Results 1 to 6 of 6
Thread: Cannot upload program to teensy 4.0 with VSCode PlatformIO on Fedora37
    Hey!
    I am just switchting a project over from an arduino to a teensy 4.0. I am working on Fedora37 on a framework laptop running VSCode and PlatformIO. I can build and test the program that I am working on and was running on the arduino but I get an error when I want to upload it.
    I get this in my Terminal:
    Opening Teensy Loader...
    Teensy did not respond to a USB-based request to enter program mode.
    *** [upload] Error 1
    I also tried to press the teensy button in different ways. Just once, 15sec and right when I plugged it in but none of this made a difference.
    I am wondering if it can be related to the fact that on my PlaformIO Devices it says No Items. Should I see the used USB Port there? Or do I need to define the port somewhere?
    11,466
    Did you install the udev.rules on this machine?
    Maybe try different USB cable. Maybe it is a power only one?
    I thought I dont have to since PlatformIO is handling it. It also opens the Teensyduino window when I click on Upload in VSCode.
    But will try another cable, but I think I have used it with teenies before but will check.
    11,466
    I would double check the udev rule, as when I install teensyduino directly for Arduino IDE, on Ubuntu, I have to manually copy the file to the right location.
    Edit, and I would also maybe see what the linux tells you when you plug the teensy in.
    like plug in the teensy and do a command like: sudo dmesg | tail -30
    or other commands like journalctl (sp)
    And does it recognize the teensy
    Ha! I was downloading the udev rule and copied it in the right folder and now i get a sccess instead of an error when uploading the program. but it still seems the arduino is running the blink program. or i got messy with wirering the components as i moved from arduino to teensy. need to double check.
    haha actually it works!!! I just selected the wrong programm that should be uploaded in Platform IO. It was actually set to the blink project Thanks for helping out!
