Page 1 of 2 1 2 LastLast
Results 1 to 25 of 42
Thread: Help me optimise this code
    Jan 2020
    284
    I wrote a class that does some calculations. It compares a 1d signal with a template of a peak and calculates the absolute difference after normalisation. I have a function that triggers based on a threshold but I want to only trigger signals of a certain shape and this class does this.
    I'm using the circular buffer library to store previous values, it's inside the m_dataStorage referenced member.
    Note that I'm only using the ComputeManhattan method called from the "ExecuteAndStore" method and I'm creating the object at compile time. Can I speed this up somehow? It works great but it's too slow. I'm planning to prune the values because I can calculate on every other sensor reading but if something more can be done I'm all ears. I'm using the teensy 4.
    Here is the .h file:
    #pragma once
    #include <cmath>
    #include <algorithm>
    #include "ProcessedSensorData.h"
    class CrossCorrelation {
    private:
        float* m_templateSignal;
        float* m_targetSignal;
        const int m_signalLength;
        ProcessedSensorData& m_dataStorage;
    public:
        CrossCorrelation(const float* templateSignal, const int signalLength, ProcessedSensorData& dataStorage);
        ~CrossCorrelation() {
            delete[] m_templateSignal;
            delete[] m_targetSignal;
        float ExecuteAndStore(int sensorID) {
            //calculate similarity of signals with a template signal
            float xCorr = 0.0f;
            xCorr = ComputeManhattan(sensorID);
            xCorr = std::min(xCorr, 30.0f);
            //store the result in buffer
            m_dataStorage.headPeakSimilarity.at(sensorID).push_front(xCorr);
            return xCorr;
    private:
        void NormalizeSignal(int sensorID);
        float Compute(int sensorID);
        inline float ComputeManhattan(int sensorID) {
        NormalizeSignal(sensorID);
        float result = 0.0f;
        for (int i = 0; i < m_signalLength; i++) {
            result += (std::fabs(m_targetSignal[i] - m_templateSignal[i]));
        return result;
    Here is the .cpp file:
    #include "CrossCorrelation.h"
    CrossCorrelation::CrossCorrelation(const float* templateSignal, const int signalLength, ProcessedSensorData& dataStorage)
        m_signalLength(signalLength),
        m_dataStorage(dataStorage)
        m_templateSignal = new float[signalLength];
        m_targetSignal = new float[signalLength];
            m_templateSignal[i] = templateSignal[i];
            m_targetSignal[i] = 0.0f;
        std::reverse(m_templateSignal, m_templateSignal + m_signalLength);
        //normalise template signal
        float max = 0.0f;
        //float average = 0.0f;
            max = std::max(m_templateSignal[i], max);
            //average += m_templateSignal[i];
        //average /= m_signalLength;
        //max -= average;
        //std::max(max, 10.0f);
            m_templateSignal[i] /= max;
    float CrossCorrelation::Compute(int sensorID) {
            result += m_targetSignal[i] * m_templateSignal[i];
        return result;
    void CrossCorrelation::NormalizeSignal(int sensorID) {
        float max = 0.0f;
            m_targetSignal[i] = m_dataStorage.headSimilaritySignal.at(sensorID).peek(i);
            if(m_targetSignal[i] > max) {
                max = m_targetSignal[i];
            //average += m_targetSignal[i];
        //max -= average;
            m_targetSignal[i] /= max;
    Jan 2020
    284
    These are the functions that are run continuously and I'm wondering if there is anything I'm doing that's stupid and will waste cycles because it's pretty slow right now.
    I'm normalising a 1d signal of 60 elements and calculating the absolute difference between that and a template of the same size. It takes like 2100 cycles which seems kind of high. I need to do this between sensor reads and it's too slow.
        return result;
        float max = 0.0f;
    Sep 2021
    239
    Quote Originally Posted by frankzappa View Post
    Divisions are slow. I have not tried it, but maybe it helps to multiply with 1.0f/max instead:
        max = 1.0f/max;
            m_targetSignal[i] *= max;
    Not sure if this is helpful for your one-loop solution.
    Jan 2020
    284
    Quote Originally Posted by Mcu32 View Post
        max = 1.0f/max;
    Thanks. I’ll see if it makes a difference. I think division and multiplication are the same on the teensy 4 but I haven’t measured it.
    Jan 2020
    284
    I've solved it (sort of). Made it go from 3.5 microseconds per sensor to 1.7 which is good enough. I got rid of one of the loops by combining the nompalise into the function. I tried various things but unrolling the loop basically cut it in half and that works for my use case although it's a monstrosity. Also std::array was more performant than c-arrays strangely. The std::fabs was faster than any home cooked version I could come up with like x > 0 ? -x : x for instance.
    BTW this is not premature optimisation, it was a bottleneck.
    17,424
    Cool. 35 cycles per float element didn't seem unexpectedly out of bounds
    Wonder if the array diff is because it might use *ptr indexing versus [ii] indexing ...
    Jan 2020
    284
    After pruning so that every other sample is used and unrolling it's now really fast. Went from 3.5 to below 1 micros per call. It's less elements but sufficient for my use case.
    std::array was faster but negligible. I did 14 calls with arrays of size 55 and measured the time and it was 3 micros faster, from 48 to 45 micros. I think *ptr indexing is faster.
    I have one thing yet to try, copying the whole chunk of data from the circular buffer into the array (there is a built in function I think). Now I'm peek() ing into every element in the unrolled loop, might save a few cycles as well.
    17,424
    Before you posted the enormous gains I was going to ask how the samples are acquired? ... Snippets don't show that ...
    And given floats - maybe it doesn't involve an ADC digital value read at all ...
    If reading is waiting on ADC to complete - at least with the ADC library that has a non-blocking read Start - the Read could be started - then MATH done on PRIOR Read array element - then read the NEW value 'when ADC complete'.
    At the end of that the prior values would be normalized for use - and the next set of RAW values would be ready for the next pass.
    This would always put the normalization one step behind the most recent data - but those MATH cycles would be done 'for free' while the ADC sample was acquired.
    Jan 2020
    284
    I'm reading sensor pairs and processing the two previous pairs so it's as good as it can get I think. I'm doing all calculations while waiting for sensor reads. Problem before was I had about 5 micros before the sensor pair was ready but the calculations took 7 micros so was slowing it down and making all my filters not have the right values any more because they are pre calculated for a certain sample rate.
    It's actually based on ADC code you wrote for me when I just started programming. Still using that technique for reading sensors haha. I'm filtering the values before the normalisation and curve fitting stuff so they are floats.
    Now since I'm doing every other loop cycle for this code I'm processing only one sensor for every pair at a time so it's super fast, like 1 microsecond or so. Problem is solved.
    Sep 2021
    239
    No, a floating point multiply needs up to 3 cycles, division up to 18.
    https://www.quinapalus.com/cm7cycles.html
    Jan 2020
    284
    Really? In that case then it should make a big difference. I think I read in a post on the forum that it was 1 cycle for division/multiplication/addition/subtraction with floats and two cycles for doubles. I believe it was PaulStoffegren who wrote it but I guess I'm mistaken. Also he said teensy will use double precision if you don't append literals with "f".
    Sep 2021
    239
    1 cycle for a div is not even for 16/32-bit-integer true udiv is 3 cycle minimum, in most cases more.
    a div is expensive.
    Jan 2020
    284
    I will try it, it would explain why it is so slow. I was expecting a lot fewer cycles. I assumed it was all the comparisons for the loop. Unrolling the loop made it twice as fast but if this works and is much faster maybe I can keep the for loop or maybe make a loop that executes 10 calculations per loop cycle. Loop is much more flexible.
    Sep 2021
    239
    p.s. you know gcc has a #pragma for unrolling? the compiler can do it for you.
    Jan 2020
    284
    Yeah I read about that but I'm not sure which compiler platformio uses. Can you show me an example how to unroll and I'll see if it works?
    Sep 2021
    239
    It will be not _that_ much faster, because the count of loops is important, too. an unrolled loop has much less jumps and compares. jumps are a bit expensive, too (not as much as a division)
    But both together is ok
    Jan 2020
    284
    Well I should be able to save like 1000 cycles per sensor pair and that is a lot. I'm doing this for 5 sensor pairs in between the sensor readings and I only have 5 microseconds of total time to calculate a sensor pair until the next pair is ready.
    Jan 2020
    284
    I changed the division to a multiplication as suggested and the program seems to work the same. I'll have to measure it.
    Jan 2020
    284
    I executed 10 of these calculations and printed the result, it's like 10 times faster lol.
    Thanks for the link and the suggestion for the optimization. This knowledge will come in handy later when I have to do a lot of similar calculations.
    Sep 2021
    239
    you're welcome
    17,424
    you're welcome
    Frank
    Senior Member JarkkoL's Avatar
    Jul 2013
    150
    You could remove the second loop in NormalizeSignal() and just return the max, then perform the normalization while calculating the abs delta in ComputeManhattan().
  24. #24
    Jan 2020
    284
    Quote Originally Posted by JarkkoL View Post
    I already did that if you read my comments above
    Thanks for the suggestion.
  25. #25
    Jul 2013
    150
    Ah, didn't see. Can you show what's the current optimized version?
