// Teensy-Synth Part 3
// Keyboard Test
// By Notes and Volts
// www.notesandvolts.com
AudioSynthWaveform waveform2; //xy=405.00000762939453,377.5000057220459
AudioSynthWaveform waveform1; //xy=409.00000762939453,318.0000057220459
AudioSynthNoisePink pink1; //xy=417.50000762939453,428.7500066757202
AudioMixer4 mixer1; //xy=600.0000114440918,378.75000381469727
AudioOutputI2S i2s1; //xy=747,377
AudioConnection patchCord1(waveform2, 0, mixer1, 1);
AudioConnection patchCord2(waveform1, 0, mixer1, 0);
AudioConnection patchCord3(pink1, 0, mixer1, 2);
AudioConnection patchCord4(mixer1, 0, i2s1, 0);
AudioConnection patchCord5(mixer1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=588,480
// GLOBAL VARIABLES
const byte BUFFER = 8; //Size of keyboard buffer
const float noteFreqs[128] = {8.176, 8.662, 9.177, 9.723, 10.301, 10.913, 11.562, 12.25, 12.978, 13.75, 14.568, 15.434, 16.352, 17.324, 18.354, 19.445, 20.602, 21.827, 23.125, 24.5, 25.957, 27.5, 29.135, 30.868, 32.703, 34.648, 36.708, 38.891, 41.203, 43.654, 46.249, 48.999, 51.913, 55, 58.27, 61.735, 65.406, 69.296, 73.416, 77.782, 82.407, 87.307, 92.499, 97.999, 103.826, 110, 116.541, 123.471, 130.813, 138.591, 146.832, 155.563, 164.814, 174.614, 184.997, 195.998, 207.652, 220, 233.082, 246.942, 261.626, 277.183, 293.665, 311.127, 329.628, 349.228, 369.994, 391.995, 415.305, 440, 466.164, 493.883, 523.251, 554.365, 587.33, 622.254, 659.255, 698.456, 739.989, 783.991, 830.609, 880, 932.328, 987.767, 1046.502, 1108.731, 1174.659, 1244.508, 1318.51, 1396.913, 1479.978, 1567.982, 1661.219, 1760, 1864.655, 1975.533, 2093.005, 2217.461, 2349.318, 2489.016, 2637.02, 2793.826, 2959.955, 3135.963, 3322.438, 3520, 3729.31, 3951.066, 4186.009, 4434.922, 4698.636, 4978.032, 5274.041, 5587.652, 5919.911, 6271.927, 6644.875, 7040, 7458.62, 7902.133, 8372.018, 8869.844, 9397.273, 9956.063, 10548.08, 11175.3, 11839.82, 12543.85};
byte globalNote = 0;
byte globalVelocity = 0;
int octave = 0;
const float DIV127 = (1.0 / 127.0);
AudioMemory(80);
usbMIDI.setHandleControlChange(myControlChange);
usbMIDI.setHandleNoteOff(myNoteOff);
usbMIDI.setHandleNoteOn(myNoteOn);
sgtl5000_1.enable();
sgtl5000_1.volume(0.32);
waveform1.begin(WAVEFORM_SAWTOOTH);
waveform1.amplitude(0.75);
waveform1.frequency(82.41);
waveform1.pulseWidth(0.15);
waveform2.begin(WAVEFORM_SAWTOOTH);
waveform2.amplitude(0.75);
waveform2.frequency(123);
waveform2.pulseWidth(0.15);
pink1.amplitude(1.0);
mixer1.gain(0, 1.0);
mixer1.gain(1, 1.0);
mixer1.gain(2, 1.0);
usbMIDI.read();
void myNoteOn(byte channel, byte note, byte velocity) {
if ( note > 23 && note < 108 ) {
globalNote = note;
globalVelocity = velocity;
keyBuff(note, true);
void myNoteOff(byte channel, byte note, byte velocity) {
keyBuff(note, false);
void keyBuff(byte note, bool playNote) {
static byte buff[BUFFER];
static byte buffSize = 0;
// Add Note
if (playNote == true && (buffSize < BUFFER) ) {
oscPlay(note);
buff[buffSize] = note;
buffSize++;
return;
// Remove Note
else if (playNote == false && buffSize != 0) {
for (byte found = 0; found < buffSize; found++) {
if (buff[found] == note) {
for (byte gap = found; gap < (buffSize - 1); gap++) {
buff[gap] = buff[gap + 1];
buffSize--;
buff[buffSize] = 255;
if (buffSize != 0) {
oscPlay(buff[buffSize - 1]);
return;
else {
oscStop();
return;
void oscPlay(byte note) {
waveform1.frequency(noteFreqs[note]);
waveform2.frequency(noteFreqs[note + octave]);
float velo = (globalVelocity * DIV127);
waveform1.amplitude(velo);
waveform2.amplitude(velo);
pink1.amplitude(velo);
void oscStop() {
waveform1.amplitude(0.0);
waveform2.amplitude(0.0);
pink1.amplitude(0.0);
void myControlChange(byte channel, byte control, byte value) {
switch (control) {
case 100:
mixer1.gain(0, (value * DIV127));
case 101:
mixer1.gain(1, (value * DIV127));
case 102:
mixer1.gain(2, (value * DIV127));
case 103:
switch (value) {
case 0:
octave = 24;
case 1:
octave = 12;
case 2:
octave = 0;
case 3:
octave = -12;
case 4:
octave = -24;
