Ethernet Teensy 4.1 connection problem - NativeEthernet bug?
JEN
In a project we are using Teensy 4.1 as a host to control some hardware via network. Sometimes we loose connection. To reproduce the behavior, I modified the AdvancedChatserver example to behave like our software. It disconnects any client except the authorized one if there are more than six clients, instead of checking for disconnected clients as the original example does. A C# testapp creates multiple clients that just connect to the Teensy by socket.connect() and receive the "we have a new client" response. Sometimes Teensy does no longer respond and clients don't get the message. Then Teensy needs to reboot before any new client can connect. Has anyone else seen something similar? Is it a bug in the NativeEthernet library or a hardware problem? Below is the code of the modified AdvancedChatserver example.
 Advanced Chat Server
 A more advanced server that distributes any incoming messages
 to all connected clients but the client the message comes from.
 To use, telnet to your device's IP address and type.
 You can see the client's input in the serial monitor as well.
 Using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 redesigned to make use of operator== 25 Nov 2013
 by Norbert Truchsess
//#include <SPI.h>
#include <NativeEthernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
  0x05, 0x39, 0x22, 0x11, 0x04, 0x23
IPAddress ip(192, 168, 5, 55);
IPAddress myDns(192, 168, 99, 254);
IPAddress gateway(192, 168, 99, 254);
IPAddress subnet(255, 255, 255, 0);
// telnet defaults to port 23
EthernetServer server(23);
int ClientCount;
int lastClient;
EthernetClient clients[8];
  // You can use Ethernet.init(pin) to configure the CS pin
  //Ethernet.init(10);  // Most Arduino shields
  //Ethernet.init(5);   // MKR ETH shield
  //Ethernet.init(0);   // Teensy 2.0
  //Ethernet.init(20);  // Teensy++ 2.0
  //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
  //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
  // initialize the Ethernet device
  Ethernet.begin(mac, ip, myDns, gateway, subnet);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  // start listening for clients
  server.begin();
  Serial.print("Chat server address:");
  Serial.println(Ethernet.localIP());
  // check for any new client connecting, and say hello (before any incoming data)
  lastClient = -1;
  EthernetClient newClient = server.accept();
  if (newClient) {
    for (byte i=0; i < 8; i++) {
      if (!clients[i]) {
        Serial.print("We have a new client #");
        Serial.println(i);
        newClient.print("Hello, client number: ");
        delay(8);
        newClient.println(i);
        // Once we "accept", the client is no longer tracked by EthernetServer
        // so we must store it into our list of clients
        clients[i] = newClient;
        lastClient = i;
  // check for incoming data from all clients
    if (clients[i] && clients[i].available() > 0) {
      // read bytes from a client
      byte buffer[80];
      int count = clients[i].read(buffer, 80);
      // write the bytes to all other connected clients
      for (byte j=0; j < 8; j++) {
        if (j != i && clients[j].connected()) {
          clients[j].write(buffer, count);
  // stop any clients which disconnect
  //for (byte i=0; i < 8; i++) {
  //  if (clients[i] && !clients[i].connected()) {
  //    Serial.print("disconnect client #");
  //    Serial.println(i);
  //    clients[i].stop();
  ClientCount = 0;
    if (clients[i] && clients[i].connected()) {
      ClientCount++;
    if(ClientCount > 6){
      for (byte i=0; i < 8; i++){
        if(clients[i] && i != lastClient){
          clients[i].stop();
          Serial.println(i);
Have a look at QNEthernet. Keep in mind some extra conveniences with the library, for example, you don’t need to specify a MAC address.
1+ for using QNEthernet. It uses more RAM, but it's more stable and has more options than NativeEthernet. I had better luck with QNEthernet in my projects. Also, it's more actively maintained.
Thanks, first tests look promising. So far no connection problems with the modified AdvancedChatServer example. Hopefully it also works in our project.
The latest QNEthernet push further reduces RAM1 usage by about 27KiB with the current configuration by moving lwIP's memory pools to RAM2, along with some other hundreds-of-bytes changes.
