Results 1 to 6 of 6
Thread: Detecting Axles using a Teensy 4.1
    Jun 2017
    241
    I would appreciate advice on creating an axle sensor using a Teensy 4.1 connected to a sensor.
    Basically, I need to detect when a wheel of a vehicle rolls over a thin/narrow aluminum strip which is glued to the roadway and placed perpendicular to the direction of traffic. The system needs to detect when a wheel rolls over the strip. Wheels may roll over the strip every 100 ms.
    I thought of a simple Piezo sensor but the ones I found would be easily destroyed by the wheels. I also tried the Adafruit 9-DOF Orientation IMU sensor but I could not get it to work.
    What is the right sensor to use and a good circuit to connect to the Teensy?
    Thanks in advance.
    1,912
    You could try something like the sensor strips that cities put on roads to measure the volume of traffic. I presume what they do is the weight of the wheel momentarily closes a circuit consisting of two wires in what amounts to a rubber hose. If that can be done it's a simple matter of hooking it up to a digital pin and "the rest is just software" (tm)
    Pete
    Jun 2017
    241
    Thank you. Yes, those are called axle sensors. They are expensive and require embedding in the asphalt.
    I need something simpler ….
    Cheltenham, UK
    1,242
    The systems used in the UK for temporary speed measurement consist of a rubber tube with one end (the far end) closed and I assume a pressure sensor on the sensing end measuring pressure pulses. Each positive pulse is a wheel travelling over the sensor.
    Jun 2017
    241
    Quote Originally Posted by BriComp View Post
    Thank you @BriComp.
    Yes, we sue that in the US too but it is bulky, cumbersome and is only for a temporary installation.
    Cordoba, Argentina
    120
    Jimmie:
    Why not use a small laser and a sensor at the other end?
    or,
    You could try two thin strips of aluminum foil very close to each other on a non conductive layer perhaps made of Capton or something like it. You could use perhaps a capacitive touch circuit, or a resistive touch circuit to detect the pulses.
    Regards,
    Ed
