dyanchandrasekar
New member
I am using Teensy LC to send data (continuous sensor values) to raspberry pi 4 through serial communication, I'm using the raspberry pi only to run a GUI, that displays graph from Teensy. I'm using pyserial in rpi to read from Teensy.
But each time I start/restart the raspberry pi I also have to restart the Teensy LC to establish the serial connection and the data transfer. (Teensy is powered through rpi USB)
I suspect this might be due to the differences in the booting speeds of teensy LC and raspberry pi4. Is there any way to solve this issue without having to restart Teensy every time?
Thank you
Thank you
