void AudioOutputI2S::config_i2s(bool only_bclk)
CCM_CCGR5 |= CCM_CCGR5_SAI1(CCM_CCGR_ON);
// if either transmitter or receiver is enabled, do nothing
if ((I2S1_TCSR & I2S_TCSR_TE) != 0 || (I2S1_RCSR & I2S_RCSR_RE) != 0)
if (!only_bclk) // if previous transmitter/receiver only activated BCLK, activate the other clock pins now
CORE_PIN23_CONFIG = 3; //1:MCLK
CORE_PIN20_CONFIG = 3; //1:RX_SYNC (LRCLK)
return ;
//PLL:
int fs = 96000 + 202;
int oversampling = 256;
int clk = 24000000;
// PLL between 27*24 = 648MHz und 54*24=1296MHz
int n1 = 4; //SAI prescaler 4 => (n1*n2) = multiple of 4
int n2 = 1 + (clk * 27) / (fs * oversampling * n1);
double C = ((double)fs * oversampling * n1 * n2) / clk;
int c0 = C; //28
int c2 = 10000;
int c1 = C * c2 - (c0 * c2);
set_audioClock(c0, c1, c2); //set_audioClock(int nfact, int32_t nmult, uint32_t ndiv, bool force)
// clear SAI1_CLK register locations
CCM_CSCMR1 = (CCM_CSCMR1 & ~(CCM_CSCMR1_SAI1_CLK_SEL_MASK))
| CCM_CSCMR1_SAI1_CLK_SEL(2); // &0x03 // (0,1,2): PLL3PFD0, PLL5, PLL4
CCM_CS1CDR = (CCM_CS1CDR & ~(CCM_CS1CDR_SAI1_CLK_PRED_MASK | CCM_CS1CDR_SAI1_CLK_PODF_MASK))
| CCM_CS1CDR_SAI1_CLK_PRED(n1-1) // &0x07
| CCM_CS1CDR_SAI1_CLK_PODF(n2-1); // &0x3f
// Select MCLK
IOMUXC_GPR_GPR1 = (IOMUXC_GPR_GPR1
& ~(IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL_MASK))
| (IOMUXC_GPR_GPR1_SAI1_MCLK_DIR | IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL(0));
if (!only_bclk)
CORE_PIN21_CONFIG = 3; //1:RX_BCLK
int rsync = 0;
int tsync = 1;
I2S1_TMR = 0;
//I2S1_TCSR = (1<<25); //Reset
I2S1_TCR1 = I2S_TCR1_RFW(1);
I2S1_TCR2 = I2S_TCR2_SYNC(tsync) | I2S_TCR2_BCP // sync=0; tx is async;
| (I2S_TCR2_BCD | I2S_TCR2_DIV((1)) | I2S_TCR2_MSEL(1));
I2S1_TCR3 = I2S_TCR3_TCE;
I2S1_TCR4 = I2S_TCR4_FRSZ((2-1)) | I2S_TCR4_SYWD((32-1)) | I2S_TCR4_MF
| I2S_TCR4_FSD | I2S_TCR4_FSE | I2S_TCR4_FSP;
I2S1_TCR5 = I2S_TCR5_WNW((32-1)) | I2S_TCR5_W0W((32-1)) | I2S_TCR5_FBT((32-1));
I2S1_RMR = 0;
//I2S1_RCSR = (1<<25); //Reset
I2S1_RCR1 = I2S_RCR1_RFW(1);
I2S1_RCR2 = I2S_RCR2_SYNC(rsync) | I2S_RCR2_BCP // sync=0; rx is async;
| (I2S_RCR2_BCD | I2S_RCR2_DIV((1)) | I2S_RCR2_MSEL(1));
I2S1_RCR3 = I2S_RCR3_RCE;
I2S1_RCR4 = I2S_RCR4_FRSZ((2-1)) | I2S_RCR4_SYWD((32-1)) | I2S_RCR4_MF
| I2S_RCR4_FSE | I2S_RCR4_FSP | I2S_RCR4_FSD;
I2S1_RCR5 = I2S_RCR5_WNW((32-1)) | I2S_RCR5_W0W((32-1)) | I2S_RCR5_FBT((32-1));
