Hello, I was just wondering if anybody can give me some advice regarding a sketch I am working on. I am trying to optimise for speed first and then memory resource use.
I used pointers to speed everything up. I am under the impression they helps with this. Have I used them pointers correctly.? Does my sketch need this many pointers or do some of them not make a difference or make things worse.
How can I optimise more?
What tips can you give to make the code run more efficiently?
Thank you very much.
char print_buffer[40];
const uint8_t lane_size = 4;
const uint8_t lane_amount = 3;
const uint8_t lane_bank_amount = 2;
const uint8_t patch_amount = 8;
const uint8_t data_amount = 2;
uint8_t lane_bank_select = 0; // This is used to select the data lane bank
uint8_t memory_select = 0; // This is used to select the data lane bank
struct data_lane {
uint8_t data1[lane_size]; // This selects which patch is selected..
uint8_t data2[lane_size]; // reserved for control data
} sceneA[lane_amount], sceneB[lane_amount]; // 2 different versions of data lane
data_lane *dl_ptr[lane_amount] = { 0 }; // pointer for data lanes
uint8_t lane_index[lane_amount] = { 0 }; // index for data lane
uint8_t *lane_index_ptr[lane_amount] = { 0 };
// displayed signals
struct patch { // creates banks of data that work together
uint8_t data1;
uint16_t data2;
} ptch[patch_amount];
patch *ptch_ptr[patch_amount] = { 0 }; // pointer for patches
uint8_t ptch_index[patch_amount] = { 0 }; // index for patch array
uint8_t *ptch_index_ptr[patch_amount] = { 0 };
serial_lane_select();
//sets where pointers are pointing to either A or B.
switch (lane_bank_select) {
case 0:
for (uint8_t i = 0; i < lane_size; i = i + 1) {
dl_ptr[i] = &sceneA[i];
case 1:
dl_ptr[i] = &sceneB[i];
default:
// fills data into data lanes
// These signals select when and which signals are displayed
//SCENE A
sceneA[0].data1[0] = 1; // selects ptch[1].data1
sceneA[0].data1[1] = 0; // selects ptch[0].data1
sceneA[0].data1[2] = 0;
sceneA[0].data1[3] = 0;
sceneA[1].data1[0] = 2; // selects ptch[2].data1
sceneA[1].data1[1] = 1; // selects ptch[1].data1
sceneA[1].data1[2] = 1;
sceneA[1].data1[3] = 1;
sceneA[2].data1[0] = 3; // selects ptch[3].data1
sceneA[2].data1[1] = 2; // selects ptch[2].data1
sceneA[2].data1[2] = 2;
sceneA[2].data1[3] = 2;
//SCENE B
sceneB[0].data1[0] = 5; // selects ptch[5].data1
sceneB[0].data1[1] = 4; // selects ptch[4].data1
sceneB[0].data1[2] = 4;
sceneB[0].data1[3] = 4;
sceneB[1].data1[0] = 6; // selects ptch[6].data1
sceneB[1].data1[1] = 5; // selects ptch[5].data1
sceneB[1].data1[2] = 5;
sceneB[1].data1[3] = 5;
sceneB[2].data1[0] = 7; // selects ptch[7].data1
sceneB[2].data1[1] = 6; // selects ptch[6].data1
sceneB[2].data1[2] = 6;
sceneB[2].data1[3] = 6;
//sets where patch pointers are pointing to
for (uint8_t i = 0; i < patch_amount; i = i + 1) {
ptch_ptr[i] = &ptch[i];
// fills data into patches
// these are the signals that are displayed...
ptch[0].data1 = 10;
ptch[0].data2 = 11;
ptch[1].data1 = 20;
ptch[1].data2 = 21;
ptch[2].data1 = 30;
ptch[2].data2 = 31;
ptch[3].data1 = 40;
ptch[3].data2 = 41;
ptch[4].data1 = 50;
ptch[4].data2 = 51;
ptch[5].data1 = 60;
ptch[5].data2 = 61;
ptch[6].data1 = 70;
ptch[6].data2 = 71;
ptch[7].data1 = 80;
ptch[7].data2 = 81;
lane_index[0] = lane_index[0] + 1;
lane_index[1] = lane_index[1] + 1;
lane_index[2] = lane_index[2] + 1;
lane_index_ptr[0] = &lane_index[0];
lane_index_ptr[1] = &lane_index[1];
lane_index_ptr[2] = &lane_index[2];
for (uint8_t i = 0; i < lane_amount; i = i + 1) {
if (lane_index[i] == lane_size) {
lane_index[i] = 0;
ptch_index[0] = (*dl_ptr[0]).data1[*lane_index_ptr[0]];
ptch_index[1] = (*dl_ptr[1]).data1[*lane_index_ptr[1]];
ptch_index[2] = (*dl_ptr[2]).data1[*lane_index_ptr[2]];
ptch_index_ptr[0] = &ptch_index[0];
ptch_index_ptr[1] = &ptch_index[1];
ptch_index_ptr[2] = &ptch_index[2];
sprintf(print_buffer, "L1:%d %d %d %d %d ",
*lane_index_ptr[0],
(*dl_ptr[0]).data1[lane_index[0]],
*ptch_index_ptr[0],
(*ptch_ptr[ptch_index[0]]).data1,
(*ptch_ptr[ptch_index[0]]).data2);
Serial.print(print_buffer);
sprintf(print_buffer, "L2:%d %d %d %d %d ",
*lane_index_ptr[1],
(*dl_ptr[1]).data1[lane_index[1]],
*ptch_index_ptr[1],
(*ptch_ptr[ptch_index[1]]).data1,
(*ptch_ptr[ptch_index[1]]).data2);
sprintf(print_buffer, "L3:%d %d %d %d %d ",
*lane_index_ptr[2],
(*dl_ptr[2]).data1[lane_index[2]],
*ptch_index_ptr[2],
(*ptch_ptr[ptch_index[2]]).data1,
(*ptch_ptr[ptch_index[2]]).data2);
Serial.println(print_buffer);
return 0;
void serial_lane_select() {
uint8_t recieved;
if (Serial.available() > 0) {
recieved = Serial.read();
if (recieved == '1') // Single Quote! This is a character.
Serial.println("lane_bank 1");
if (recieved == '2') {
lane_bank_select = 1;
Serial.println("lane_bank 2");
if (recieved == 'q') {
memory_select = 0;
Serial.println("memory_bank 1");
if (recieved == 'w') {
memory_select = 1;
Serial.println("memory_bank 2");
