Results 1 to 14 of 14
Thread: Teensy 4.0 broken USB
    Nov 2020
    Czech Republic
    125
    I have Teensy 4.0 and project where I send data via USB cable to PC. But quite offten I hav problem, if I touch the cable or Teensy in plastic box, then Teensy is starting connecting and disconnecting and I have to move with micro usb connector many times to connect again. Do you have eny experience how to solve it? Maybe use any external usb connector?
    I need very durable connector solution beacuse I use my project in field mesurements and speed of USB in the same time.
    For you information, this is the box:
    Thank you!
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    1,248
    Sounds to me that the USB cable is not inserted all the way into the Teensy 4 USB connector. Is the opening in the plastic housing large enough to let the cable through? Can you show us a close-up photo of the Teensy USB connector with the USB cable plugged in?
    Another possibility is that 1 or more pins of the USB connector on the Teensy 4 have a bad contact due to mechanical stress. Or pins from the USB connector to the PCB have come partly loose.
    Paul
    Nov 2020
    Czech Republic
    125
    Yes, connector is all inserted (tried without box). Seems loose a lot. Tried many cables. I can move the connector left/right very easily and Teensy is connecting / disconnecting. Is there any way how to correct it?
    1) Because this is project for mesuring at construction site, lot of dust, etc. - how to solve heavy duty usb connection to laptop?
    2) Is there another way how to connect to laptop and send about 500kB in less than one second?
    Senior Member blackketter's Avatar
    May 2015
    San Francisco
    356
    I'd check those surface mount pads on the USB connector very closely and try reflowing the solder to them.
    If that fixes it, think about reworking your enclosure to use a more robust connector, maybe with something like this:
    https://www.adafruit.com/product/3258
    If that connector breaks, then you can replace it more easily than fixing or replacing the Teensy.
    Apr 2015
    Netherlands
    1,248
    Are the pins in the orange circle still connected OK?
Name:	T4 USB pins.jpg
    On 1: perhaps this kind of connector?
    Micro-USB and heavy duty are not companions...
    On 2: you may want consider a high speed serial connection with an industrial dust/water-proof 3-pin connector?
    3) a metal box may also be wise on a construction site.
    Paul
    Cheltenham, UK
    1,381
    You might find one of these with it's protective cap more robust in those sort of environments. That is as long as the cap is replaced each time.
Name:	USB Extension Socket right angle.png
    Nov 2020
    Czech Republic
    125
    Paul
    Pins looks connected ok.
    "high speed serial connection with an industrial dust/water-proof 3-pin connector"
    What is it? I do not know this connection.
    Also I have to solve problems like lot of noise from USB cable. But if I use USB replicator, the noise is low.
    Cheltenham, UK
    1,381
    USB connector pushed in many times and probably not carefully. That is probably the source of your bad connections.
    Probably about time to change the connector to a chassis mount one as has been described to you.
    Otherwise the Teensy may well stop connecting to the PC with that worn Socket.
    Apr 2015
    Netherlands
    1,248
    Quote Originally Posted by frohr View Post
    E.g. RS-232, RS-422, RS-485, etc. And then select a suitable industrial connector.
    Paul
    Apr 2015
    Netherlands
    1,248
    To 'rescue' the worn USB connector, you may try to press [very gently] the top and bottom metal closer together using pliers.
    But that's definitely not a permanent solution...
    Paul
    Nov 2020
    Czech Republic
    125
    Paul
    How to connect it to teensy? Thank you
    Apr 2015
    Netherlands
    1,248
    Using Teensy 4's hardware serial ports.
    Paul
    Nov 2020
    Czech Republic
    125
    Is possible use D+ D- GND and 5v to send data? If yes, I can make special USB cable and use something like military connectors.
    17,433
    On T_4.0 bottom side pads? That D+ and D- are to USB_Host port. Data could be sent to a Device - but not to a Host using those underside pads.
    Device could be a hard drive or flash drive or other supported device adapter - seems one was wired ethernet.
