I've been working on this project again, this time for the Teensy 4.x. I am emulating the 74 hundred series of Logic IC's starting with the 74HC00 (NAND) and this is my code - working -. The roll section to read an actual IC is not completed yet, I think it will be much simpler than the emulation part.
I connected 8 switches and 4 LED's to the Teensy. The 8 switches represent the NAND IC inputs and the LED's are connected to emulate the outputs of the NAND.
Main question is: Is ther an easier method to code this? Not realy necessary because it works. I intend on emulating more logic and want to make corrections now before I get too much more involved.
[COLOR=#DAE3E3][FONT=Consolas][COLOR=#7f8c8d]// Copyright 2023 Jorge Joaquin Pareja[/COLOR]
[COLOR=#7f8c8d]//[/COLOR]
[COLOR=#7f8c8d]// FileName: HC00.ino[/COLOR]
[COLOR=#7f8c8d]// Purpose: Emulate OR Communicate with 74HC00 Quad 2 Input NAND Gate[/COLOR]
[COLOR=#7f8c8d]// NOTE: Keep in mind that teensy 4.x are limited to 3.3v IO, the 74 series of ic's are higher so care should be taken.[/COLOR]
[COLOR=#7f8c8d]// The 7400 series device datasheet will indicate (in Recomended Operating Conditions) if the real IC can operate[/COLOR]
[COLOR=#7f8c8d]// at Teensy 4.x's voltage levels[/COLOR]
[COLOR=#7f8c8d]// Mocrocontroller: Teensy 4.1[/COLOR]
[COLOR=#7f8c8d]////////////[/COLOR]
[COLOR=#7f8c8d]// Document formatting symbols (forums may mangle this)[/COLOR]
[COLOR=#7f8c8d]// ─ │ ┌ ┐ └ ┘ ├ ┤ ┬ ┴ ┼ ═ ║ ╒ ╓ ╔ ╕╖ ╗ ╘ ╙ ╚ ╛╜╝╞ ╟ ╠ ╡ ╢ ╣ ╤ ╥ ╦ ╧ ╨ ╩ ╪ ╫ ╬[/COLOR]
[COLOR=#7f8c8d]// Documentation[/COLOR]
[COLOR=#7f8c8d]// DocumentationSource : Nexperia 74HC00, This IC can operate at 3.3v of Teensy 4.x, other manufacturers may differ.[/COLOR]
[COLOR=#7f8c8d]// Pinout DIP 14[/COLOR]
[COLOR=#7f8c8d]// ┌──────┬──┬──────┐[/COLOR]
[COLOR=#7f8c8d]// │ └──┘ │[/COLOR]
[COLOR=#7f8c8d]// 1A ┤1 74HC00 14├ VCC[/COLOR]
[COLOR=#7f8c8d]// 1B ┤2 13├ 4B[/COLOR]
[COLOR=#7f8c8d]// 1Y ┤3 12├ 4A[/COLOR]
[COLOR=#7f8c8d]// 2A ┤4 11├ 4Y[/COLOR]
[COLOR=#7f8c8d]// 2B ┤5 10├ 3B[/COLOR]
[COLOR=#7f8c8d]// 2Y ┤6 9├ 3A[/COLOR]
[COLOR=#7f8c8d]// GND ┤7 8├ 3Y[/COLOR]
[COLOR=#7f8c8d]// │ │[/COLOR]
[COLOR=#7f8c8d]// └────────────────┘[/COLOR]
[COLOR=#7f8c8d]// Truth Table (NAND)[/COLOR]
[COLOR=#7f8c8d]// ┌───────────╥────────┐[/COLOR]
[COLOR=#7f8c8d]// │ INPUTS ║ OUTPUT │[/COLOR]
[COLOR=#7f8c8d]// ├─────┬─────╫────────┤[/COLOR]
[COLOR=#7f8c8d]// │ A │ B ║ Y │[/COLOR]
[COLOR=#7f8c8d]// ╞═════╪═════╬════════╡[/COLOR]
[COLOR=#7f8c8d]// │ L │ L ║ H │[/COLOR]
[COLOR=#7f8c8d]// ├─────┼─────╫────────┤[/COLOR]
[COLOR=#7f8c8d]// │ L │ H ║ H │[/COLOR]
[COLOR=#7f8c8d]// │ H │ L ║ H │[/COLOR]
[COLOR=#7f8c8d]// │ H │ H ║ L │[/COLOR]
[COLOR=#7f8c8d]// └─────┴─────╨────────┘[/COLOR]
[COLOR=#7f8c8d]////////////////////[/COLOR]
[COLOR=#7f8c8d]// define the some pins for teensy to act as a 7400 IC (Respecting Teensy's voltage limits)[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_1A[/COLOR] [COLOR=#7fcbcd]0[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_1B[/COLOR] [COLOR=#7fcbcd]1[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_1Y[/COLOR] [COLOR=#7fcbcd]2[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_2A[/COLOR] [COLOR=#7fcbcd]3[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_2B[/COLOR] [COLOR=#7fcbcd]4[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_2Y[/COLOR] [COLOR=#7fcbcd]5[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_3A[/COLOR] [COLOR=#7fcbcd]6[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_3B[/COLOR] [COLOR=#7fcbcd]7[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_3Y[/COLOR] [COLOR=#7fcbcd]8[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_4A[/COLOR] [COLOR=#7fcbcd]9[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_4B[/COLOR] [COLOR=#7fcbcd]10[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_4Y[/COLOR] [COLOR=#7fcbcd]11[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]PIN_ROLL[/COLOR] [COLOR=#7fcbcd]12[/COLOR][COLOR=#7f8c8d] // teensy pin 12 will serve as the input to change the roll of the teensy at runtime[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]BIT0[/COLOR] [COLOR=#7fcbcd]0[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]BIT1[/COLOR] [COLOR=#7fcbcd]1[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]BIT2[/COLOR] [COLOR=#7fcbcd]2[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]BIT3[/COLOR] [COLOR=#7fcbcd]3[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]BIT4[/COLOR] [COLOR=#7fcbcd]4[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]BIT5[/COLOR] [COLOR=#7fcbcd]5[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]BIT6[/COLOR] [COLOR=#7fcbcd]6[/COLOR]
[COLOR=#c586c0]#define[/COLOR] [COLOR=#f39c12]BIT7[/COLOR] [COLOR=#7fcbcd]7[/COLOR]
[COLOR=#0ca1a6]int[/COLOR] lastRoll;
[COLOR=#0ca1a6]int[/COLOR] currentRoll;
[COLOR=#0ca1a6]uint8_t[/COLOR] inputs;
[COLOR=#0ca1a6]uint8_t[/COLOR] outputs;
[COLOR=#7f8c8d]// constants can NOT be changed by setting them in code after programmed to the micro[/COLOR]
[COLOR=#0ca1a6]const[/COLOR] [COLOR=#0ca1a6]int[/COLOR] TEENSY_ROLL_READ_IC = [COLOR=#7fcbcd]0[/COLOR];[COLOR=#7f8c8d] // set the microcontroller to read an actual 74HC00 IC[/COLOR]
[COLOR=#0ca1a6]const[/COLOR] [COLOR=#0ca1a6]int[/COLOR] TEENSY_ROLL_ACT_AS_IC = [COLOR=#7fcbcd]1[/COLOR];[COLOR=#7f8c8d] // act as an 74HC00 IC for testing and learning[/COLOR]
[COLOR=#0ca1a6]void[/COLOR] [COLOR=#f39c12]setup[/COLOR]() {
[COLOR=#7f8c8d] // set direction of roll pin[/COLOR]
[COLOR=#f39c12]pinMode[/COLOR](PIN_ROLL, INPUT_PULLUP);[COLOR=#7f8c8d] // defaults to act as IC[/COLOR]
[COLOR=#7f8c8d] // initialize serial communication:[/COLOR]
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]begin[/COLOR]([COLOR=#7fcbcd]115200[/COLOR]);
[COLOR=#7f8c8d] //wait 0.1 second[/COLOR]
[COLOR=#f39c12]delayMicroseconds[/COLOR]([COLOR=#7fcbcd]100[/COLOR]);
lastRoll = [COLOR=#7fcbcd]1[/COLOR];[COLOR=#7f8c8d] // set to a known value, eg. default state[/COLOR]
[COLOR=#f39c12]getROLL[/COLOR]();
[COLOR=#0ca1a6]void[/COLOR] [COLOR=#f39c12]loop[/COLOR]() {
[COLOR=#7f8c8d] //getROLL();[/COLOR]
[COLOR=#7f8c8d] // print out some data :TODO: check if changes are visible and set lastRole to currentRoll outside of the same function.[/COLOR]
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]print[/COLOR]([COLOR=#7fcbcd]"Current roll: "[/COLOR]);
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]print[/COLOR](currentRoll, DEC);
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]print[/COLOR]([COLOR=#7fcbcd]" Last roll: "[/COLOR]);
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]print[/COLOR](lastRoll, DEC);
[COLOR=#f39c12]readPins[/COLOR]();
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]print[/COLOR]([COLOR=#7fcbcd]" --- Port Input bits: "[/COLOR]);
[COLOR=#f39c12]printBin[/COLOR](inputs);
[COLOR=#f39c12]setOutputs[/COLOR]();
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]print[/COLOR]([COLOR=#7fcbcd]" --- Port Output bits: "[/COLOR]);
[COLOR=#f39c12]printBin[/COLOR](outputs);
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]println[/COLOR]();
[COLOR=#f39c12]delayMicroseconds[/COLOR]([COLOR=#7fcbcd]250[/COLOR]);
[COLOR=#0ca1a6]void[/COLOR] [COLOR=#f39c12]setOutputs[/COLOR](){
outputs = 0b[COLOR=#7fcbcd]00000000[/COLOR];
[COLOR=#7f8c8d] //////////////////////////////////[/COLOR]
[COLOR=#7f8c8d] // Port 1[/COLOR]
[COLOR=#c586c0]if[/COLOR]( ([COLOR=#f39c12]bitRead[/COLOR](inputs,BIT0) == [COLOR=#7fcbcd]1[/COLOR]) && ([COLOR=#f39c12]bitRead[/COLOR](inputs,BIT1) ==[COLOR=#7fcbcd]1[/COLOR]) ){
[COLOR=#f39c12]digitalWrite[/COLOR](PIN_1Y, LOW);
[COLOR=#f39c12]bitWrite[/COLOR](outputs,BIT0,LOW);
[COLOR=#c586c0]else[/COLOR]{
[COLOR=#f39c12]digitalWrite[/COLOR](PIN_1Y, HIGH);
[COLOR=#f39c12]bitWrite[/COLOR](outputs,BIT0,HIGH);
[COLOR=#7f8c8d] // Port 2[/COLOR]
[COLOR=#c586c0]if[/COLOR]( ([COLOR=#f39c12]bitRead[/COLOR](inputs,BIT2) == [COLOR=#7fcbcd]1[/COLOR]) && ([COLOR=#f39c12]bitRead[/COLOR](inputs,BIT3) ==[COLOR=#7fcbcd]1[/COLOR]) ){
[COLOR=#f39c12]digitalWrite[/COLOR](PIN_2Y, LOW);
[COLOR=#f39c12]bitWrite[/COLOR](outputs,BIT1,LOW);
[COLOR=#f39c12]digitalWrite[/COLOR](PIN_2Y, HIGH);
[COLOR=#f39c12]bitWrite[/COLOR](outputs,BIT1,HIGH);
[COLOR=#7f8c8d] // Port 3[/COLOR]
[COLOR=#c586c0]if[/COLOR]( ([COLOR=#f39c12]bitRead[/COLOR](inputs,BIT4) == [COLOR=#7fcbcd]1[/COLOR]) && ([COLOR=#f39c12]bitRead[/COLOR](inputs,BIT5) ==[COLOR=#7fcbcd]1[/COLOR]) ){
[COLOR=#f39c12]digitalWrite[/COLOR](PIN_3Y, LOW);
[COLOR=#f39c12]bitWrite[/COLOR](outputs,BIT2,LOW);
[COLOR=#f39c12]digitalWrite[/COLOR](PIN_3Y, HIGH);
[COLOR=#f39c12]bitWrite[/COLOR](outputs,BIT2,HIGH);
[COLOR=#7f8c8d] // Port 4[/COLOR]
[COLOR=#c586c0]if[/COLOR]( ([COLOR=#f39c12]bitRead[/COLOR](inputs,BIT6) == [COLOR=#7fcbcd]1[/COLOR]) && ([COLOR=#f39c12]bitRead[/COLOR](inputs,BIT7) ==[COLOR=#7fcbcd]1[/COLOR]) ){
[COLOR=#f39c12]digitalWrite[/COLOR](PIN_4Y, LOW);
[COLOR=#f39c12]bitWrite[/COLOR](outputs,BIT3,LOW);
[COLOR=#f39c12]digitalWrite[/COLOR](PIN_4Y, HIGH);
[COLOR=#f39c12]bitWrite[/COLOR](outputs,BIT3,HIGH);
[COLOR=#0ca1a6]void[/COLOR] [COLOR=#f39c12]readPins[/COLOR](){
inputs = 0b[COLOR=#7fcbcd]00000000[/COLOR];
inputs |= [COLOR=#f39c12]digitalRead[/COLOR](PIN_1A) << BIT0;
[COLOR=#f39c12]delayMicroseconds[/COLOR]([COLOR=#7fcbcd]10[/COLOR]);
inputs |= [COLOR=#f39c12]digitalRead[/COLOR](PIN_1B) << BIT1;
inputs |= [COLOR=#f39c12]digitalRead[/COLOR](PIN_2A) << BIT2;
inputs |= [COLOR=#f39c12]digitalRead[/COLOR](PIN_2B) << BIT3;
inputs |= [COLOR=#f39c12]digitalRead[/COLOR](PIN_3A) << BIT4;
inputs |= [COLOR=#f39c12]digitalRead[/COLOR](PIN_3B) << BIT5;
inputs |= [COLOR=#f39c12]digitalRead[/COLOR](PIN_4A) << BIT6;
inputs |= [COLOR=#f39c12]digitalRead[/COLOR](PIN_4B) << BIT7;
[COLOR=#7f8c8d]// Alters IO direction of the respective pins but does not read them[/COLOR]
[COLOR=#0ca1a6]void[/COLOR] [COLOR=#f39c12]setROLL_READ_IC[/COLOR](){
[COLOR=#7f8c8d] // we are reading an actual 7400, set pins appropriately[/COLOR]
[COLOR=#f39c12]pinMode[/COLOR](PIN_1A, OUTPUT);[COLOR=#7f8c8d] // by default, digital pin 0 is used to send signals to 1A[/COLOR]
[COLOR=#f39c12]pinMode[/COLOR](PIN_1B, OUTPUT);[COLOR=#7f8c8d] // by default, digital pin 1 is used to send signals to 1B[/COLOR]
[COLOR=#f39c12]pinMode[/COLOR](PIN_1Y, INPUT);[COLOR=#7f8c8d] // read the result from the 7400 1Y output from digital pin 2[/COLOR]
[COLOR=#f39c12]pinMode[/COLOR](PIN_2A, OUTPUT);[COLOR=#7f8c8d] // same as above with respect to pins for the remaining 7400 ports[/COLOR]
[COLOR=#f39c12]pinMode[/COLOR](PIN_2B, OUTPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_2Y, INPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_3A, OUTPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_3B, OUTPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_3Y, INPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_4A, OUTPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_4B, OUTPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_4Y, INPUT);
currentRoll = TEENSY_ROLL_READ_IC;
}[COLOR=#7f8c8d] // end setROLL_READ_IC[/COLOR]
[COLOR=#0ca1a6]void[/COLOR] [COLOR=#f39c12]setROLL_ACT_AS_IC[/COLOR](){
[COLOR=#f39c12]pinMode[/COLOR](PIN_1A, INPUT_PULLUP);
[COLOR=#f39c12]pinMode[/COLOR](PIN_1B, INPUT_PULLUP);
[COLOR=#f39c12]pinMode[/COLOR](PIN_1Y, OUTPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_2A, INPUT_PULLUP);
[COLOR=#f39c12]pinMode[/COLOR](PIN_2B, INPUT_PULLUP);
[COLOR=#f39c12]pinMode[/COLOR](PIN_2Y, OUTPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_3A, INPUT_PULLUP);
[COLOR=#f39c12]pinMode[/COLOR](PIN_3B, INPUT_PULLUP);
[COLOR=#f39c12]pinMode[/COLOR](PIN_3Y, OUTPUT);
[COLOR=#f39c12]pinMode[/COLOR](PIN_4A, INPUT_PULLUP);
[COLOR=#f39c12]pinMode[/COLOR](PIN_4B, INPUT_PULLUP);
[COLOR=#f39c12]pinMode[/COLOR](PIN_4Y, OUTPUT);
currentRoll = TEENSY_ROLL_ACT_AS_IC;
}[COLOR=#7f8c8d] // end setROLL_ACT_AS_IC[/COLOR]
[COLOR=#7f8c8d]// checks to see if the controll pin (PIN_ROLL) has changed[/COLOR]
[COLOR=#0ca1a6]void[/COLOR] [COLOR=#f39c12]getROLL[/COLOR](){
[COLOR=#7f8c8d] //read ROLL pin[/COLOR]
currentRoll = [COLOR=#f39c12]digitalRead[/COLOR](PIN_ROLL);
[COLOR=#c586c0]if[/COLOR](currentRoll != lastRoll)
[COLOR=#c586c0]switch[/COLOR](currentRoll){
[COLOR=#c586c0]case[/COLOR] TEENSY_ROLL_READ_IC:
[COLOR=#f39c12]setROLL_READ_IC[/COLOR]();
[COLOR=#c586c0]break[/COLOR];
[COLOR=#c586c0]case[/COLOR] TEENSY_ROLL_ACT_AS_IC:
[COLOR=#f39c12]setROLL_ACT_AS_IC[/COLOR]();
[COLOR=#c586c0]default[/COLOR]:
}[COLOR=#7f8c8d]//end switch[/COLOR]
lastRoll = currentRoll;
}[COLOR=#7f8c8d] // end if[/COLOR]
}[COLOR=#7f8c8d] // end getROLL[/COLOR]
[COLOR=#7f8c8d]// to print leading zero's in binary numbers.[/COLOR]
[COLOR=#7f8c8d]// from https://forum.arduino.cc/t/how-can-i-serial-println-a-binary-output-that-will-give-all-the-leading-zeros-of-a-variable/962247[/COLOR]
[COLOR=#0ca1a6]void[/COLOR] [COLOR=#f39c12]printBin[/COLOR](byte aByte) {
[COLOR=#c586c0]for[/COLOR] ([COLOR=#0ca1a6]int8_t[/COLOR] aBit = [COLOR=#7fcbcd]7[/COLOR]; aBit >= [COLOR=#7fcbcd]0[/COLOR]; aBit--)
[COLOR=#f39c12]Serial[/COLOR].[COLOR=#f39c12]write[/COLOR]([COLOR=#f39c12]bitRead[/COLOR](aByte, aBit) ? '1' : '0');
[/FONT][/COLOR]
