Teensy 4.1 CPU frequency steps?
Srx
I've noticed that the Teensy 4.1 page mentions very specific MHz on the product page:
Is there any reason for this? I run my teensies through PlatformIO settings mostly on 240MHz and I'm wondering if this cause any problem to run Teensy 4.1 on "odd" frequencies?
Anything can work in steps of some couple MHz auto adjusted versus requested value based on clock math.
Certain select frequencies are 'sweet' spots: 600 Max in Spec, 528 optimal speed and current design, and others going down to 24 where USB still works. And those going upwards
I believe on of the main system clocks maxes at 150MHz (w/o overclocking), so multiples of that are used (the large datasheet has details of all the PLLs and clock domain/trees and if you have the patience that may answer a lot of questions about which frequencies are used). Certain peripherals may place constraints on some of the clocks, such as USB.
