OTA through Ethernet demo code for Teensy41
by Olivier Merlet
WARNING: You can brick your Teensy with incorrect flash erase/write, such as
incorrect flash config (0x400-40F). This code may or may not prevent that.
I, Olivier Merlet, give no warranty, expressed or implied for this software and/or
documentation provided, including, without limitation, warranty of
merchantability and fitness for a particular purpose.
based on:
- FlasherX Library (https://github.com/joepasquariello/FlasherX)
- QNEthernet
- Async_AdvancedWebServer !!!! be sure to use the modified version fixing Upload bug
see (https://forum.pjrc.com/threads/72220-AsyncWebServer_Teensy41-bug-onUpload?p=321229&viewfull=1#post321229)
#if !( defined(CORE_TEENSY) && defined(__IMXRT1062__) && defined(ARDUINO_TEENSY41) )
#error Only Teensy 4.1 supported
#define USING_DHCP true
//#define USING_DHCP false
#if !USING_DHCP
// Set the static IP address to use if the DHCP fails to assign
IPAddress myIP(192, 168, 2, 222);
IPAddress myNetmask(255, 255, 255, 0);
IPAddress myGW(192, 168, 2, 1);
//IPAddress mydnsServer(192, 168, 2, 1);
IPAddress mydnsServer(8, 8, 8, 8);
#include "QNEthernet.h" // https://github.com/ssilverman/QNEthernet
using namespace qindesign::network;
#include <AsyncWebServer_Teensy41.h>
AsyncWebServer server(80);
#include "FXUtil.h" // read_ascii_line(), hex file support
extern "C" {
#include "FlashTxx.h" // TLC/T3x/T4x/TMM flash primitives
// hex_info_t struct for hex record and hex file info
typedef struct { //
char *data; // pointer to array allocated elsewhere
unsigned int addr; // address in intel hex record
unsigned int code; // intel hex record type (0=data, etc.)
unsigned int num; // number of data bytes in intel hex record
uint32_t base; // base address to be added to intel hex 16-bit addr
uint32_t min; // min address in hex file
uint32_t max; // max address in hex file
int eof; // set true on intel hex EOF (code = 1)
int lines; // number of hex records received
} hex_info_t;
void read_ascii_line( Stream *serial, char *line, int maxbytes );
int parse_hex_line( const char *theline, char *bytes, unsigned int *addr, unsigned int *num, unsigned int *code );
int process_hex_record( hex_info_t *hex );
void update_firmware( Stream *in, Stream *out, uint32_t buffer_addr, uint32_t buffer_size );
static char line[96]; // buffer for hex lines
int line_index=0;
static char data[32] __attribute__ ((aligned (8))); // buffer for hex data
hex_info_t hex = { // intel hex info struct
data, 0, 0, 0, // data,addr,num,code
0, 0xFFFFFFFF, 0, // base,min,max,
0, 0 // eof,lines
bool ota_status=0; // 1=running
bool ota_final=0;
uint32_t buffer_addr, buffer_size;
void OTAend(AsyncWebServerRequest *request){
AsyncWebParameter* p = request->getParam(0);
Serial.printf("FILE[%s]: %s, size: %u\n", p->name().c_str(), p->value().c_str(), p->size());
if (ota_final){
Serial.printf( "\nhex file: %1d lines %1lu bytes (%08lX - %08lX)\n",
hex.lines, hex.max-hex.min, hex.min, hex.max );
// check FSEC value in new code -- abort if incorrect
#if defined(KINETISK) || defined(KINETISL)
uint32_t value = *(uint32_t *)(0x40C + buffer_addr);
if (value != 0xfffff9de) {
out->printf( "new code contains correct FSEC value %08lX\n", value );
else {
out->printf( "abort - FSEC value %08lX should be FFFFF9DE\n", value );
ota_final=false;
if (ota_final){
// check FLASH_ID in new code - abort if not found
if (check_flash_id( buffer_addr, hex.max - hex.min )) {
Serial.printf( "new code contains correct target ID %s\n", FLASH_ID );
else {
Serial.printf( "abort - new code missing string %s\n", FLASH_ID );
ota_final=false;
AsyncWebServerResponse *response = request->beginResponse((!ota_final)?500:200, "text/plain", (!ota_final)?"OTA Failed... Going for reboot":"OTA Success! Going for reboot");
response->addHeader("Connection", "close");
response->addHeader("Access-Control-Allow-Origin", "*");
request->send(response);
if (ota_final){
Serial.printf( "calling flash_move() to load new firmware...\n" );
flash_move( FLASH_BASE_ADDR, buffer_addr, hex.max-hex.min );
Serial.flush();
REBOOT;
Serial.printf( "erase FLASH buffer / free RAM buffer...\n" );
firmware_buffer_free( buffer_addr, buffer_size );
delay(15000);
Serial.flush();
REBOOT;
void OTA(AsyncWebServerRequest *request, String filename, size_t index, uint8_t *data, size_t len, bool final){
if (!ota_status){
Serial.println("Starting OTA...");
if (firmware_buffer_init( &buffer_addr, &buffer_size ) == 0) {
Serial.println( "unable to create buffer" );
Serial.printf( "created buffer = %1luK %s (%08lX - %08lX)\n",
buffer_size/1024, IN_FLASH(buffer_addr) ? "FLASH" : "RAM",
buffer_addr, buffer_addr + buffer_size );
ota_status=true;
if (ota_status) {
if(len){
size_t i=0;
while (i<len){
if (data[i]==0x0A || (line_index==sizeof(line)-1)){ // '\n'
line[line_index] = 0; // null-terminate
//Serial.printf( "%s\n", line );
if (parse_hex_line( (const char*)line, hex.data, &hex.addr, &hex.num, &hex.code ) == 0) {
Serial.printf( "abort - bad hex line %s\n", line );
return request->send(400, "text/plain", "abort - bad hex line");
else if (process_hex_record( &hex ) != 0) { // error on bad hex code
Serial.printf( "abort - invalid hex code %d\n", hex.code );
return request->send(400, "text/plain", "invalid hex code");
else if (hex.code == 0) { // if data record
uint32_t addr = buffer_addr + hex.base + hex.addr - FLASH_BASE_ADDR;
if (hex.max > (FLASH_BASE_ADDR + buffer_size)) {
Serial.printf( "abort - max address %08lX too large\n", hex.max );
return request->send(400, "text/plain", "abort - max address too large");
else if (!IN_FLASH(buffer_addr)) {
memcpy( (void*)addr, (void*)hex.data, hex.num );
else if (IN_FLASH(buffer_addr)) {
int error = flash_write_block( addr, hex.data, hex.num );
if (error) {
Serial.printf( "abort - error %02X in flash_write_block()\n", error );
return request->send(400, "text/plain", "abort - error in flash_write_block()");
hex.lines++;
line_index=0;
} else if (data[i]!=0x0D){ // '\r'
line[line_index++]=data[i];
i++;
if (final) { // if the final flag is set then this is the last frame of data
Serial.println("Transfer finished");
ota_final=true;
}else{
return;
return request->send(400, "text/plain", "OTA could not begin");
void handleNotFound(AsyncWebServerRequest *request)
request->send(404, "text/plain", "Not found");
while (!Serial && millis() < 5000);
delay(200);
Serial.print("\nOTA through Ethernet demo code for ");
Serial.println(BOARD_NAME);
#if USING_DHCP
// Start the Ethernet connection, using DHCP
Serial.print("Initialize Ethernet using DHCP => ");
Ethernet.begin();
#else
// Start the Ethernet connection, using static IP
Serial.print("Initialize Ethernet using static IP => ");
Ethernet.begin(myIP, myNetmask, myGW);
Ethernet.setDNSServerIP(mydnsServer);
if (!Ethernet.waitForLocalIP(10000))
Serial.println(F("Failed to configure Ethernet"));
if (!Ethernet.linkStatus())
Serial.println(F("Ethernet cable is not connected."));
// Stay here forever
while (true)
delay(1);
Serial.print(F("Connected! IP address:"));
Serial.println(Ethernet.localIP());
#if USING_DHCP
#else
delay(2000);
server.onNotFound(handleNotFound);
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
String html = "<body><h1>OTA through Ethernet demo code for Teensy41</h1><br \><h2>select and send your binary file:</h2><br \><div><form method='POST' enctype='multipart/form-data' action='/'><input type='file' name='file'><button type='submit'>Send</button></form></div></body>";
request->send(200, "text/html", html);
server.on("/", HTTP_POST, OTAend, OTA);
server.begin();
Serial.print(F("HTTP EthernetWebServer is @ IP : "));
Serial.print(F("Visit http://"));
Serial.print(Ethernet.localIP());
Serial.println("/");
the file:
