problem with 4.0
carpracing
getting this error message i am a total newbie with this so be gentle plz
Arduino: 1.8.19 (Windows 10), TD: 1.57, Board: "Teensy 4.0, Serial, 600 MHz, Faster, United Kingdom"
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/Audio.h:129:0,
from C:\Users\iandi\Documents\Arduino\Audio_GuestBook1\Audio_GuestBook1.ino:31:
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/play_serialflash_raw.h:33:25: fatal error: SerialFlash.h: No such file or directory
Not used: C:\Program Files (x86)\Arduino\libraries\SD
compilation terminated.
It's not finding the SerialFlash library.
Simplest solution is the run the Teensyduino installer again. On the screen for which optional libraries to install, best to just install them all. SerialFlash is one of those. Audio needs it, even if you don't use that sort of memory chip, because it needs to compile code which could read from that type of memory.
Sometimes lame anti-virus software or even Windows Defender can interfere with writing files to your hard drive. Usually this affects exe programs rather than source code file, but those anti-virus programs are really unpredictable. If you run the installer again and select all libraries, or at least make sure SerialFlash is checked, but this problem persists, you might need to temporarily disable anti-virus while running the installer. The installer does not use internet access in any way, so you can unplug from the internet while anti-virus is off, run the installer, then turn it back on and plug back into the net.
re installed programme now getting this message
sketch_feb01a: In function 'void loop()':
sketch_feb01a:148: warning: enumeration value 'Initialising' not handled in switch
switch(mode){
sketch_feb01a: In function 'void playAllRecordings()':
C:\Users\iandi\Documents\Arduino\Audio_GuestBook1\sketch_feb01a\sketch_feb01a.ino:304:36: warning: invalid conversion from 'const char*' to 'char*' [-fpermissive]
if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
In file included from c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\stdlib.h:11:0,
from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/WProgram.h:34,
from C:\Users\iandi\AppData\Local\Temp\arduino_build_899385\pch\Arduino.h:6:
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\string.h:150:7: note: initializing argument 1 of 'char* strlwr(char*)'
char *_EXFUN(strlwr,(char *));
sketch_feb01a: In function 'void setup()':
sketch_feb01a:363: error: redefinition of 'void setup()'
}void setup() {
C:\Users\iandi\Documents\Arduino\Audio_GuestBook1\sketch_feb01a\sketch_feb01a.ino:87:6: note: 'void setup()' previously defined here
sketch_feb01a:368: error: redefinition of 'void loop()'
C:\Users\iandi\Documents\Arduino\Audio_GuestBook1\sketch_feb01a\sketch_feb01a.ino:143:6: note: 'void loop()' previously defined here
sketch_feb01a:371: error: redefinition of 'void setup()'
}void setup() {
sketch_feb01a:376: error: redefinition of 'void loop()'
this is the code i am trying to get to work
 * Audio Guestbook, Copyright (c) 2022 Playful Technology
 * Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
 * with minor modifications on other similar hardware
 * When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
 * Then, recording starts, and continues until the handset is replaced.
 * Playback button allows all messages currently saved on SD card through earpiece
 * Files are saved on SD card as 44.1kHz, 16-bit, mono signed integer RAW audio format
 * These can be loaded directly into Audacity ([url]https://www.audacityteam.org/[/url]). Or else, converted to WAV/MP3 format using SOX ([url]https://sourceforge.net/projects/sox/[/url])
// **********   Rik  6/22/2022  -   My mods are marked with RAM in comments.  *********
// ************  GREETING MUST BE RECORDED IN .RAW FORMAT  (16 BIT 44.1Khz. MONO)   ****************************************************************
// INCLUDES
// The default "sketchbook" location in which Arduino IDE installs libraries is:
// C:\Users\alast\Documents\Arduino
// However, the TeensyDuino installer installs libraries in:
// C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries
// To ensure the correct libraries are used when targetting Teensy platform in Arduino IDE, go File->Preferences and change the sketchbook location to avoid conflicts with Arduino libraries.
// When targetting Arduino boards, change it back again to default
#include <Bounce.h>
#include <TimeLib.h>
// DEFINES
// Define pins used by Teensy Audio Shield
#define SDCARD_CS_PIN    10
#define SDCARD_MOSI_PIN  7
#define SDCARD_SCK_PIN   14
// And those used for inputs
#define HOOK_PIN 0
#define PLAYBACK_BUTTON_PIN 1
int     hookRead;  // Added to check for hang up before playing greeting.  RAM
int     x;
// GLOBALS
// Audio initialisation code can be generated using the GUI interface at [url]https://www.pjrc.com/teensy/gui/[/url]
// Inputs
AudioSynthWaveform      waveform1; // To create the "beep" sfx
AudioInputI2S           i2s2; // I2S input from microphone on audio shield
AudioPlaySdRaw          playRaw1; // Play .RAW audio files saved on SD card
AudioPlaySdWav          playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
// Outputs
AudioRecordQueue         queue1; // Creating an audio buffer in memory before saving to SD
AudioMixer4              mixer; // Allows merging several inputs to same output
AudioOutputI2S           i2s1; // I2S interface to Speaker/Line Out on Audio shield
// Connections
AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
AudioConnection patchCord2(playRaw1, 0, mixer, 1); // raw audio to mixer
AudioConnection patchCord3(playWav1, 0, mixer, 2); // wav file playback mixer
AudioConnection patchCord4(mixer, 0, i2s1, 0); // mixer output to speaker (L)
AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
AudioConnection patchcord6(i2s2, 0, mixer, 3); // Added mic input to mixer to hear talking through handset speaker.  RAM
AudioControlSGTL5000     sgtl5000_1;
// Filename to save audio recording on SD card
char filename[15];
// The file object itself
File frec;
// Use long 100ms debounce time on hook switch
Bounce buttonRecord = Bounce(HOOK_PIN, 100);    // default (40).  RAM
Bounce buttonPlay = Bounce(PLAYBACK_BUTTON_PIN, 100);   // default (8).  RAM
// Keep track of current state of the device
enum Mode {Initialising, Ready, Prompting, Recording, Playing};
Mode mode = Mode::Initialising;
  // Note that Serial.begin() is not required for Teensy -
  // by default it initialises serial communication at full USB speed
  // See [url]https://www.pjrc.com/teensy/td_serial.html[/url]
  // Serial.begin()
  Serial.println(__FILE__ __DATE__);
  // Configure the input pins
  pinMode(HOOK_PIN, INPUT_PULLUP);
  pinMode(PLAYBACK_BUTTON_PIN, INPUT_PULLUP);
  AudioMemory(60);
  sgtl5000_1.enable();
  // Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
  sgtl5000_1.volume(0.6);  // Output speaker volume.  default (.5).   RAM
  // Play a beep to indicate system is online
  waveform1.frequency(440);
  waveform1.amplitude(0.9);
  wait(250);
  waveform1.amplitude(0);
  // Initialize the SD card
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
    while (1) {
  // Mic Gain (Value in dB)
  sgtl5000_1.micGain(38);   // default (15).  RAM
  // Synchronise the Time object used in the program code with the RTC time provider.
  // See [url]https://github.com/PaulStoffregen/Time[/url]
  // Define a callback that will assign the correct datetime for any file system operations
  // (i.e. saving a new audio recording onto the SD card)
  FsDateTime::setCallback(dateTime);
  mode = Mode::Ready;
  // First, read the buttons
  buttonRecord.update();
  buttonPlay.update();
  switch(mode){
    case Mode::Ready:
      // Rising edge occurs when the handset is lifted
      if (buttonRecord.risingEdge()) {
        Serial.println("Handset lifted");
        mode = Mode::Prompting;
      else if(buttonPlay.fallingEdge()) {
        playAllRecordings();
    case Mode::Prompting:
             // Wait a second for users to put the handset to their ear.   RAM
             // Added to read hook pin to check if handset has been replaced before proceeding.  RAM
      x=0;   // Clear counter.
      while (x < 30)  {
        wait(50);   // Wait 50 mS.
        x=x+1;      // Increment counter
        Serial.println(x);  // Print counter value
        hookRead=digitalRead(HOOK_PIN);  // Check if handset replaced.
          if (hookRead==0)  {
          Serial.println("Handset Replaced Before Message");
          mode = Mode::Ready;  // Return to ready mode if hang up.
          return;
      // Play the greeting inviting them to record their message
      playRaw1.play("greeting.raw");    //  Changed from default (.wav) to (.raw) format.  Greeting MUST be recorded in .raw format.   RAM
      // Wait until the  message has finished playing
      while (playRaw1.isPlaying()) {
        // Check whether the handset is replaced
        // Handset is replaced
        if(buttonRecord.fallingEdge()) {
          playRaw1.stop();
          mode = Mode::Ready;
          return;
      // Debug message
      Serial.println("Starting Recording");
      // Play the tone sound effect
      wait(250);
      // Start the recording function
      startRecording();
    case Mode::Recording:
      if(buttonRecord.fallingEdge()){
        // Debug log
        Serial.println("Stopping Recording");
        // Stop recording
        stopRecording();
        // Play audio tone to confirm recording has ended
        waveform1.frequency(523.25);
        wait(50);
        wait(50);
        wait(50);
      else {
        continueRecording();
    case Mode::Playing:
void startRecording() {
  // Find the first available file number
  for (uint8_t i=0; i<9999; i++) {
    // Format the counter as a five-digit number with leading zeroes, followed by file extension
    snprintf(filename, 11, " %05d.RAW", i);
    // Create if does not exist, do not open existing, write, sync after write
    if (!SD.exists(filename)) {
  frec = SD.open(filename, FILE_WRITE);
  if(frec) {
    Serial.print("Recording to ");
    Serial.println(filename);
    queue1.begin();
    mode = Mode::Recording;
  else {
    Serial.println("Couldn't open file to record!");
void continueRecording() {
  // Check if there is data in the queue
  if (queue1.available() >= 2) {
    byte buffer[512];
    // into a 512 byte buffer.  The Arduino SD library
    // writes are used.
    memcpy(buffer, queue1.readBuffer(), 256);
    queue1.freeBuffer();
    memcpy(buffer+256, queue1.readBuffer(), 256);
    // Write all 512 bytes to the SD card
    frec.write(buffer, 512);
void stopRecording() {
  // Stop adding any new data to the queue
  queue1.end();
  // Flush all existing remaining data from the queue
    // Save to open file
    frec.write((byte*)queue1.readBuffer(), 256);
  // Close the file
  frec.close();
  mode = Mode::Ready;
void playAllRecordings() {
  // Recording files are saved in the root directory
  File dir = SD.open("/");
  while (true) {
    File entry =  dir.openNextFile();
    if (!entry) {
      // no more files
      entry.close();
    int8_t len = strlen(entry.name());
      Serial.print("Now playing ");
      Serial.println(entry.name());
      // Play a short beep before each message
      waveform1.amplitude(0.5);
      wait(250);
      // Play the file
      playRaw1.play(entry.name());
      mode = Mode::Playing;
    entry.close();
      // Button is pressed again
      if(buttonPlay.risingEdge() || buttonRecord.fallingEdge()) {
        playRaw1.stop();
        mode = Mode::Ready;
        return;
  // All files have been played
  mode = Mode::Ready;
// Retrieve the current time from Teensy built-in RTC
time_t getTeensy3Time(){
  return Teensy3Clock.get();
// Callback to assign timestamps for file system operations
void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
  // Return date using FS_DATE macro to format fields.
  *date = FS_DATE(year(), month(), day());
  // Return time using FS_TIME macro to format fields.
  *time = FS_TIME(hour(), minute(), second());
  // Return low time bits in units of 10 ms.
  *ms10 = second() & 1 ? 100 : 0;
// Non-blocking delay, which pauses execution of main program logic,
// but while still listening for input
void wait(unsigned int milliseconds) {
  elapsedMillis msec=0;
  while (msec <= milliseconds) {
    if (buttonRecord.fallingEdge()) Serial.println("Button (pin 0) Press");
    if (buttonPlay.fallingEdge()) Serial.println("Button (pin 1) Press");
    if (buttonRecord.risingEdge()) Serial.println("Button (pin 0) Release");
    if (buttonPlay.risingEdge()) Serial.println("Button (pin 1) Release");
}void setup() {
}void setup() {
 * These can be loaded directly into Audacity (https://www.audacityteam.org/). Or else, converted to WAV/MP3 format using SOX (https://sourceforge.net/projects/sox/)
 // INCLUDES
#include <Bounce.h>
// DEFINES
#define HOOK_PIN 0
int     x;
// GLOBALS
// Audio initialisation code can be generated using the GUI interface at https://www.pjrc.com/teensy/gui/
// Inputs
// Outputs
// Connections
char filename[15];
File frec;
enum Mode { Initialising, Ready, Prompting, Recording, Playing };
    // See https://www.pjrc.com/teensy/td_serial.html
    // Serial.begin()
    AudioMemory(60);
    wait(250);
        while (1) {
    // See https://github.com/PaulStoffregen/Time
    mode = Mode::Ready;
    switch (mode) {
    case Mode::Ready:
        else if (buttonPlay.fallingEdge()) {
        x = 0;   // Clear counter.
        while (x < 30) {
            x = x + 1;      // Increment counter
            hookRead = digitalRead(HOOK_PIN);  // Check if handset replaced.
            if (hookRead == 0) {
                return;
            if (buttonRecord.fallingEdge()) {
                playRaw1.stop();
                mode = Mode::Ready;
                return;
        // Debug message
        wait(250);
        startRecording();
            // Debug log
            // Stop recording
            stopRecording();
            wait(50);
            wait(50);
            wait(50);
        else {
    case Mode::Playing:
    for (uint8_t i = 0; i < 9999; i++) {
    if (frec) {
        queue1.begin();
    else {
        byte buffer[512];
        // writes are used.
        memcpy(buffer + 256, queue1.readBuffer(), 256);
    queue1.end();
    // Close the file
    frec.close();
    mode = Mode::Ready;
    while (true) {
        if (!entry) {
            // no more files
            entry.close();
            wait(250);
            // Play the file
        entry.close();
            if (buttonPlay.risingEdge() || buttonRecord.fallingEdge()) {
                playRaw1.stop();
                mode = Mode::Ready;
                return;
    mode = Mode::Ready;
time_t getTeensy3Time() {
    elapsedMillis msec = 0;
}void setup() {
}void setup() {
When posting code please enclose it between CODE tags using the # button at the top of the entry form.
It makes the code much easier to read, understand and therefore de-bug.
Your problem is that you have more than one occurrences of void setup and void loop (See the end of the code you have posted here). In fact you have three of each.
Looks like you have been copy and pasting your code.
Delete this.....
}void setup() {
... from the end of your program.
done that got this now
Audio_2: In function 'void loop()':
Audio_2:148: warning: enumeration value 'Initialising' not handled in switch
switch(mode){
Audio_2: In function 'void playAllRecordings()':
C:\Users\iandi\Documents\Arduino\Audio_GuestBook1\Audio_2\Audio_2.ino:304:36: warning: invalid conversion from 'const char*' to 'char*' [-fpermissive]
from C:\Users\iandi\AppData\Local\Temp\arduino_build_598846\pch\Arduino.h:6:
Audio_2: In function 'void wait(unsigned int)':
Audio_2:362: error: expected '}' at end of input
Please remember, we can't see your screen. Showing us the error messages is good, but not enough. We also need to see the code that was in the Arduino window.
When posting the code, in Arduino type CTRL-A to select all and CTRL-C to copy to clipboard. Then here on the forum, click the # button in the forum's editor toolbar (it's the last one, on the right hand side). You'll see the code tags appear, with the cursor positioned between them. Press CTRL-V to paste all the code, between those special tags. Doing it that way makes it easier for us to see it properly and better help figure out what's really wrong.
It's ok, we can help you, but we need to see what you've done.
// INCLUDES
#include <Bounce.h>
// DEFINES
#define HOOK_PIN 0
int     x;
// GLOBALS
// Inputs
// Outputs
// Connections
char filename[15];
File frec;
  // Serial.begin()
  AudioMemory(60);
  wait(250);
    while (1) {
  mode = Mode::Ready;
  switch(mode){
    case Mode::Ready:
      while (x < 30)  {
          if (hookRead==0)  {
          return;
          playRaw1.stop();
          mode = Mode::Ready;
          return;
      // Debug message
      wait(250);
      startRecording();
        // Debug log
        // Stop recording
        stopRecording();
        wait(50);
        wait(50);
        wait(50);
      else {
    case Mode::Playing:
  if(frec) {
    queue1.begin();
  else {
    byte buffer[512];
    // writes are used.
  queue1.end();
  // Close the file
  frec.close();
  mode = Mode::Ready;
  while (true) {
    if (!entry) {
      // no more files
      entry.close();
      wait(250);
      // Play the file
    entry.close();
        playRaw1.stop();
        mode = Mode::Ready;
        return;
  mode = Mode::Ready;
Looks like you accidentally deleted the last part of the program, while trying to get rid of the extra junk that was at the end.
Recommend finding the original code again. Probably best to just open a new Arduino window. Delete the template stuff Arduino automatically puts into every new window (this is probably where things went wrong last time), so you have a completely blank window. Then carefully select all of the code. Before pressing CTRL-C to copy to clipboard, visually double check to make sure you got it all selected and you did not accidentally select any extra stuff.
// INCLUDES
#include <Bounce.h>
// DEFINES
#define HOOK_PIN 0
int     x;
// GLOBALS
// Inputs
// Outputs
// Connections
char filename[15];
File frec;
  // Serial.begin()
  AudioMemory(60);
  wait(250);
    while (1) {
  mode = Mode::Ready;
  switch(mode){
    case Mode::Ready:
      while (x < 30)  {
          if (hookRead==0)  {
          return;
          playRaw1.stop();
          mode = Mode::Ready;
          return;
      // Debug message
      wait(250);
      startRecording();
        // Debug log
        // Stop recording
        stopRecording();
        wait(50);
        wait(50);
        wait(50);
      else {
    case Mode::Playing:
  if(frec) {
    queue1.begin();
  else {
    byte buffer[512];
    // writes are used.
  queue1.end();
  // Close the file
  frec.close();
  mode = Mode::Ready;
  while (true) {
    if (!entry) {
      // no more files
      entry.close();
      wait(250);
      // Play the file
    entry.close();
        playRaw1.stop();
        mode = Mode::Ready;
        return;
  mode = Mode::Ready;
Quit out of the Arduino IDE.
Go into your Documents folder, then into Arduino (Documents\Arduino) and delete all Audio Guestbook entries.
Go to https://github.com/playfultechnology/audio-guestbook and download the Audio-Guestbook code by clicking on the green button labelled <> Code.
Click on Download ZIP
Navigate to your "Downloads" folder. Open the audio-guestbook-main.zip zip folder by double clicking on it.
Right click on audio-guestbook-main and select copy.
Navigate to your Documents folder then to the Arduino folder as above.
Right click on some "white Space" and select paste.
You will now have a NEW CLEAN version of the audio guestbook.
Start up the Arduino IDE.
Select File..audio-guestbook-main...and open the audio-guestbook by double clicking on audio-guestbook.ino.
Same problem as msg #9, the last essential part of the program was deleted by mistake.
Hopefully this picture can make it clearer?
Please find the original code. Scroll to the end of the Arduino window and carefully compare it. Even if none of the code makes any sense, you can hopefully see whether you got it all properly copied.
arduino ide dont see my board
now getting this message with fresh install
Arduino: 1.8.19 (Windows 10), TD: 1.57-beta1, Board: "Teensy 4.0, Serial, 600 MHz, Faster, United Kingdom"
C:\Users\iandi\Documents\Arduino\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:30:24: fatal error: MTP_Teensy.h: No such file or directory
I think you have things in the wrong directories.
Copy all the contents
of C:\Users\iandi\Documents\Arduino\audio-guestbook-main\audio-guestbook\
to C:\Users\iandi\Documents\Arduino\audio-guestbook-main\
Then delete the directory C:\Users\iandi\Documents\Arduino\audio-guestbook-main\audio-guestbook\ and all its contents.
No. "Error compiling" means Arduino IDE could not use the files on your PC.
It didn't even try to talk to Teensy, because the code on your PC is not correct. This is the way the Arduino software works. It compiles first and only tries to upload if the compile is successful.
To check if Teensy is working with your PC, in Arduino click File > Examples > 01.Basics > Blink. This will open a new window with the very simple LED blink program. Click Upload. After compiling, the small Teensy Loader window should appear, and you should see it do the code loading. Usually takes about 2 seconds, so it's easy to miss if you're not looking.
During uploads, the red LED near the USB connector should turn on.
Try editing the code to change the delays from 1000 to only 100. Before uploading, look at the orange LED and get a visual idea of the blinking speed. Then upload with the reduced delay. When the new program is running, you should see a much faster blinking speed.
And back to the errors, try just typing a random word somewhere in the code. When you attempt to upload, you'll see an error message. You'll see it doesn't even try to talk to Teensy to attempt upload if there is "Error compiling".
done changes and it does slow down and speed up but still no sd card reading ?????
nope still not compiling
Arduino: 1.8.19 (Windows 10), TD: 1.57, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
Then what do you mean by the above statement?
Are you running some other software to read the SD card?
