Interface_16x16 Example
USB2 PLL running
reset waited 6
USBHS_ASYNCLISTADDR = 0
USBHS_PERIODICLISTBASE = 20003000
periodictable = 20003000
port change: 10001803
connect
begin reset
port change: 18001205
port enabled
end recovery
new_Device: 480 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 00 02 09 00 02 40 40 1A 01 02 00 01 00 01 00 01
VendorID = 1A40, ProductID = 0201, Version = 0100
Class/Subclass/Protocol = 9(Hub) / 0 / 2(Multi-TT)
Number of Configurations = 1
enumeration:
enumeration:
Product: USB 2.0 Hub [MTT]
enumeration:
Config data length = 41
enumeration:
Configuration Descriptor:
09 02 29 00 01 01 00 E0 32
NumInterfaces = 1
ConfigurationValue = 1
09 04 00 00 01 09 00 01 00
Interface = 0
Number of endpoints = 1
Class/Subclass/Protocol = 9(Hub) / 0 / 1(Single-TT)
07 05 81 03 01 00 0C
Endpoint = 1 IN
Type = Interrupt
Max Size = 1
Polling Interval = 12
09 04 00 01 01 09 00 02 00
Interface = 0
Endpoint = 1 IN
Type = Interrupt
Max Size = 1
enumeration:
USBHub memory usage = 960
USBHub claim_device this=200031E0
found possible interface, altsetting=0
found possible interface, altsetting=1
number of interfaces found = 2
best interface is 0 using altsetting 1
USBHub control callback
09 29 07 88 00 32 64 00 FF 00 00 00 00 00 00 00
Hub ports = 7
unhandled setup, message = 10B01
power turned on to all ports
device addr = 1
new_Pipe
allocate_interrupt_pipe_bandwidth
ep interval = 12
interval = 256
best_bandwidth = 2, at offset = 0
pipe cap1 = F0012101
HUB Callback (member)
status = 7E
getstatus, port = 1
deferred getstatus, port = 2
deferred getstatus, port = 3
deferred getstatus, port = 4
deferred getstatus, port = 5
deferred getstatus, port = 6
01 01 01 00
New Port Status
status=10101 port=1
state=0
Device is present:
Has Power
Port Status Cleared, port=1
getstatus, port = 2
01 01 01 00
New Port Status
status=10101 port=2
state=0
Device is present:
Has Power
Port Status Cleared, port=2
getstatus, port = 3
01 01 01 00
New Port Status
status=10101 port=3
state=0
Device is present:
Has Power
Port Status Cleared, port=3
getstatus, port = 4
01 01 01 00
New Port Status
status=10101 port=4
state=0
Device is present:
Has Power
Port Status Cleared, port=4
getstatus, port = 5
01 01 01 00
New Port Status
status=10101 port=5
state=0
Device is present:
Has Power
Port Status Cleared, port=5
getstatus, port = 6
01 01 01 00
New Port Status
status=10101 port=6
state=0
Device is present:
Has Power
Port Status Cleared, port=6
timer event (19999 us): Debounce Timer, this = 200031E0, timer = 200034F8
ports in use bitmask = 7E
getstatus, port = 1
01 01 00 00
New Port Status
status=101 port=1
state=2
Device is present:
Has Power
getstatus, port = 2
01 01 00 00
New Port Status
status=101 port=2
state=2
Device is present:
Has Power
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=2
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=2
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=2
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=2
Device is present:
Has Power
getstatus, port = 1
01 01 00 00
New Port Status
status=101 port=1
state=3
Device is present:
Has Power
getstatus, port = 2
01 01 00 00
New Port Status
status=101 port=2
state=3
Device is present:
Has Power
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=3
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=3
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=3
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=3
Device is present:
Has Power
getstatus, port = 1
01 01 00 00
New Port Status
status=101 port=1
state=4
Device is present:
Has Power
getstatus, port = 2
01 01 00 00
New Port Status
status=101 port=2
state=4
Device is present:
Has Power
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=4
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=4
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=4
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=4
Device is present:
Has Power
getstatus, port = 1
01 01 00 00
New Port Status
status=101 port=1
state=5
Device is present:
Has Power
getstatus, port = 2
01 01 00 00
New Port Status
status=101 port=2
state=5
Device is present:
Has Power
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=5
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=5
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=5
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=5
Device is present:
Has Power
getstatus, port = 1
01 01 00 00
New Port Status
status=101 port=1
state=6
Device is present:
Has Power
sending reset
send_setreset
unhandled setup, message = 40323
getstatus, port = 2
01 01 00 00
New Port Status
status=101 port=2
state=6
Device is present:
Has Power
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=6
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
ports in use bitmask = 7C
getstatus, port = 2
01 01 00 00
New Port Status
status=101 port=2
state=6
Device is present:
Has Power
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=6
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
status = 2
getstatus, port = 1
03 01 10 00
New Port Status
status=100103 port=1
state=7
Device is present:
Enabled, speed = 12 Mbit/sec
Has Power
unhandled setup, message = 140123
timer event (20000 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 2
01 01 00 00
New Port Status
status=101 port=2
state=6
Device is present:
Has Power
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=6
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
timer event (24999 us): Hello, I'm resettimer, this = 200031E0, timer = 20003518
port_doing_reset = 1
PORT_RECOVERY
new_Device: 12 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 00 02 EF 02 01 40 C0 16 42 04 00 02 01 05 03 01
VendorID = 16C0, ProductID = 0442, Version = 0200
Class/Subclass/Protocol = 239 / 2 / 1
enumeration:
enumeration:
Manufacturer: Axoloti
enumeration:
Product: Axoloti Core
enumeration:
Serial Number: 003500323532470532323631
enumeration:
Config data length = 140
enumeration:
09 02 8C 00 03 01 05 C0 32
NumInterfaces = 3
08 0B 00 02 01 03 00 00
Interface Association = 0 through 1
Class / Subclass / Protocol = 1 / 3 / 0
09 04 00 00 00 01 01 00 00
Interface = 0
Number of endpoints = 0
Class/Subclass/Protocol = 1 / 1 / 0
09 24 01 00 01 09 00 01 01
09 04 01 00 02 01 03 00 00
Interface = 1
Number of endpoints = 2
Class/Subclass/Protocol = 1 / 3 / 0
07 24 01 00 01 41 00
06 24 02 01 01 05
06 24 02 02 02 06
09 24 03 01 03 01 02 01 06
09 24 03 02 04 01 01 01 02
09 05 01 02 40 00 00 00 00
Endpoint = 1 OUT
Type = Bulk
Max Size = 64
Polling Interval = 0
05 25 01 01 01
09 05 81 02 40 00 00 00 00
Endpoint = 1 IN
Type = Bulk
Max Size = 64
05 25 01 01 03
08 0B 02 01 FF 00 00 04
Interface Association = 2 through 2
Class / Subclass / Protocol = 255 / 0 / 4
09 04 02 00 02 FF 00 00 04
Interface = 2
Class/Subclass/Protocol = 255 / 0 / 0
07 05 02 02 40 00 00
Endpoint = 2 OUT
Type = Bulk
Max Size = 64
07 05 82 02 40 00 00
Endpoint = 2 IN
Type = Bulk
Max Size = 64
enumeration:
USBHub claim_device this=200035A0
USBHub claim_device this=20003960
USBHub claim_device this=20003D20
Descriptor 11 = IAD
Descriptor 4 = INTERFACE
MIDIDevice claim this=200040E0
len = 123
Interface is unknown (might be Yahama)
type: 36, len: 9
MIDI Header (ignored)
type: 4, len: 9
MIDIDevice claim this=200047E0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=20004EE0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=200055E0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=20005CE0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=200063E0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=20006AE0
len = 123
type: 36, len: 9
type: 4, len: 9
Descriptor 36 = ???
len = 105
Interface is MIDI
type: 36, len: 7
type: 36, len: 6
MIDI IN Jack (ignored)
type: 36, len: 6
type: 36, len: 9
MIDI OUT Jack (ignored)
type: 36, len: 9
type: 5, len: 9
MIDI Endpoint: 1
tx_size = 64
type: 37, len: 5
MIDI Endpoint Jack Association (ignored)
type: 5, len: 9
MIDI Endpoint: 81
rx_size = 64
type: 37, len: 5
type: 11, len: 8
new_Pipe
new_Pipe
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 5 = ENDPOINT
Descriptor 37 = ???
Descriptor 37 = ???
Descriptor 11 = IAD
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
This interface is not MIDI
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
timer event (27214 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 2
01 01 00 00
New Port Status
status=101 port=2
state=6
Device is present:
Has Power
sending reset
send_setreset
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=6
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
ports in use bitmask = 78
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=6
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
status = 4
getstatus, port = 2
03 01 10 00
New Port Status
status=100103 port=2
state=7
Device is present:
Has Power
getstatus, port = 3
01 01 00 00
New Port Status
status=101 port=3
state=6
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
port_doing_reset = 2
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
Serial Number: 003600433435511733353932
enumeration:
enumeration:
NumInterfaces = 3
Interface = 0
Interface = 1
06 24 02 01 01 05
06 24 02 02 02 06
Endpoint = 1 OUT
Type = Bulk
Max Size = 64
05 25 01 01 01
Endpoint = 1 IN
Type = Bulk
Max Size = 64
05 25 01 01 03
Interface = 2
Endpoint = 2 OUT
Type = Bulk
Max Size = 64
Endpoint = 2 IN
Type = Bulk
Max Size = 64
timer event (20108 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 3
enumeration:
Descriptor 11 = IAD
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
Descriptor 36 = ???
len = 105
Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
MIDI Endpoint: 1
tx_size = 64
type: 37, len: 5
type: 5, len: 9
MIDI Endpoint: 81
rx_size = 64
type: 37, len: 5
type: 11, len: 8
new_Pipe
new_Pipe
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 37 = ???
Descriptor 37 = ???
Descriptor 11 = IAD
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
len = 23
type: 5, len: 7
MIDI Endpoint: 2
tx_size = 64
type: 5, len: 7
MIDI Endpoint: 82
rx_size = 64
01 01 00 00
New Port Status
status=101 port=3
state=6
Device is present:
Has Power
sending reset
send_setreset
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
ports in use bitmask = 70
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
status = 8
getstatus, port = 3
03 01 10 00
New Port Status
status=100103 port=3
state=7
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
timer event (24998 us): Hello, I'm resettimer, this = 200031E0, timer = 20003518
port_doing_reset = 3
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 00 02 00 00 00 08 E6 12 16 00 1A 01 01 02 03 01
VendorID = 12E6, ProductID = 0016, Version = 011A
Class/Subclass/Protocol = 0 / 0 / 0
enumeration:
enumeration:
Manufacturer: Waldorf Music GmbH
enumeration:
Product: Pulse2
enumeration:
Serial Number: 9
enumeration:
Config data length = 86
enumeration:
09 02 56 00 02 01 00 80 03
NumInterfaces = 2
Interface = 0
Interface = 1
07 24 01 00 01 32 00
06 24 02 01 01 00
09 24 03 01 02 01 01 01 00
Endpoint = 1 OUT
Type = Bulk
Max Size = 64
05 25 01 01 01
09 05 82 02 40 00 00 00 00
Endpoint = 2 IN
Type = Bulk
Max Size = 64
05 25 01 01 02
enumeration:
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
Descriptor 36 = ???
len = 59
Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
MIDI Endpoint: 1
tx_size = 64
type: 37, len: 5
type: 5, len: 9
MIDI Endpoint: 82
rx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 37 = ???
Descriptor 37 = ???
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
sending reset
send_setreset
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
ports in use bitmask = 60
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
status = 10
getstatus, port = 4
03 01 10 00
New Port Status
status=100103 port=4
state=7
Device is present:
Has Power
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
port_doing_reset = 4
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 10 01 00 00 00 40 C0 16 85 04 11 02 01 02 03 01
VendorID = 16C0, ProductID = 0485, Version = 0211
enumeration:
enumeration:
Manufacturer: Teensyduino
enumeration:
Product: Teensy MIDIx4
enumeration:
Serial Number: 6633190
enumeration:
Config data length = 211
enumeration:
09 02 D3 00 02 01 00 C0 32
NumInterfaces = 2
09 04 00 00 02 01 03 00 00
Interface = 0
07 24 01 00 01 7F 00
06 24 02 01 01 05
06 24 02 02 02 05
09 24 03 01 03 01 02 01 05
09 24 03 02 04 01 01 01 05
06 24 02 01 05 06
06 24 02 02 06 06
09 24 03 01 07 01 06 01 06
09 24 03 02 08 01 05 01 06
06 24 02 01 09 07
06 24 02 02 0A 07
09 24 03 01 0B 01 0A 01 07
09 24 03 02 0C 01 09 01 07
06 24 02 01 0D 08
06 24 02 02 0E 08
09 24 03 01 0F 01 0E 01 08
09 24 03 02 10 01 0D 01 08
09 05 04 02 40 00 00 00 00
Endpoint = 4 OUT
Type = Bulk
Max Size = 64
08 25 01 04 01 05 09 0D
09 05 83 02 40 00 00 00 00
Endpoint = 3 IN
Type = Bulk
Max Size = 64
08 25 01 04 03 07 0B 0F
09 04 01 00 02 03 00 00 00
Interface = 1
Class/Subclass/Protocol = 3(HID) / 0 / 0
09 21 11 01 00 01 22 21 00
HID, 1 report descriptor
07 05 81 03 40 00 01
Endpoint = 1 IN
Type = Interrupt
Max Size = 64
07 05 02 03 20 00 02
Endpoint = 2 OUT
Type = Interrupt
Max Size = 32
Polling Interval = 2
enumeration:
len = 202
Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
MIDI Endpoint: 4
tx_size = 64
type: 37, len: 8
type: 5, len: 9
MIDI Endpoint: 83
rx_size = 64
type: 37, len: 8
type: 4, len: 9
new_Pipe
new_Pipe
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 37 = ???
Descriptor 37 = ???
len = 32
len = 32
len = 32
Descriptor 33 = HID
getstatus, port = 5
01 01 00 00
New Port Status
status=101 port=5
state=6
Device is present:
Has Power
sending reset
send_setreset
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
ports in use bitmask = 40
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
status = 20
getstatus, port = 5
03 01 10 00
New Port Status
status=100103 port=5
state=7
Device is present:
Has Power
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
port_doing_reset = 5
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 00 02 00 00 00 40 83 04 40 57 00 02 01 02 03 01
VendorID = 0483, ProductID = 5740, Version = 0200
enumeration:
enumeration:
Manufacturer: Dreadbox
enumeration:
Product: Typhon
enumeration:
Serial Number: 325B346C3030
enumeration:
Config data length = 204
enumeration:
09 02 CC 00 04 01 00 80 EF
NumInterfaces = 4
08 0B 00 02 01 00 20 00
Class / Subclass / Protocol = 1 / 0 / 0
09 04 00 00 00 01 01 20 00
Interface = 0
Class/Subclass/Protocol = 1 / 1 / 32
09 24 01 00 02 09 2E 00 00
08 24 0A 01 01 01 00 00
11 24 02 03 02 06 00 01 02 00 00 00 00 00 00 00 00
0C 24 03 04 01 01 00 03 01 00 00 00
09 04 01 00 00 01 02 20 00
Interface = 1
Class/Subclass/Protocol = 1 / 2 / 32
09 04 01 01 01 01 02 20 00
Interface = 1
10 24 01 04 00 01 01 00 00 00 02 00 00 00 00 00
06 24 02 01 02 10
07 05 81 05 C4 00 01
Endpoint = 1 IN
Type = Isochronous
Max Size = 196
08 25 01 00 00 00 00 00
09 04 02 00 00 01 01 00 00
Interface = 2
09 24 01 00 01 09 00 01 03
09 04 03 00 02 01 03 00 00
Interface = 3
06 24 02 01 01 00
09 05 02 02 40 00 00 00 00
Endpoint = 2 OUT
Type = Bulk
Max Size = 64
05 25 01 01 01
Endpoint = 2 IN
Type = Bulk
Max Size = 64
05 25 01 01 02
enumeration:
Descriptor 11 = IAD
len = 187
type: 36, len: 9
type: 36, len: 8
Unknown MIDI CS_INTERFACE descriptor!
len = 187
type: 36, len: 9
type: 36, len: 8
len = 187
type: 36, len: 9
type: 36, len: 8
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
len = 132
type: 4, len: 9
len = 132
type: 4, len: 9
len = 132
type: 4, len: 9
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 37 = ???
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
Descriptor 36 = ???
len = 59
Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
MIDI Endpoint: 2
tx_size = 64
type: 37, len: 5
type: 5, len: 9
MIDI Endpoint: 82
rx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 37 = ???
Descriptor 37 = ???
timer event (25688 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 6
01 01 00 00
New Port Status
status=101 port=6
state=6
Device is present:
Has Power
sending reset
send_setreset
ports in use bitmask = 0
status = 40
getstatus, port = 6
03 01 10 00
New Port Status
status=100103 port=6
state=7
Device is present:
Has Power
port_doing_reset = 6
PORT_RECOVERY
new_Pipe
enumeration:
ERROR Followup
remain on followup list
remove from followup list
stray halted 20005A60
qtd: 20005A60, token=80008180, next=20003120
dummy halt: 20003120
enumeration:
ERROR Followup
stray halted 200060A0
qtd: 200059E0, token=80120180, next=200060A0
qtd: 200060A0, token=80008080, next=200060E0
dummy halt: 200060E0
enumeration:
Device Descriptor:
12 01 10 01 00 00 00 40 EF 08 0B 00 02 01 00 20 00 09
VendorID = 08EF, ProductID = 000B, Version = 0102
Number of Configurations = 9
qtd: 200059A0, token=87FC0180, next=20005A60
qtd: 20005A60, token=80008080, next=20003120
enumeration:
ERROR Followup
qtd: 20005960, token=80090180, next=200060A0
enumeration:
Config data length = 256
qtd: 20005920, token=81000180, next=20005A60
enumeration:
error: config must be 9 bytes
ERROR Followup
qtd: 200060A0, token=80008180, next=200060E0
enumeration:
Descriptor 11 = IAD
len = 239
type: 36, len: 9
type: 36, len: 8
len = 239
type: 36, len: 9
type: 36, len: 8
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
len = 184
type: 4, len: 9
len = 184
type: 4, len: 9
len = 175
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 175
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 37 = ???
len = 129
type: 36, len: 9
type: 4, len: 9
len = 129
type: 36, len: 9
type: 4, len: 9
Descriptor 36 = ???
len = 111
Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
MIDI Endpoint: 2
tx_size = 64
type: 37, len: 5
type: 5, len: 9
MIDI Endpoint: 82
rx_size = 64
type: 37, len: 5
type: 5, len: 7
MIDI Endpoint: 2
len = 111
Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
MIDI Endpoint: 2
tx_size = 64
type: 37, len: 5
type: 5, len: 9
MIDI Endpoint: 82
rx_size = 64
type: 37, len: 5
type: 5, len: 7
MIDI Endpoint: 2
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 37 = ???
Descriptor 37 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ???
Descriptor 0 = ??
the Descriptor 0 = ??? part simply repeats forever...
