.0: ttyACM1: USB ACM device
[ 5.582030] usbcore: registered new interface driver cdc_acm
[ 5.582031] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
... I can see the Teensy (ttyACM0)
... Running sample spinview program, example /opt/spinnaker/bin/Acquisition
[ 168.456654] usb 2-4: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 168.668449] usb 1-1: reset high-speed USB device number 2 using xhci_hcd
[ 168.818768] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
... I can not longer see the Teensy in my devices. I can still see /dev/ttyACM1 (other device, not associated with Teensy or third party library)
I have to use this third party SDK, and this reset occurs on the obligatory "Init" call. I would really appreciate new ideas.
These are the third party udev rules (.txt so I could attach). I also have the latest 00-teensy.rules file installed.
View attachment 40-flir.rules.txt
View attachment 40-flir-spinnaker.rules.txt
* Teensy 4.1
