Audio Issue [conflict I2C/I2S]
PierreBanwarth
New member
HI all,
I'm switching from mozzi to the teensy audio library.
I'm on a polyphonic synth with an accordion keyboard.
I got a Teensy 4.1
My project goal is to scan 36 Cherry Mx Keys connected to two pcf8575 playing synth
I'm using an external chip to get sound it's a MAX98357A DAC/Amp.
I know that the basic sound is working (drum example in the audio library git)
My i2cs are ok i can detect switch changes. the 2 PCF are plugged on Wire1 (0x22 0x20)
I have a test switch plugged to the teensy.
When i use the same code while removing all PCF.read i got a clear sound.
Same thing with to different PCF library ( https://registry.platformio.org/libraries/robtillaart/PCF8575 and https://github.com/adafruit/Adafruit_PCF8574)
Sound got better when i add some delays in the main loop. But i can't get clear sound and reactive keyboard.
I come there to see if someone got that shit work before ?
And how to clean this out.
Maybe a non_blocking i2c lib ? Oveclocking teensy ? Changing i2C rate ?
i'm looking into try same code but with Mozzi, but i think it'll be the same..
Here is my code
https://github.com/PierreBanwarth/MIDI-Accordina
thanks a lot
/////////// EDIT ////////////
My keyboard is working and the dac too, making a clear sin sound but with a clicky and loud noise (that i havent without if i remove PCF reading in the code.
When i play with delay, clicky noise frequency decrease.
To answer this specific question, the Monolith Synth project uses several I2C-based I/O expanders to read over 40 arcade-style pushbuttons and also control their LEDs.
https://www.pjrc.com/monolith-synth/
Many other projects have used I2C while playing audio.
From the tone of your question, I'm getting the impression you believe I2C communication disrupts the audio. But that is certainly not the case. I can't say what's going wrong, but I'm pretty confident it's not I2C.
If it were me I would use a SX1509.
It has a built in keyboard scanner for up to 64 keys.
It will scan the kbd and return the keys(s) pressed.
You just have to scan an interrupt line to determine a key has been pressed then read the I2C to determine the key.
Uses up much more processor time.
In your case you would use 12 I/O lines for the kbd scan and still have 4 left for other things.
Ok so maybe i'm missing something, but it's sound good anytime i replace the pcf.read() by return 1;
Maybe i have electrical interference issues..
[COLOR=#D4D4D4][FONT=Consolas][COLOR=#6a9955]// Created: 2021-03-01 15:00:00[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"concertina_lib/concertina.h"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"concertina_lib/display.hpp"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"concertina_lib/display.cpp"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"concertina_lib/configuration.h"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"concertina_lib/configuration.cpp"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"concertina_lib/keyboard.hpp"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"concertina_lib/keyboard.cpp"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"concertina_lib/musicMath.h"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<PCF8575.h>[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<stdlib.h>[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<Arduino.h>[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<MIDI.h>[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<Wire.h>[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"SSD1306Ascii.h"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"SSD1306AsciiWire.h"[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]"RotaryEncoder.h"[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#6a9955]// RotaryEncoder v1.5.0 library by Matthais Hertel[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<math.h>[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#6a9955]//<cmath> in case of c++[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<Audio.h>[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<SPI.h>[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<SD.h>[/COLOR]
[COLOR=#c586c0]#include[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#ce9178]<SerialFlash.h>[/COLOR]
[COLOR=#6a9955]// GUItool: begin automatically generated code[/COLOR]
[COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]waveformPitch[/COLOR][[COLOR=#b5cea8]16[/COLOR]][[COLOR=#b5cea8]8[/COLOR]] = {
{[COLOR=#b5cea8]255[/COLOR], [COLOR=#b5cea8]255[/COLOR], [COLOR=#b5cea8]255[/COLOR], [COLOR=#b5cea8]255[/COLOR], [COLOR=#b5cea8]255[/COLOR], [COLOR=#b5cea8]255[/COLOR], [COLOR=#b5cea8]255[/COLOR], [COLOR=#b5cea8]255[/COLOR]},[COLOR=#6a9955]   // Default to 255 as an "unused" indicator as it's outside the range of pitch values 0-127[/COLOR]
[COLOR=#6a9955]// Teensy Audio library configuration (visualizer: https://www.pjrc.com/teensy/gui/index.html)[/COLOR]
[COLOR=#6a9955]// 128 waveforms to 128 envelopes (8 note polyphony per channel x 16) routed to 32 mixers to 8 mixers to 2 mixers to 1 mixer to audio out (MQS)[/COLOR]
[COLOR=#4ec9b0]AudioSynthWaveform[/COLOR]      [COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]16[/COLOR]][[COLOR=#b5cea8]8[/COLOR]];
[COLOR=#4ec9b0]AudioEffectEnvelope[/COLOR]     [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]16[/COLOR]][[COLOR=#b5cea8]8[/COLOR]];
[COLOR=#4ec9b0]AudioMixer4[/COLOR]             [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]32[/COLOR]];
[COLOR=#4ec9b0]AudioMixer4[/COLOR]             [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]8[/COLOR]];
[COLOR=#4ec9b0]AudioMixer4[/COLOR]             [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]];
[COLOR=#4ec9b0]AudioMixer4[/COLOR]             [COLOR=#9cdcfe]outMixer[/COLOR];
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15WaveformToEnvelope0[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15WaveformToEnvelope1[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15WaveformToEnvelope2[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15WaveformToEnvelope3[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15WaveformToEnvelope4[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15WaveformToEnvelope5[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15WaveformToEnvelope6[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15WaveformToEnvelope7[/COLOR]([COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch00envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]0[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch01envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]1[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch02envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]2[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch03envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]3[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]8[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]8[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]8[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]8[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]9[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]9[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]9[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch04envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]4[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]9[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]10[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]10[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]10[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]10[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]11[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]11[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]11[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch05envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]5[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]11[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]12[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]12[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]12[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]12[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]13[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]13[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]13[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch06envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]6[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]13[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]14[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]14[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]14[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]14[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]15[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]15[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]15[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch07envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]7[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]15[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]16[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]16[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]16[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]16[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]17[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]17[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]17[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch08envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]8[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]17[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]18[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]18[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]18[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]18[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]19[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]19[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]19[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch09envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]9[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]19[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]20[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]20[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]20[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]20[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]21[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]21[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]21[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch10envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]10[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]21[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]22[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]22[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]22[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]22[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]23[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]23[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]23[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch11envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]11[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]23[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]24[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]24[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]24[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]24[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]25[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]25[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]25[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch12envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]12[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]25[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]26[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]26[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]26[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]26[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]27[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]27[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]27[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch13envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]13[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]27[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]28[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]28[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]28[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]28[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]29[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]29[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]29[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch14envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]14[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]29[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15envelopeToMixer0[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]30[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15envelopeToMixer1[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]30[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15envelopeToMixer2[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]30[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15envelopeToMixer3[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]30[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15envelopeToMixer4[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]31[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15envelopeToMixer5[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]31[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15envelopeToMixer6[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]31[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]ch15envelopeToMixer7[/COLOR]([COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#b5cea8]15[/COLOR]][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]31[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer00[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer01[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer02[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer03[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer04[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer05[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer06[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer07[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer08[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]8[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer09[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]9[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer10[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]10[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer11[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]11[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer12[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]12[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer13[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]13[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer14[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]14[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer15[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]15[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer16[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]16[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer17[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]17[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer18[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]18[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer19[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]19[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer20[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]20[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer21[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]21[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer22[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]22[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer23[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]23[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer24[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]24[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer25[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]25[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer26[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]26[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer27[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]27[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer28[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]28[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer29[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]29[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer30[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]30[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]firstMixerToSecondMixer31[/COLOR]([COLOR=#9cdcfe]firstMixer[/COLOR][[COLOR=#b5cea8]31[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]secondMixerToThirdMixer0[/COLOR]([COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]secondMixerToThirdMixer1[/COLOR]([COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]secondMixerToThirdMixer2[/COLOR]([COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]2[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]secondMixerToThirdMixer3[/COLOR]([COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]3[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]secondMixerToThirdMixer4[/COLOR]([COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]4[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]secondMixerToThirdMixer5[/COLOR]([COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]5[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]secondMixerToThirdMixer6[/COLOR]([COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]6[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]2[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]secondMixerToThirdMixer7[/COLOR]([COLOR=#9cdcfe]secondMixer[/COLOR][[COLOR=#b5cea8]7[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]3[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]thirdMixerToOutMixer0[/COLOR]([COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]0[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]outMixer[/COLOR], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]         [COLOR=#9cdcfe]thirdMixerToOutMixer1[/COLOR]([COLOR=#9cdcfe]thirdMixer[/COLOR][[COLOR=#b5cea8]1[/COLOR]], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]outMixer[/COLOR], [COLOR=#b5cea8]1[/COLOR]);
[COLOR=#4ec9b0]AudioAmplifier[/COLOR]    [COLOR=#9cdcfe]amp1[/COLOR];[COLOR=#6a9955]   //xy=324,172[/COLOR]
[COLOR=#4ec9b0]AudioOutputI2S[/COLOR]    [COLOR=#9cdcfe]i2s1[/COLOR];[COLOR=#6a9955]   //xy=538,168[/COLOR]
[COLOR=#4ec9b0]AudioConnection[/COLOR]   [COLOR=#9cdcfe]patchCord1[/COLOR] ([COLOR=#9cdcfe]outMixer[/COLOR], [COLOR=#9cdcfe]amp1[/COLOR]);
[COLOR=#4ec9b0]AudioConnection[/COLOR]   [COLOR=#9cdcfe]patchCord2[/COLOR] ([COLOR=#9cdcfe]amp1[/COLOR], [COLOR=#b5cea8]0[/COLOR], [COLOR=#9cdcfe]i2s1[/COLOR], [COLOR=#b5cea8]0[/COLOR]);
[COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]waveform_type[/COLOR] = [COLOR=#569cd6]WAVEFORM_SAWTOOTH[/COLOR];
[COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]mixer1_setting[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]mixer2_setting[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#4ec9b0]elapsedMillis[/COLOR] [COLOR=#9cdcfe]timeout[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#569cd6]bool[/COLOR] [COLOR=#9cdcfe]mixer2_envelope[/COLOR] = [COLOR=#569cd6]false[/COLOR];
[COLOR=#c586c0]#define[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#569cd6]SOUFFLET_PIN[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#b5cea8]1[/COLOR]
[COLOR=#c586c0]#define[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#569cd6]PRESSED[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#b5cea8]0[/COLOR]
[COLOR=#c586c0]#define[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#569cd6]RELEASED[/COLOR][COLOR=#569cd6] [/COLOR][COLOR=#b5cea8]1[/COLOR]
[COLOR=#6a9955]// declaration of the screen object SSD1306AsciiWire oled on first i2c bus [/COLOR]
[COLOR=#4ec9b0]SSD1306AsciiWire[/COLOR] [COLOR=#9cdcfe]oled[/COLOR];[COLOR=#6a9955] // I2C address 0x3C for 128x64[/COLOR]
[COLOR=#6a9955]// declaration of the PCF8575 objects[/COLOR]
[COLOR=#4ec9b0]PCF8575[/COLOR] [COLOR=#9cdcfe]PCF1[/COLOR]([COLOR=#b5cea8]0x20[/COLOR], &[COLOR=#9cdcfe]Wire1[/COLOR]);
[COLOR=#4ec9b0]PCF8575[/COLOR] [COLOR=#9cdcfe]PCF2[/COLOR]([COLOR=#b5cea8]0x22[/COLOR], &[COLOR=#9cdcfe]Wire1[/COLOR]);
[COLOR=#6a9955]// declaration of the encoder object RotaryEncoder encoder(2, 3);[/COLOR]
[COLOR=#4ec9b0]RotaryEncoder[/COLOR] [COLOR=#9cdcfe]encoder[/COLOR]([COLOR=#b5cea8]14[/COLOR], [COLOR=#b5cea8]15[/COLOR]);
[COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]encoderPosition[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]buttonEncoder[/COLOR] = [COLOR=#b5cea8]8[/COLOR];
[COLOR=#6a9955]// declaration of a display object[/COLOR]
[COLOR=#6a9955]// TODO TEST DISPLAY AND KEYBOARD[/COLOR]
[COLOR=#6a9955]// Display display(&oled, 0x3C, &Wire);[/COLOR]
[COLOR=#6a9955]// Keyboard keyboard(0x20, 0x22, &Wire);[/COLOR]
[COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]topPotPin[/COLOR] = [COLOR=#b5cea8]26[/COLOR];
[COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]bottomPotPin[/COLOR] = [COLOR=#b5cea8]27[/COLOR];
[COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]previousTopPotValue[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]previousBottomPotValue[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#6a9955]// declaration of the button states array[/COLOR]
[COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]buttonStates[/COLOR][[COLOR=#b5cea8]36[/COLOR]];
[COLOR=#6a9955]// add constants for pressed an released buttons[/COLOR]
[COLOR=#569cd6]const[/COLOR] [COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]buttonPressed[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#569cd6]const[/COLOR] [COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]buttonReleased[/COLOR] = [COLOR=#b5cea8]1[/COLOR];
[COLOR=#6a9955]// declare each value of an 36 buttons array[/COLOR]
[COLOR=#6a9955]// values of each pin sorted by rows[/COLOR]
[COLOR=#569cd6]const[/COLOR] [COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]pinMenu[/COLOR][[COLOR=#b5cea8]6[/COLOR]] = {
  [COLOR=#b5cea8]39[/COLOR], [COLOR=#b5cea8]34[/COLOR], [COLOR=#b5cea8]35[/COLOR],
  [COLOR=#b5cea8]36[/COLOR], [COLOR=#b5cea8]37[/COLOR], [COLOR=#b5cea8]38[/COLOR],
[COLOR=#6a9955]// replace 0 by value of the pin and add 32[/COLOR]
[COLOR=#569cd6]const[/COLOR] [COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]pinArrayPCF[/COLOR][[COLOR=#b5cea8]36[/COLOR]] = {
  [COLOR=#b5cea8]4[/COLOR], [COLOR=#b5cea8]0[/COLOR], [COLOR=#b5cea8]0[/COLOR],
  [COLOR=#b5cea8]0[/COLOR], [COLOR=#b5cea8]8[/COLOR], [COLOR=#b5cea8]9[/COLOR],
  [COLOR=#b5cea8]10[/COLOR], [COLOR=#b5cea8]11[/COLOR], [COLOR=#b5cea8]12[/COLOR],
  [COLOR=#b5cea8]13[/COLOR], [COLOR=#b5cea8]14[/COLOR], [COLOR=#b5cea8]15[/COLOR],
  [COLOR=#b5cea8]7[/COLOR], [COLOR=#b5cea8]6[/COLOR], [COLOR=#b5cea8]5[/COLOR],
  [COLOR=#b5cea8]0[/COLOR], [COLOR=#b5cea8]3[/COLOR], [COLOR=#b5cea8]2[/COLOR],
  [COLOR=#b5cea8]1[/COLOR], [COLOR=#b5cea8]55[/COLOR], [COLOR=#b5cea8]16[/COLOR],
  [COLOR=#b5cea8]17[/COLOR], [COLOR=#b5cea8]18[/COLOR], [COLOR=#b5cea8]19[/COLOR],
  [COLOR=#b5cea8]20[/COLOR], [COLOR=#b5cea8]21[/COLOR], [COLOR=#b5cea8]22[/COLOR],
  [COLOR=#b5cea8]31[/COLOR], [COLOR=#b5cea8]23[/COLOR], [COLOR=#b5cea8]30[/COLOR],
  [COLOR=#b5cea8]29[/COLOR], [COLOR=#b5cea8]28[/COLOR], [COLOR=#b5cea8]27[/COLOR],
  [COLOR=#b5cea8]26[/COLOR], [COLOR=#b5cea8]25[/COLOR], [COLOR=#b5cea8]24[/COLOR],
[COLOR=#569cd6]const[/COLOR] [COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]pinArrayClassicPin[/COLOR][[COLOR=#b5cea8]36[/COLOR]] = {
  [COLOR=#b5cea8]5[/COLOR], [COLOR=#b5cea8]6[/COLOR], [COLOR=#b5cea8]2[/COLOR],
  [COLOR=#b5cea8]0[/COLOR], [COLOR=#b5cea8]0[/COLOR], [COLOR=#b5cea8]0[/COLOR],
[COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]indexArrayScan[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#569cd6]void[/COLOR] [COLOR=#dcdcaa]setup[/COLOR](){
[COLOR=#6a9955]  // initialize tab values[/COLOR]
  [COLOR=#c586c0]for[/COLOR]([COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]i[/COLOR] = [COLOR=#b5cea8]0[/COLOR]; [COLOR=#9cdcfe]i[/COLOR] < [COLOR=#b5cea8]36[/COLOR]; [COLOR=#9cdcfe]i[/COLOR]++){
    [COLOR=#9cdcfe]buttonStates[/COLOR][[COLOR=#9cdcfe]i[/COLOR]] = [COLOR=#b5cea8]1[/COLOR];
[COLOR=#6a9955]  // set all pins to input with pull-up[/COLOR]
  [COLOR=#dcdcaa]pinMode[/COLOR]([COLOR=#9cdcfe]buttonEncoder[/COLOR], [COLOR=#569cd6]INPUT[/COLOR]);
  [COLOR=#dcdcaa]digitalWrite[/COLOR]([COLOR=#9cdcfe]buttonEncoder[/COLOR], [COLOR=#569cd6]HIGH[/COLOR]);
[COLOR=#6a9955]  // init pinmod for the keyboard[/COLOR]
  [COLOR=#c586c0]for[/COLOR] ([COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]pin[/COLOR] = [COLOR=#b5cea8]0[/COLOR]; [COLOR=#9cdcfe]pin[/COLOR] < [COLOR=#b5cea8]7[/COLOR]; [COLOR=#9cdcfe]pin[/COLOR]++)
    [COLOR=#dcdcaa]pinMode[/COLOR]([COLOR=#9cdcfe]pin[/COLOR], [COLOR=#569cd6]INPUT_PULLUP[/COLOR]);
    [COLOR=#dcdcaa]digitalWrite[/COLOR]([COLOR=#9cdcfe]pin[/COLOR], [COLOR=#569cd6]HIGH[/COLOR]);
[COLOR=#6a9955]  // init pinmod for the menu keyboard[/COLOR]
  [COLOR=#c586c0]for[/COLOR] ([COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]pin[/COLOR] = [COLOR=#b5cea8]0[/COLOR]; [COLOR=#9cdcfe]pin[/COLOR] < [COLOR=#b5cea8]6[/COLOR]; [COLOR=#9cdcfe]pin[/COLOR]++)
    [COLOR=#dcdcaa]pinMode[/COLOR]([COLOR=#9cdcfe]pinMenu[/COLOR][[COLOR=#9cdcfe]pin[/COLOR]], [COLOR=#569cd6]INPUT_PULLUP[/COLOR]);
    [COLOR=#dcdcaa]digitalWrite[/COLOR]([COLOR=#9cdcfe]pinMenu[/COLOR][[COLOR=#9cdcfe]pin[/COLOR]], [COLOR=#569cd6]HIGH[/COLOR]);
[COLOR=#6a9955]  // init pinmod for the pots[/COLOR]
  [COLOR=#dcdcaa]pinMode[/COLOR]([COLOR=#9cdcfe]topPotPin[/COLOR], [COLOR=#569cd6]INPUT[/COLOR]);
  [COLOR=#dcdcaa]pinMode[/COLOR]([COLOR=#9cdcfe]bottomPotPin[/COLOR], [COLOR=#569cd6]INPUT[/COLOR]);
[COLOR=#6a9955]  // Init I2C connections [/COLOR]
  [COLOR=#9cdcfe]Wire[/COLOR].[COLOR=#dcdcaa]begin[/COLOR]();[COLOR=#6a9955]           // Init I2C for the screen[/COLOR]
  [COLOR=#9cdcfe]Wire1[/COLOR].[COLOR=#dcdcaa]begin[/COLOR]();[COLOR=#6a9955]           // Init I2C for PCF8575 (keyboard)[/COLOR]
[COLOR=#6a9955]  // screen settings init[/COLOR]
[COLOR=#6a9955]  //Wire.setClock(400000L); // Fast mode[/COLOR]
  [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]begin[/COLOR](&[COLOR=#9cdcfe]Adafruit128x64[/COLOR], [COLOR=#b5cea8]0x3C[/COLOR]);
  [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]clear[/COLOR]();
  [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]setFont[/COLOR]([COLOR=#9cdcfe]Adafruit5x7[/COLOR]);
  [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]println[/COLOR]([COLOR=#ce9178]"Accordina MIDI"[/COLOR]);
  [COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]error[/COLOR];
  [COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]found[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#6a9955]  // I2C Address scanner[/COLOR]
  [COLOR=#c586c0]for[/COLOR] ([COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]address[/COLOR] = [COLOR=#b5cea8]1[/COLOR]; [COLOR=#9cdcfe]address[/COLOR] < [COLOR=#b5cea8]127[/COLOR]; [COLOR=#9cdcfe]address[/COLOR]++)
[COLOR=#6a9955]    // The i2c_scanner uses the return value of[/COLOR]
[COLOR=#6a9955]    // the Write.endTransmisstion to see if[/COLOR]
[COLOR=#6a9955]    // a device did acknowledge to the address.[/COLOR]
    [COLOR=#9cdcfe]Wire1[/COLOR].[COLOR=#dcdcaa]beginTransmission[/COLOR]([COLOR=#9cdcfe]address[/COLOR]);
    [COLOR=#9cdcfe]error[/COLOR] = [COLOR=#9cdcfe]Wire1[/COLOR].[COLOR=#dcdcaa]endTransmission[/COLOR]();
    [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]error[/COLOR] == [COLOR=#b5cea8]0[/COLOR])
      [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]print[/COLOR]([COLOR=#ce9178]"Found : "[/COLOR]);
      [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]println[/COLOR]([COLOR=#9cdcfe]address[/COLOR]);
      [COLOR=#c586c0]if[/COLOR]([COLOR=#9cdcfe]found[/COLOR] == [COLOR=#b5cea8]0[/COLOR]){
        [COLOR=#9cdcfe]PCF1[/COLOR].[COLOR=#dcdcaa]setAddress[/COLOR]([COLOR=#9cdcfe]address[/COLOR]);
        [COLOR=#9cdcfe]found[/COLOR]++;
      }[COLOR=#c586c0]else[/COLOR] [COLOR=#c586c0]if[/COLOR]([COLOR=#9cdcfe]found[/COLOR] == [COLOR=#b5cea8]1[/COLOR]){
        [COLOR=#9cdcfe]PCF2[/COLOR].[COLOR=#dcdcaa]setAddress[/COLOR]([COLOR=#9cdcfe]address[/COLOR]);
[COLOR=#6a9955]  // Checking if the PCF8575 are connected[/COLOR]
  [COLOR=#c586c0]if[/COLOR] (![COLOR=#9cdcfe]PCF1[/COLOR].[COLOR=#dcdcaa]begin[/COLOR]())
    [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]println[/COLOR]([COLOR=#ce9178]"could not initialize..."[/COLOR]);
  [COLOR=#c586c0]if[/COLOR] (![COLOR=#9cdcfe]PCF1[/COLOR].[COLOR=#dcdcaa]isConnected[/COLOR]())
    [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]println[/COLOR]([COLOR=#ce9178]"=> not connected"[/COLOR]);
    [COLOR=#9cdcfe]oled[/COLOR].[COLOR=#dcdcaa]println[/COLOR]([COLOR=#ce9178]"=> connected!!"[/COLOR]);
  [COLOR=#c586c0]if[/COLOR] (![COLOR=#9cdcfe]PCF2[/COLOR].[COLOR=#dcdcaa]begin[/COLOR]())
  [COLOR=#c586c0]if[/COLOR] (![COLOR=#9cdcfe]PCF2[/COLOR].[COLOR=#dcdcaa]isConnected[/COLOR]())
[COLOR=#6a9955]  // set the button mask to 0xFFFF to read all buttons[/COLOR]
  [COLOR=#dcdcaa]delay[/COLOR]([COLOR=#b5cea8]2000[/COLOR]);
  [COLOR=#9cdcfe]PCF1[/COLOR].[COLOR=#dcdcaa]setButtonMask[/COLOR]([COLOR=#b5cea8]0xFFFF[/COLOR]);
  [COLOR=#9cdcfe]PCF2[/COLOR].[COLOR=#dcdcaa]setButtonMask[/COLOR]([COLOR=#b5cea8]0xFFFF[/COLOR]);
  [COLOR=#569cd6]AudioMemory[/COLOR]([COLOR=#b5cea8]160[/COLOR]);
  [COLOR=#9cdcfe]amp1[/COLOR].[COLOR=#dcdcaa]gain[/COLOR]([COLOR=#b5cea8]0.1[/COLOR]);
[COLOR=#569cd6]int[/COLOR] [COLOR=#dcdcaa]getButtonState[/COLOR]([COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]index[/COLOR]){
[COLOR=#6a9955]  // if value is 0 in PCF array then classic reading[/COLOR]
  [COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]returnValue[/COLOR] = [COLOR=#b5cea8]1[/COLOR];
  [COLOR=#c586c0]if[/COLOR]([COLOR=#9cdcfe]pinArrayPCF[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] != [COLOR=#b5cea8]0[/COLOR]){
    [COLOR=#c586c0]if[/COLOR]([COLOR=#9cdcfe]pinArrayPCF[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] < [COLOR=#b5cea8]16[/COLOR]){
      [COLOR=#9cdcfe]returnValue[/COLOR] = [COLOR=#9cdcfe]PCF1[/COLOR].[COLOR=#dcdcaa]read16[/COLOR]();
    [COLOR=#c586c0]else[/COLOR] [COLOR=#c586c0]if[/COLOR]([COLOR=#9cdcfe]pinArrayPCF[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] < [COLOR=#b5cea8]32[/COLOR]){
      [COLOR=#9cdcfe]returnValue[/COLOR] = [COLOR=#9cdcfe]PCF2[/COLOR].[COLOR=#dcdcaa]readButton[/COLOR]([COLOR=#9cdcfe]pinArrayPCF[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] - [COLOR=#b5cea8]16[/COLOR]);
    [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]pinArrayPCF[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] == [COLOR=#b5cea8]55[/COLOR])
      [COLOR=#9cdcfe]returnValue[/COLOR] = [COLOR=#9cdcfe]PCF1[/COLOR].[COLOR=#dcdcaa]readButton[/COLOR]([COLOR=#b5cea8]0[/COLOR]);
  [COLOR=#c586c0]else[/COLOR]{
    [COLOR=#9cdcfe]returnValue[/COLOR] = [COLOR=#dcdcaa]digitalRead[/COLOR]([COLOR=#9cdcfe]pinArrayClassicPin[/COLOR][[COLOR=#9cdcfe]index[/COLOR]]);
  [COLOR=#c586c0]return[/COLOR] [COLOR=#9cdcfe]returnValue[/COLOR];
[COLOR=#6a9955]// Mapping function for floats[/COLOR]
[COLOR=#569cd6]float[/COLOR] [COLOR=#dcdcaa]mapFloat[/COLOR]([COLOR=#569cd6]float[/COLOR] [COLOR=#9cdcfe]x[/COLOR], [COLOR=#569cd6]float[/COLOR] [COLOR=#9cdcfe]in_min[/COLOR], [COLOR=#569cd6]float[/COLOR] [COLOR=#9cdcfe]in_max[/COLOR], [COLOR=#569cd6]float[/COLOR] [COLOR=#9cdcfe]out_min[/COLOR], [COLOR=#569cd6]float[/COLOR] [COLOR=#9cdcfe]out_max[/COLOR])
    [COLOR=#c586c0]return[/COLOR] ([COLOR=#9cdcfe]x[/COLOR] - [COLOR=#9cdcfe]in_min[/COLOR]) * ([COLOR=#9cdcfe]out_max[/COLOR] - [COLOR=#9cdcfe]out_min[/COLOR]) / ([COLOR=#9cdcfe]in_max[/COLOR] - [COLOR=#9cdcfe]in_min[/COLOR]) + [COLOR=#9cdcfe]out_min[/COLOR];
[COLOR=#569cd6]void[/COLOR] [COLOR=#dcdcaa]synthNoteOn[/COLOR]([COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]synthChannel[/COLOR], [COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]pitch[/COLOR], [COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]velocity[/COLOR])
  [COLOR=#c586c0]for[/COLOR] ([COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]myWaveform[/COLOR] = [COLOR=#b5cea8]0[/COLOR]; [COLOR=#9cdcfe]myWaveform[/COLOR] < [COLOR=#b5cea8]8[/COLOR]; [COLOR=#9cdcfe]myWaveform[/COLOR]++)
    [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]waveformPitch[/COLOR][[COLOR=#9cdcfe]synthChannel[/COLOR]][[COLOR=#9cdcfe]myWaveform[/COLOR]] == [COLOR=#b5cea8]255[/COLOR])[COLOR=#6a9955]                                        // Find the first available waveform in the 16 waveform array.  255 used as indicator.[/COLOR]
        [COLOR=#9cdcfe]waveformPitch[/COLOR][[COLOR=#9cdcfe]synthChannel[/COLOR]][[COLOR=#9cdcfe]myWaveform[/COLOR]] = [COLOR=#9cdcfe]pitch[/COLOR];
        [COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#9cdcfe]synthChannel[/COLOR]][[COLOR=#9cdcfe]myWaveform[/COLOR]].[COLOR=#dcdcaa]amplitude[/COLOR]([COLOR=#b5cea8]0.1[/COLOR]);
        [COLOR=#9cdcfe]waveformCh[/COLOR][[COLOR=#9cdcfe]synthChannel[/COLOR]][[COLOR=#9cdcfe]myWaveform[/COLOR]].[COLOR=#dcdcaa]frequency[/COLOR]([COLOR=#9cdcfe]midiPitchFrequencyMap[/COLOR][[COLOR=#9cdcfe]pitch[/COLOR]]);
        [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#9cdcfe]synthChannel[/COLOR]][[COLOR=#9cdcfe]myWaveform[/COLOR]].[COLOR=#dcdcaa]noteOn[/COLOR]();
        [COLOR=#c586c0]break[/COLOR];
[COLOR=#569cd6]void[/COLOR] [COLOR=#dcdcaa]synthNoteOff[/COLOR]([COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]synthChannel[/COLOR], [COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]pitch[/COLOR], [COLOR=#4ec9b0]byte[/COLOR] [COLOR=#9cdcfe]velocity[/COLOR])
    [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]waveformPitch[/COLOR][[COLOR=#9cdcfe]synthChannel[/COLOR]][[COLOR=#9cdcfe]myWaveform[/COLOR]] == [COLOR=#9cdcfe]pitch[/COLOR])[COLOR=#6a9955]                                        // Find matching waveform in the 16 waveform array, mark as available and send noteOff[/COLOR]
        [COLOR=#9cdcfe]waveformPitch[/COLOR][[COLOR=#9cdcfe]synthChannel[/COLOR]][[COLOR=#9cdcfe]myWaveform[/COLOR]] = [COLOR=#b5cea8]255[/COLOR];
        [COLOR=#9cdcfe]envelopeCh[/COLOR][[COLOR=#9cdcfe]synthChannel[/COLOR]][[COLOR=#9cdcfe]myWaveform[/COLOR]].[COLOR=#dcdcaa]noteOff[/COLOR]();
[COLOR=#569cd6]void[/COLOR] [COLOR=#dcdcaa]noteOff[/COLOR]([COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]note[/COLOR]){
  [COLOR=#dcdcaa]synthNoteOff[/COLOR]([COLOR=#b5cea8]0[/COLOR],[COLOR=#9cdcfe]note[/COLOR]+[COLOR=#b5cea8]36[/COLOR],[COLOR=#b5cea8]127[/COLOR]);
[COLOR=#569cd6]void[/COLOR] [COLOR=#dcdcaa]noteOn[/COLOR]([COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]note[/COLOR], [COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]index[/COLOR]){
  [COLOR=#dcdcaa]synthNoteOn[/COLOR]([COLOR=#b5cea8]0[/COLOR],[COLOR=#9cdcfe]note[/COLOR]+[COLOR=#b5cea8]36[/COLOR],[COLOR=#b5cea8]127[/COLOR]);
[COLOR=#569cd6]static[/COLOR] [COLOR=#569cd6]void[/COLOR] [COLOR=#dcdcaa]noteMidi[/COLOR]([COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]sens_soufflet[/COLOR], [COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]index[/COLOR], [COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]velocity[/COLOR]){
[COLOR=#6a9955]   //, uint8_t oldStatePousser, uint8_t oldStateTirer[/COLOR]
  [COLOR=#4ec9b0]uint8_t[/COLOR] [COLOR=#9cdcfe]bouton[/COLOR] = [COLOR=#9cdcfe]buttonStates[/COLOR][[COLOR=#9cdcfe]index[/COLOR]];
  [COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]noteSynthPousser[/COLOR] = [COLOR=#9cdcfe]pousser[/COLOR][[COLOR=#9cdcfe]index[/COLOR]];
  [COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]noteSynthTirer[/COLOR] = [COLOR=#9cdcfe]tirer[/COLOR][[COLOR=#9cdcfe]index[/COLOR]];
[COLOR=#6a9955]    // higher velocity usually makes MIDI instruments louder[/COLOR]
    [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]bouton[/COLOR] == [COLOR=#569cd6]BUTTON_PRESSED[/COLOR])
      [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]sens_soufflet[/COLOR] == [COLOR=#569cd6]BUTTON_PRESSED[/COLOR])
[COLOR=#6a9955]        // on pousse sur le bouton et sur le soufflet[/COLOR]
        [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]oldStatePousser[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] == [COLOR=#569cd6]BUTTON_RELEASED[/COLOR])
          [COLOR=#dcdcaa]noteOn[/COLOR]([COLOR=#9cdcfe]noteSynthPousser[/COLOR],[COLOR=#9cdcfe]index[/COLOR]);
          [COLOR=#9cdcfe]oldStatePousser[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] = [COLOR=#569cd6]BUTTON_PRESSED[/COLOR];
          [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]oldStateTirer[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] == [COLOR=#569cd6]BUTTON_PRESSED[/COLOR])
            [COLOR=#dcdcaa]noteOff[/COLOR]([COLOR=#9cdcfe]noteSynthTirer[/COLOR]);
            [COLOR=#9cdcfe]oldStateTirer[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] = [COLOR=#569cd6]BUTTON_RELEASED[/COLOR];
      {[COLOR=#6a9955] // on tire sur le soufflet et on appuie sur le bouton[/COLOR]
        [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]oldStateTirer[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] == [COLOR=#569cd6]BUTTON_RELEASED[/COLOR])
          [COLOR=#dcdcaa]noteOn[/COLOR]([COLOR=#9cdcfe]noteSynthTirer[/COLOR], [COLOR=#9cdcfe]index[/COLOR]);
          [COLOR=#9cdcfe]oldStateTirer[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] = [COLOR=#569cd6]BUTTON_PRESSED[/COLOR];
          [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]oldStatePousser[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] == [COLOR=#569cd6]BUTTON_PRESSED[/COLOR])
            [COLOR=#dcdcaa]noteOff[/COLOR]([COLOR=#9cdcfe]noteSynthPousser[/COLOR]);
            [COLOR=#9cdcfe]oldStatePousser[/COLOR][[COLOR=#9cdcfe]index[/COLOR]] = [COLOR=#569cd6]BUTTON_RELEASED[/COLOR];
[COLOR=#6a9955]        // on appuie pas sur le bouton ma[/COLOR]
[COLOR=#569cd6]void[/COLOR] [COLOR=#dcdcaa]playNotes[/COLOR]([COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]index[/COLOR], [COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]sens_soufflet[/COLOR] ){
  [COLOR=#c586c0]if[/COLOR] ([COLOR=#9cdcfe]index[/COLOR] != [COLOR=#b5cea8]31[/COLOR] && [COLOR=#9cdcfe]index[/COLOR] != [COLOR=#b5cea8]8[/COLOR])
    [COLOR=#dcdcaa]noteMidi[/COLOR]([COLOR=#9cdcfe]sens_soufflet[/COLOR], [COLOR=#9cdcfe]index[/COLOR], [COLOR=#b5cea8]127[/COLOR]);
[COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]state[/COLOR] = [COLOR=#b5cea8]0[/COLOR];
[COLOR=#569cd6]int[/COLOR] [COLOR=#9cdcfe]sens_soufflet[/COLOR] =[COLOR=#b5cea8]1[/COLOR];
[COLOR=#569cd6]void[/COLOR] [COLOR=#dcdcaa]loop[/COLOR]()
  [COLOR=#c586c0]if[/COLOR]([COLOR=#9cdcfe]state[/COLOR] >= [COLOR=#b5cea8]36[/COLOR]){
    [COLOR=#9cdcfe]sens_soufflet[/COLOR] = [COLOR=#dcdcaa]digitalRead[/COLOR]([COLOR=#569cd6]SOUFFLET_PIN[/COLOR]);
  [COLOR=#9cdcfe]buttonStates[/COLOR][[COLOR=#9cdcfe]state[/COLOR]] = [COLOR=#dcdcaa]getButtonState[/COLOR]([COLOR=#9cdcfe]state[/COLOR]);
  [COLOR=#dcdcaa]playNotes[/COLOR]([COLOR=#9cdcfe]state[/COLOR], [COLOR=#9cdcfe]sens_soufflet[/COLOR]);
  [COLOR=#9cdcfe]state[/COLOR]++;
[/FONT][/COLOR]
