My application is a little different, I have Teensy running controllers developed using MATLAB Simulink Autocode. The workflow is to use a Simulink Simulation of the vehicle and controller to develop and validate control laws and autonomy software in Simulink. The controller is then autocoded to C++, bundled with some wrapper code I wrote that handles the sensor and actuator I/O and real-time state estimation, and then flashed to Teensy. This uses a CMake build system to handle a lot of the magic and pull in dependencies:
https://github.com/bolderflight/spaaro
I have Simulink Embedded Coder setup for an NXP Cortex chip, but it's just generating C++ code during the Autocode process. This gets combined with C++ code from the Teensy cores along with C++ sensor drivers, state estimation, and a data logger. Then it's built and flashed using my CMake toolchain. Theoretically, you could setup the Teensy fully in Simulink and have Simulink flash the Teensy directly, but that approach seemed like a lot more effort than I wanted to invest. I would also then need to implement my sensor drivers and state estimation software in S-Functions so that they could then be Simulink blocks. There are some (simple) examples of this online, but from experience, implementing S-Functions can be time consuming.
I used to use Hardware in the Loop (HIL) testing in previous jobs, but I haven't found enough justification to implement it yet. My understanding is that Simulink can communicate with external devices over ethernet or serial. So the idea would be to spoof the sensors and actuators while running the vehicle model on a PC, communicating with a controller running on the Teensy. Probably use serial to facilitate that communication. My biggest issue is that I would need to have a different version of the controller software for HIL, one for example that looks for IMU data over serial instead of reading from the IMU over SPI. The other issue is that I'm using the IMU data ready interrupt for timing and for HIL / PIL the timing would need to come from Simulink. With all these mods am I really testing the controller?
In my experience, I'm mostly using Simulink simulation to validate my control laws. HIL / PIL testing is used to validate that I'm not overrunning frames and to ensure that the sensor and actuator I/O is correct. I just use ground testing for this currently. It's not the perfect work flow for everyone, but it works well enough for me and seems like a good approach for UAS / drones.
EDIT: I think HIL testing would likely be easier to implement and far more useful if the Teensy toolchain is fully implemented in Simulink. There are examples where the S-Function for a sensor driver can be setup to:
1. use a simulink model of the sensor during simulation
2. autocode to the C++ driver to communicate with the actual sensor
3. pull in external data from HIL
So that would be perfect, but it is a tall hill to climb. If you go down the path of trying to fully implement Teensy in Simulink, please let me know, I'd be happy to contribute where I can.
