Results 1 to 6 of 6
Thread: Booster for Fastled
    Booster for Fastled
    Hello all
    I have a Teensy 3.6 outputting Fastled data. Reasonably simple project. 12v RGB strip by the way.
    I need to extend the cable to the leds, and at 3m I am starting to get data issues. I believe it is because the 3.3v output is borderline for the strip IC to deal with.
    I would like to make a simple booster circuit (or preferably buy one) that will bump that 3.3v Fastled data up to 5v.
    But I understand that some of these 3.3v to 5v level shifters don't play well with the data speeds that Fastled uses.
    Anyone have any suggestions or advice? Maybe a suggestion of a suitable level shifter.
    Thank you
    Could I simply put a single sacrificial RGB led in the actual controller box as the first led?
    Am I wrong in thinking that first WS2815 RGB strip individual driver chip will then output a 5v level signal onwards?
Name:	LED data issue.jpg
    Jan 2023
    6
    Unusual but it should work.
    If the 3.3v signals are reliable to the first LED, then using the first LED as a level shifter should work. I've used a TXB0104 level-shifter chip with APA102 LEDs without any problem. If you don't want to handle SMD chips a break-out board is available such as https://www.adafruit.com/product/1875
    Mar 2017
    Oakland, CA, USA
    621
    This thread has more information:
    https://forum.pjrc.com/threads/25549...evel-converter
    In summary, the bidirectional shifters are slower. Use the active, unidirectional faster shifters.
    Feb 2016
    Australia
    293
    Quote Originally Posted by SteveCS View Post
    Hello all
    Thank you
    Even level shifted I belive you have issues with a signal like this as the distance increases. Something about balanced / unbalanced signals i dunno. The common thing todo is convert the signal to rs485 levels. The aliexpress devices I use cost a few dollars and will give you the level shifting as a bonus.
    https://www.aliexpress.com/item/3284...d=vaWghBXB2NXp
    pjrc I think sell a rs485 breakout which will do the same thing. You feed one device a 0 - 5 (or 0-3.3) volt signal, it does some rs485 magic and sends it to another rs485 device maybe 100m away and that device spits out 0-5v to your smart led. Works fine for 800khz ws2811 leds.
