Results 1 to 9 of 9
Thread: [Feature request] Reliably detect Host PC suspending USB port
    Junior Member FeuerSturm's Avatar
    Jan 2023
    15
    I have ported my project from using TinyUSB stack and FastLED on a generic Raspberry Pi Pico to
    a Teensy 4.X with using your amazing OctoWS2811 library, I've got almost everything to work perfect,
    but there's one thing that nags me: the lack of being able to reliably detect the PC suspending the USB ports
    Using TinyUSB allowed me to simply check for the state of the USB port with
    bool portSuspended = TinyUSBDevice.suspended();
    and I desperatly need such a feature.
    I asked for help on the forums already and receivedd a reply with a possible solution reading the suspend flag in the PORTSC1,
    unfortunately that's not really working for me at all, using this test sketch showed that it seems to be totally random when the
    onboard led turns on or off:
    unsigned long lastCheck;
    	pinMode(LED_BUILTIN, OUTPUT);
    	unsigned long currentMillis = millis();
    	if(currentMillis - lastCheck >= 1000)
    		lastCheck = currentMillis;
    		if(!bitRead(USB1_PORTSC1,7))
    I have then checked the i.MX RT1060 Processor Reference Manual, Rev. 2, 12/2019 and tried everything that I could find searching for "suspend" inside it, no success at all.
    I'd really love to see a callback or function to reliably check if the PC the Teensy is connected to is on or off (port suspended or not).
    Mar 2017
    Oakland, CA, USA
    635
    Does `if (!Serial)` work?
    16,891
    Once if(Serial) goes TRUE is stays that way.
    Not finding it but post last year suggested a register to check can identify if Host connect is active.
    Jan 2023
    15
    Quote Originally Posted by shawn View Post
    Unfortunately it's exactly like defragster said, it just stays TRUE no matter what.
    I've been searching the forums for hours literally and tried everything that people suggested additionally to searching
    through the Processor Reference Manual and trying everything that could even lightly be related, no success at all unfortunately.
    If TinyUSB can do that with a Pi Pico, I am pretty sure there's a way with a Teensy 4.X as well.
    Thanks for your replies so far, gentlemen.
    16,891
    Wasn't tried here - but there was a post and it seems I dug it up some weeks back in reference for another and re-linked ...
    Jan 2023
    15
    That might have been my post in Project Guidance, you digged out that "USB1_PORTSC1" suggestion, that unfortunately doesn't work the way I need it, as it flags the device as suspended after 3ms without activity on the bus
    which doesn't help me with my use case.
    Jan 2023
    15
    I cannot believe that I am the only one that would be interested in such a vital feature.
    Can I pretty please at least get some feedback if this is being considered at all?
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    1,041
    Does this thread, msg#4, help you?
    Paul
    Jan 2023
    15
    Quote Originally Posted by PaulS View Post
    Paul
    Nope, already tried that (see first post) and any other registers I found in the processor docs.
    That just reports "suspended" when there's no activity on the bus for 3ms,
    that's not what I need.
