radiohound
Recently, Phil Schatzmann succesfully ported espeak-ng to arduino (ESP32). His work is located here: https://github.com/pschatzmann/arduino-espeak-ng (with some backstory here: https://www.pschatzmann.ch/home/2022/11/10/espeak-ng-the-difficult-journey-to-an-arduino-library/
I am attempting to see if I can port it to a Teensy 4.1. Espeak-ng uses phoneme sound files that are 22khz 16 bit files. So to make it work with Teensy 4.1 I believe it will have to use Frank's https://github.com/FrankBoesing/Teensy-WavePlayer library.
The phoneme files are in espeak-ng-data-min (a slimmed down English only version, about 828kB) or espeak-ng-data (most all languages, about 11.7MB), which would be loaded to the SD card in /SD/espeak-ng-data
I think this would be a fantastic feature for the Teensy to be able to have with it's audio functions. If anyone could help to try to get this working for a Teensy 4.1, I would really appreciate it.
My feeble, unfinished attempt is below. But I get "Compilation error: exit status 1" when trying to compile.
Thank you for any help or suggestions you can offer,
Walter
//Teensy 4.1
* @file espeak.ino
* @author Phil Schatzmann
* @brief Functional API example with additional information
* @version 0.1
* @date 2022-10-27
* @copyright Copyright (c) 2022
//#include "AudioTools.h" - this was for ESP32
#include <FileSystems.h> // https://github.com/pschatzmann/arduino-posix-fs
//#include "AudioLibs/AudioKit.h" // https://github.com/pschatzmann/arduino-audiokit
#include <play_wav.h> //added for Teensy to allow for 22khz sound
#include <Audio.h> //added for teensy
#include <espeak.h>
#include <SdFat.h>
#if defined(__IMXRT1062__)
#define T4
#include <utility/imxrt_hw.h> // make available set_audioClock() for setting I2S freq on Teensy 4
#else
#define F_I2S ((((I2S0_MCR >> 24) & 0x03) == 3) ? F_PLL : F_CPU) // calculation for I2S freq on Teensy 3
//Teensy sound setup
AudioPlayWav playWav; //xy=323,171
AudioMixer4 mixer1; //xy=647,123
AudioMixer4 mixer3; //xy=648,212
AudioOutputI2S output1; //xy=828,169
AudioConnection patchCord1(playWav, 0, mixer1, 0);
AudioConnection patchCord2(playWav, 1, mixer3, 0);
AudioConnection patchCord3(playWav, 2, mixer1, 1);
AudioConnection patchCord4(playWav, 3, mixer3, 1);
AudioConnection patchCord5(playWav, 4, mixer1, 2);
AudioConnection patchCord6(playWav, 5, mixer3, 2);
AudioConnection patchCord7(playWav, 6, mixer1, 3);
AudioConnection patchCord8(playWav, 7, mixer3, 3);
AudioConnection patchCord9(mixer1, 0, output1, 0);
AudioConnection patchCord10(mixer3, 0, output1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=853,409
//modded for Teensy 4.1 with builtin SD card
#define PIN_SD_CARD_CS BUILTIN_SDCARD
#define PIN_SD_CARD_MISO 12
#define PIN_SD_CARD_MOSI 11
#define PIN_SD_CARD_CLK 13
//I2SStream was for ESP32 - Need to change for Teensy
//I2SStream i2s; // or replace with AudioKitStream for AudioKit
const char* path = "/sd/espeak-ng-data"; //Change path by command below:
//file_systems::FileSystemSD efs(path, SD); // dummy implementation on ESP32
espeak_AUDIO_OUTPUT output = AUDIO_OUTPUT_SYNCH_PLAYBACK;
//output = AUDIO_OUTPUT_SYNCH_PLAYBACK;
void *user_data = nullptr;
unsigned int *identifier = nullptr;
int buflength = 500, options = 0;
unsigned int position = 0, end_position = 0, flags = espeakCHARS_AUTO;
espeak_POSITION_TYPE position_type = POS_CHARACTER;
// we load the config data from SD: "sd" is default mount point
Serial.println("starting SD");
while (!(SD.begin(PIN_SD_CARD_CS))) {
// stop here, but print a message repetitively
sgtl5000_1.enable();
sgtl5000_1.volume(0.6);
// setup audio
Serial.println("starting i2s");
audio_info espeak_info = espeak_get_audio_info();
//configures sampling rates for ESP32
auto cfg = i2s.defaultConfig();
cfg.channels = espeak_info.channels; // 1
cfg.sample_rate = espeak_info.sample_rate; // 22050
cfg.bits_per_sample = espeak_info.bits_per_sample; // 16
i2s.begin(cfg);
espeak_set_audio_output(&i2s);
// setup espeak
Serial.println("espeak_Initialize");
espeak_Initialize(output, buflength, path, options);
espeak_VOICE voice;
memset(&voice, 0, sizeof(espeak_VOICE)); // Zero out the voice first
const char *langNativeString = "en"; // Set voice by properties
voice.languages = langNativeString;
voice.name = "US";
voice.variant = 2;
voice.gender = 2;
Serial.println("espeak_SetVoiceByProperties");
espeak_SetVoiceByProperties(&voice);
//from teensy waveplayer
Serial.print("Playing file: ");
Serial.println(filename);
playWav.play(filename);
while (playWav.isPlaying())
// Needed for EventResponder: could instead call yield(),
// or switch to old scheme of reading SD inside the update() loop
// by executing playWav.enableEventReading(false)
delay(10);
//teensy 4 calculate speed
#ifdef T4
#else
// calculate I2S dividers for Teensy 3
uint32_t I2S_dividers( float fsamp, uint32_t nbits, uint32_t tcr2_div )
unsigned fract, divi;
fract = divi = 1;
float minfehler = 1e7;
unsigned x = (nbits * ((tcr2_div + 1) * 2));
unsigned b = F_I2S / x;
for (unsigned i = 1; i < 256; i++) {
unsigned d = round(b / fsamp * i);
float freq = b * i / (float)d ;
float fehler = fabs(fsamp - freq);
if ( fehler < minfehler && d < 4096 ) {
fract = i;
divi = d;
minfehler = fehler;
//Serial.printf("%fHz<->%fHz(%d/%d) Fehler:%f\n", fsamp, freq, fract, divi, minfehler);
if (fehler == 0.0f) break;
return I2S_MDR_FRACT( (fract - 1) ) | I2S_MDR_DIVIDE( (divi - 1) );
// set I2S samplerate for Teensy
void setI2SFreq(int freq) {
#if defined(T4)
// PLL between 27*24 = 648MHz und 54*24=1296MHz
int n1 = 4; //SAI prescaler 4 => (n1*n2) = multiple of 4
int n2 = 1 + (24000000 * 27) / (freq * 256 * n1);
double C = ((double)freq * 256 * n1 * n2) / 24000000;
int c0 = C;
int c2 = 10000;
int c1 = C * c2 - (c0 * c2);
set_audioClock(c0, c1, c2, true);
CCM_CS1CDR = (CCM_CS1CDR & ~(CCM_CS1CDR_SAI1_CLK_PRED_MASK | CCM_CS1CDR_SAI1_CLK_PODF_MASK))
| CCM_CS1CDR_SAI1_CLK_PRED(n1-1) // &0x07
| CCM_CS1CDR_SAI1_CLK_PODF(n2-1); // &0x3f
#else
unsigned tcr5 = I2S0_TCR5;
unsigned word0width = ((tcr5 >> 24) & 0x1f) + 1;
unsigned wordnwidth = ((tcr5 >> 16) & 0x1f) + 1;
unsigned framesize = ((I2S0_TCR4 >> 16) & 0x0f) + 1;
unsigned nbits = word0width + wordnwidth * (framesize - 1 );
unsigned tcr2div = I2S0_TCR2 & 0xff; //bitclockdiv
uint32_t MDR = I2S_dividers(freq, nbits, tcr2div);
if (MDR > 0) {
while (I2S0_MCR & I2S_MCR_DUF) {
I2S0_MDR = MDR;
char text[] = "Hello world!";
Serial.println(text);
espeak_Synth(text, buflength, position, position_type, end_position, flags,
identifier, user_data);
Serial.println("Done");
delay(5000);
Walter
