When I was working on a sketch, experimenting with sgtl5000's compression values, suddenly all signs of life from either the input or output went dead. My Teensy 4.0 + Audio Shield is setup according to the Audio Tutorial.
Things that I've done so far to pinpoint the problem (with no real success):
- Ran Audio > Tutorial > Hardware test: All pots and buttons work properly with stable values printed.
- Ran various Hardware tests such as PassThroughStereo and PeakMeterStereo: No signs of life on the inputs/outputs.
- Ran Audio > Tutorial > PlayMusic: No sound (on both HP and LO)
- Modified PlayMusic script with the contents of PeakMeterStereo so I can monitor if any WAV is played off of SDCard at all (by wiring up a cord between playSd and peaks): i can monitor peaks of the WAV file, so AudioShield does not seem to be fully broken. No sound on any outputs tho.
- Went through all solder joints on Teensy AND Audio Shield with my Voltmeter, no shorts or loose solder.
- An interesting find: If I connect my Digitakt to Line-ins and crank the volume to the max, i can very very faintly hear what's coming from line-in through headphones. This is not dependent on the sketch loaded. Happens even with LED Blink sketch.
- Power cycled dozens of times (in hopes of resetting sgtl5000): Nothing changed.
I'm lost. Anyone have other ideas to try?
Cheers!
Cheers!
