So I have heard that a Teensy 3.6 has its own crystal built in. And that all you need to do is provide it with a battery. Ive also heard that the "Vbat" pin is used to connect to the battery. But I am unsure, would you also need a ground pin for that? if not, how would Vbat connect to both ends of the battery? I am unsure of how exactly to use RTC with Teensy 3.6.
I am doing a hobby project and I am much more skilled with software than hardware so Im not too familiar with pins and physically putting things together. (programming the teensy will likely be smoother (hopefully))
