StefanPetrick
on the Teensy 3.2 the data transfer works really fast (12/24 Mhz and non-blocking(?!)) when using the SPI pins 11 and 13.
Which pins should I use on the Teensy 3.6? It seems to always default to bit-banging? (Idle fps are not in the expected range.)
24 Mhz doesn't work at all. (I'm aware that it's likely too fast for 256 APAs and they might glitch.)
LEDS.addLeds<APA102, 11, 13, BGR, DATA_RATE_MHZ(12)>(leds, NUM_LEDS);
