MSC race condition during initialization
wwatson
@Paul @KurtE - Using Arduino 1.8.19, TD1.58 Beta3 I am seeing a intermittent situation with MSC where during uploading and sometimes powering up using the "DriveInfo.ino" sketch for testing results in the msDriveInfo struct is blank:
Waiting for Drive to initialize...
Device Info:
       connected: 1
     initialized: 0
   USB Vendor ID: 0000
  USB Product ID: 0000
      HUB Number: 0
        HUB Port: 0
  Device Address: 0
Removable Device: NO
        VendorID:
       ProductID:
      RevisionID:
         Version: 0
    Sector Count: 0
     Sector size: 0
   Disk Capacity: 0 Bytes
Volume name: 32GFAT32
Volume type: FAT32
Cluster Size: 16384 bytes
Volume size: 30927306752 bytes
 Space used: 375930880 bytes  (922 ms to compute)
Files:
2021-10-03 16:29   56863276 armaged.wav
2019-01-01 08:14   40900890 Daddy's_Little_Man.wav
2021-09-12 23:48   43025728 DeffLepardAnimal.wav
2021-09-12 23:46   60148898 StatusQuoWhateverYouWant.wav
2021-09-12 23:44   35639166 ThePaperboysMolinos.wav
2019-01-01 08:01   36381082 ThePaperboysMolinosI'veJustSeenaFace.wav
2021-09-12 23:47  102878882 YoureLazyJimmyBarnesJoeBonamassa.wav
It shows the device is connected but everything else is 0 including 'initialized'. This is from 'printDriveInfo(myDrive)'. The drive info is filled in by the 'mscInit()' function.
Other times the output is correct:
Device Info:
       connected: 1
     initialized: 1
   USB Vendor ID: 0951
  USB Product ID: 1666
      HUB Number: 0
        HUB Port: 0
  Device Address: 1
Removable Device: YES
        VendorID: Kingston
       ProductID: DataTraveler 3.0
      RevisionID:
         Version: 6
    Sector Count: 60437491
     Sector size: 512
   Disk Capacity: 30943995392 Bytes
Partition Table
	part,boot,bgnCHS[3],type,endCHS[3],start,length
FAT32:	1,0,0x4,0x1,0x4,0xB,0xFE,0xC2,0xFF,2048,60434432
pt_#0:	2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
pt_#0:	3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
pt_#0:	4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
	 < unused area starting at: 60436480 length 1011 >
Volume type: FAT32
Files:
I added a 'Serial.printf()' in:
bool USBDrive::begin() {
	m_errorCode = MS_CBW_PASS;
[COLOR="#FF0000"]Serial.printf("mscInit()\n");[/COLOR]
	mscInit(); // Do initial init of each instance of a MSC object.
	m_errorCode = checkConnectedInitialized();
	if (m_errorCode) { // Check for Connected USB drive.
		m_initDone = false;
		m_initDone = true;
	return m_initDone;
And the result when failing is:
Device Info:
       connected: 1
     initialized: 0
   USB Vendor ID: 0000
      HUB Number: 0
        HUB Port: 0
  Device Address: 0
        VendorID:
       ProductID:
      RevisionID:
         Version: 0
    Sector Count: 0
     Sector size: 0
[COLOR="#FF0000"]mscInit()[/COLOR] <------ mscInit() called after printDriveInfo().
Volume name: 128GEXFAT
Volume type: FAT64
Cluster Size: 131072 bytes
Volume size: 123723579392 bytes
 Space used: 159121408 bytes  (91 ms to compute)
Files:
2011-09-07 16:39     74002706 rom-hackerboard-3320.zip
2022-04-04 15:07     74901978 rom-falconwing.img.zip
2011-10-30 12:07       978134 IOMux.v2.0.27.zip
2011-10-30 12:07       754815 IMX23REFSCH.zip
2022-04-04 17:51      4273249 falconwing_chb3_all.zip
2011-09-07 16:39         7368 chumby-user-group-pages.zip
2011-09-07 16:39       115691 chumby-user-group-files.zip
2011-09-07 16:39       470245 chumbyone_gerbers.zip
2011-09-07 16:39       664812 chumby_hackerboard_gerbers.zip
2011-09-07 16:39      1748436 chumby_hackerboard.zip
2011-10-30 12:06        18247 Debian_on_a_Chumby.html
When not failing results are:
[COLOR="#FF0000"]mscInit()[/COLOR] <------ mscInit() called before printDriveInfo().
Device Info:
       connected: 1
     initialized: 1
   USB Vendor ID: 0951
      HUB Number: 0
        HUB Port: 0
  Device Address: 1
        VendorID: Kingston
      RevisionID:
         Version: 6
    Sector Count: 241660915
     Sector size: 512
   Disk Capacity: 123730388480 Bytes
Partition Table
exFAT:  1,0,0x4,0x1,0x4,0x7,0xFE,0xC2,0xFF,2048,241657856
         < unused area starting at: 241659904 length 1011 >
Volume type: FAT64
 Space used: 159121408 bytes  (90 ms to compute)
Files:
This may or may not be a problem but can be misleading and/or misinterpreted as a failure. 'mscInit()' is eventually called after 'printDriveInfo'.
If I add a manual call to 'myDrive.begin()'in the sketch the results are:
[COLOR="#FF0000"]mscInit()[/COLOR] <----- Manual call to myDrive.begin().
Device Info:
       connected: 1
     initialized: 1
   USB Vendor ID: 0951
      HUB Number: 0
        HUB Port: 0
  Device Address: 1
        VendorID: Kingston
      RevisionID:
         Version: 6
     Sector size: 512
Partition Table
[COLOR="#FF0000"]mscInit()[/COLOR] <----- startFileSystems() call to USBDrive::begin().
Volume type: FAT64
Files:
Successful initialization consistently. Will have to experiment more to try and fix it. Any help is welcome:)
Edit: Tested with 4 different USB thumb drives and a SSD drive. Same results.
Turns out the issue is with 'DriveInfo.ino' itself. Here is the changed section of the sketch.
  // Wait for the drive to start.
  while (!myDrive) {
[COLOR="#FF0000"]//    myusb.Task();[/COLOR]
[COLOR="#FF0000"]  myusb.Task();[/COLOR]
This works consistently with all my USB drives.
Ran out of time tonight check it out further...
