Results 1 to 7 of 7
Thread: How to detect USB state changes - suspend/resume in particular?
    Junior Member FeuerSturm's Avatar
    Jan 2023
    15
    is there a callback or function that I can use to keep
    track of USB state changes?
    I'd need to know when the USB state changes to suspended
    and resume to turn off and on attached led strips.
    I've looked through the source files but didn't see anything
    ready to use, any ideas?
    Thanks in advance!
    16,871
    Seems some weeks/months back a status register (?) was indicated to track the connect state?
    Jan 2023
    15
    To be honest, I have no idea what you're trying to tell me
    16,871
    Quote Originally Posted by FeuerSturm View Post
    ... with a search of forum there is a posting making note of a status register that changes when USB drops and returns IIRC.
    16,871
    quick search of 'usb status' found this down some dozen lines: pjrc.com/threads/70721-detecting-usb-connection-on-a-teensy-4-0
    What finally worked was to check the suspend flag in the PORTSC1 register. 1 = Suspend state, 0 = not in Suspend state.
    Jan 2023
    15
    Thank you, this is what I was looking for.
    I did search various different combinations of terms, but that post didn't come up.
    Jan 2023
    15
    I've tried that approach and it is working unreliable for me at most.
    I'm using this simple test code:
    unsigned long lastCheck;
    	pinMode(LED_BUILTIN, OUTPUT);
    	unsigned long currentMillis = millis();
    	if(currentMillis - lastCheck >= 1000)
    		lastCheck = currentMillis;
    		if(!bitRead(USB1_PORTSC1,7))
    The led does turn on, but randomly turns off for seconds and turns on again.
    Am I doing something wrong?
    Thanks!
