Page 1 of 2 1 2 LastLast
Results 1 to 25 of 47
Thread: UDP client stops receiving packets
    I am having intermittent problems using QNEthernet to receive UDP messages on a Teensy 4.1
    I am firing UDP messages (of 6008 bytes) from a C# test program at the Teensy which is running the sketch below
    It works fine for a while, printing out a message at every multiple of 10000 packets
    Then after some variable amount of time/ packets, it just hangs
    I know the C# application is still sending packets because if I reset the Teensy, it start receiving again
    When it hangs, it must be receiving -1 from parsePacket() because I don't get a message logging any other negative return code
    I am assuming the EthernetUdp object has failed in some way?
    Is there a way to detect this so that I could then perhaps call .begin() again, assuming that would enable it to recover?
    If I put a 1ms delay in the client sending loop (between each packet being sent), it seems to not fail but maybe I just did not test it for long enough
    I had thought about increasing the queue length?
    I am aware that 6008 bytes is over 4 times the size of the MTU max packetr size of 1500 bytes. However the packet splitting/ combining clearly seems to be working to some degree at least?
    The number of packets seems to vary
    HTML Code:
    #include <QNEthernet.h>
    using namespace qindesign::network;
    const uint32_t kDHCPTimeout = 10000;  // 10 seconds
    const uint32_t PayloadLength = 6000;
    const uint32_t LocalPort = 8002;
    struct __attribute__((packed)) T_MessageHeader
      uint32_t messageId;
      uint32_t payloadLength;
    struct __attribute__((packed)) T_TestMessage
      T_MessageHeader messageHeader;
      char payload[PayloadLength];
    union __attribute__((packed)) T_MessageBuffer
      T_TestMessage testMessage;
      char buffer[sizeof(T_TestMessage)];
    EthernetUDP udp;
    unsigned long packetCount = 0;
      while (!Serial && millis() < 4000)
        // Wait for Serial to initialize
      stdPrint = &Serial;  // Make printf work (a QNEthernet feature)
      printf("Starting...\r\n");
      uint8_t mac[6];
      Ethernet.macAddress(mac);  // This is informative; it retrieves, not sets
      printf("MAC = %02x:%02x:%02x:%02x:%02x:%02x\r\n",
             mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
      printf("Starting Ethernet with DHCP...\r\n");
      if (!Ethernet.begin())
        printf("Failed to start Ethernet\r\n");
        return;
      if (!Ethernet.waitForLocalIP(kDHCPTimeout))
        printf("Failed to get IP address from DHCP\r\n");
        return;
      IPAddress ip = Ethernet.localIP();
      printf("    Local IP    = %u.%u.%u.%u\r\n", ip[0], ip[1], ip[2], ip[3]);
      ip = Ethernet.subnetMask();
      printf("    Subnet mask = %u.%u.%u.%u\r\n", ip[0], ip[1], ip[2], ip[3]);
      ip = Ethernet.gatewayIP();
      printf("    Gateway     = %u.%u.%u.%u\r\n", ip[0], ip[1], ip[2], ip[3]);
      ip = Ethernet.dnsServerIP();
      printf("    DNS         = %u.%u.%u.%u\r\n", ip[0], ip[1], ip[2], ip[3]);
      // Start UDP listening on the NTP port
      udp.begin(LocalPort);
      int packetSize = udp.parsePacket();
      if ((packetSize < 0) && (packetSize != -1))
        printf("Return code: %d\r\n", packetSize);
      if (packetSize > 0)
        if (packetSize > (int) sizeof(T_TestMessage))
          printf("Packet size error (expected: %u, actual: %u)\r\n", sizeof(T_TestMessage), packetSize);
          T_MessageBuffer messageBuffer;;
          int dataCount = udp.read(messageBuffer.buffer, packetSize);
          if (dataCount != packetSize)
            printf("Packet read error (expected: %u, actual: %u)\r\n", packetSize, dataCount);
            packetCount++;
            if ((packetCount % 10000) == 0)
              printf("Packet count: %lu\r\n", packetCount);
    Jan 2022
    Netherlands
    56
    Quote Originally Posted by Lateralleap View Post
    HTML Code:
      uint32_t messageId;
    EthernetUDP udp;
      uint8_t mac[6];
        return;
        return;
      if (packetSize > 0)
            packetCount++;
    maybe put a hard cap on packetSize before calling the udp.read?
    Like
    if (packetSize > PayloadLength) packetSize = PayloadLength;
    I effectively do do that. I check if packetSize is greater that the size of the expected packet structure
    Jan 2022
    Netherlands
    56
    No I think you don’t. The size of the struct is 8 bytes more.
    So you may end up writing into RAM that is not part of the struct. But just above it.
    Sorry. I am struggling to understand what you mean. The size of the buffer I read into is the size of the structure that includes the payload and the header. The payload is immaterial in this test program. What matters is the overall size of the message being sent which is 6008 bytes
    Jan 2022
    Netherlands
    56
    If packetSize would be 6001, then where in the buffer that has a only 6000 bytes capacity would the last byte end up?
    The buffer is 6008 bytes long not 6000
    Jan 2022
    Netherlands
    56
    element buffer in this struct has only 6000 bytes.
    beyond the 6000th buffer byte of messageBuffer.buffer, there’s nothing that your udp.read() is allowed to write to. but it will do that when packetSize is >6000…
    maybe you meant to write
    int dataCount = udp.read(&messageBuffer, packetSize);
    where you have
    Sorry but I think you have misunderstood the data declarations
    uint32_t messageId;
    T_TestMessage is a structure that combines a header (of length 8 bytes) and a payload buffer that is declared to be of length PayloadLength (which is 6000 bytes)
    So T_TestMessage is of length 8 + 6000 = 6008 bytes
    The union T_MessageBuffer just provides two alternative ways to access the buffer. Either via the variable testMessage (declared as T_TestMessage so of length 6008 bytes as above) or via the variable buffer (declared as a char array of length sizeof(T_TestMessage) so also 6008 bytes)
    So reading into messageBuffer.buffer is reading into that char array which is of length 6008 bytes
    To put this discussion to bed, please see below:
    Does anyone have any insights into the original issue outlined in my first post?
    THanks
    Jan 2022
    Netherlands
    56
    I see.
    Get https://www.wireshark.org/ and confirm that the udp packets are really there still, also when it hangs.
    Next step if that’s not giving hints: does it restart after unplugging and re-instering the Ethernet cable? If yes, then consider this from WiKi:
    End of frame – physical layer[edit]
    The end of a frame is usually indicated by the end-of-data-stream symbol at the physical layer or by loss of the carrier signal; an example is 10BASE-T, where the receiving station detects the end of a transmitted frame by loss of the carrier. Later physical layers use an explicit end of data or end of stream symbol or sequence to avoid ambiguity, especially where the carrier is continually sent between frames; an example is Gigabit Ethernet with its 8b/10b encoding scheme that uses special symbols which are transmitted before and after a frame is transmitted.[6][7]
    Interpacket gap – physical layer[edit]
    Interpacket gap (IPG) is idle time between packets. After a packet has been sent, transmitters are required to transmit a minimum of 96 bits (12 octets) of idle line state before transmitting the next packet.
    Does the Interpacket gap really meet this spec?
    Thanks Sicco
    I have already confirmed the packets are still there
    Removing/ reinserting the ethernet cable does not restart it
    Resetting the Teensy does restart it
    Feels odd that it can typically do ~ 140,000 packets before hanging if it was an interpacket gap problem?
    I still feel the EthernetUDP object is failing somehow
    What I think is happening when it seems to hang is that it is still receiving packets but at a much slower rate
    In other words, only 1 in every N packets gets through
    I will do some more tests to verify this
    Mar 2017
    Oakland, CA, USA
    633
    I’m curious, is it possible that groups of packets come in immediately, one after the other? This is what I was seeing with pixel data (eg. sACN). It’s why I added a “queue size” parameter to another `EthernetUDP(queueSize)` constructor. It’s able to buffer _N_ packets in a circular buffer. What happens if you use a queue? For example:
    `EthernetUDP udp(64)`
    Hi Shawn
    I did try queue size in an earlier iteration but just of size 2. I will try 64
    However the packet source is a C# application running in a tight loop so not sure why packets would be bunching up and why it would work for 120K packets and then fail
    Also once it gets into this state, it never recovers. I need to look the packet rate to prove that it enters a packet loss state
    Feels like some sort of resource exhaustion or corruption
    I will try queue size and packet rate logging
    Mar 2017
    Oakland, CA, USA
    633
    Entirely possible. I’ll look more closely when I have a chance. Let me just clarify something: does it actually hang or is it just really slow?
    I added some code to print the total packet count received and rate/s every 5 seconds that the end of the main loop
    It seems to die after about 40000 packets have been received
    It is no longer executing the main loop because I get no more output
    Here is the code
    HTML Code:
    const uint32_t PacketTimeoutMillis = 5000;
      uint32_t messageId;
    EthernetUDP udp;
    unsigned long ratePacketCount;
    unsigned long rateMillis;
    unsigned long packetCount;
      uint8_t mac[6];
        return;
        return;
      packetCount = 0;
      ratePacketCount = 0;
      rateMillis = millis();
      if (packetSize == -1)
        //if ((millis() - lastPacketMillis) >= PacketTimeoutMillis)
        //  printf("Packet timeout\r\n");
        //  udp.begin(LocalPort);
        //  lastPacketMillis = millis();
      else if (packetSize < 0)
      else if (packetSize > 0)
            ratePacketCount++;
            packetCount++;
      if ((millis() - rateMillis) >= 5000)
        unsigned long rate = ratePacketCount / 5;
        printf("Packet count: %lu Rate: %lu\r\n", packetCount, rate);
    Mar 2017
    Oakland, CA, USA
    633
    Some questions: Where exactly does it freeze? If it’s actually crashing, does the Teensy restart? What does printing the CrashReport show at program start?
    Here is CrashReport at startup:
    09:20:01.779 -> Hopefully all is well, but certain types of crashes can't be reported:
    09:20:01.779 -> stuck in an infinite loop (technically, hardware still running properly)
    09:20:01.779 -> remaining in a low power sleep mode
    09:20:01.779 -> access to certain peripherals without their clock enabled (eg, FlexIO)
    09:20:01.779 -> change of CPU or bus clock speed without use of glitchless mux
    09:20:01.779 -> Breadcrumb #1 was 3361759250 (0xC8606012)
    09:20:01.779 -> Breadcrumb #6 was 2528204831 (0x96B1581F)
    I added code to the main loop to print out that it was being called every 10 seconds
    When it dies, this time after 335,000 packets received, it no longet prints that keep alive message. So the main loop is no longer being called or else something has happened to serial communication
    The receive rate is very constant around 1800 packets per second right up until the time it dies
    If I do a reset, still the same null CrashReport (just no breadcumb lines) and it starts receiving again
    Hi Shawn
    Another thought. Given that I am sending quite large packets (6008 bytes) much bigger than the MTU max packet size, might there be an issue with the splitting/ combining logic?
    Mar 2017
    Oakland, CA, USA
    633
    What I’m gathering from you is there’s no crash or hang. I’m not certain where your program is stopping. What does the current code look like, and where exactly is it apparently freezing? For example, if the program isn’t continuing, then a “print” after every line will certainly stop at some point. Or… are you saying that after a certain point, parsePacket() always returns something negative?
    Sending packets larger than the MTU will result in IP reassembly of multiple packets. I wonder how robust lwIP’s reassembly is?
    I can certainly instrument the code more. The problem is the packet rate and the print statements will slow down the rate and may mask the problem. Hence why I am printing the keep alive every 10 seconds
    I will do more instrumentation and let you know the result
    Here is the latest code
    HTML Code:
      uint32_t messageId;
    EthernetUDP udp;
    unsigned long aliveMillis;
    bool printed;
      Serial.print(CrashReport);
      uint8_t mac[6];
        return;
        return;
      packetCount = 0;
      aliveMillis = millis();
      if (printed)
        printf("1");
      if (printed)
        printf("2");
      printed = false;
      if ((millis() - aliveMillis) >= 10000)
        printf("Alive! PacketSize: %d\r\n", packetSize);
          printf("3");
          printed = true;
          printf("4");
          printed = true;
            ratePacketCount++;
            packetCount++;
      if (printed)
        printf("5\r\n");
    You will see that I am only printing out 1 or 2 if this follows a previous packet reception. This is to limit a mass of 1s and 2s when there is no packet to read
    What I get is a stream of complete 12345 sequences (obviously the first one is 345)
    What I don't get is
    12345
    12345
    1
    or
    12345
    12345
    12
    I believe this means it is hanging after receiving a packet but then the main look is not called again or else I would get a 1 and perhaps a 2
    If that is what is happening, how can the main loop not be called again but no CrashReport
