Ken Perlins improved noise - http://mrl.nyu.edu/~perlin/noise/
C-port: http://www.fundza.com/c4serious/noise/perlin/perlin.html
by Malcolm Kesson; arduino port by Peter Chiochetti, Sep 2007 :
- make permutation constant byte, obsoletes init(), lookup % 256
static const byte p[] = { 151,160,137,91,90, 15,131, 13,201,95,96,
53,194,233, 7,225,140,36,103,30,69,142, 8,99,37,240,21,10,23,190, 6,
148,247,120,234,75, 0,26,197,62,94,252,219,203,117, 35,11,32,57,177,
33,88,237,149,56,87,174,20,125,136,171,168,68,175,74,165,71,134,139,
48,27,166, 77,146,158,231,83,111,229,122, 60,211,133,230,220,105,92,
41,55,46,245,40,244,102,143,54,65,25,63,161, 1,216,80,73,209,76,132,
187,208, 89, 18,169,200,196,135,130,116,188,159, 86,164,100,109,198,
173,186, 3,64,52,217,226,250,124,123,5,202,38,147,118,126,255,82,85,
212,207,206, 59,227, 47,16,58,17,182,189, 28,42,223,183,170,213,119,
248,152,2,44,154,163,70,221,153,101,155,167,43,172, 9,129,22,39,253,
19,98,108,110,79,113,224,232,178,185,112,104,218,246, 97,228,251,34,
242,193,238,210,144,12,191,179,162,241,81,51,145,235,249,14,239,107,
49,192,214, 31,181,199,106,157,184, 84,204,176,115,121,50,45,127, 4,
150,254,138,236,205, 93,222,114, 67,29,24, 72,243,141,128,195,78,66,
215,61,156,180
float fade(float t){ return t * t * t * (t * (t * 6 - 15) + 10); }
float lerp(float t, float a, float b){ return a + t * (b - a); }
float grad(int hash, float x, float y, float z)
int h = hash & 15; /* CONVERT LO 4 BITS OF HASH CODE */
float u = h < 8 ? x : y, /* INTO 12 GRADIENT DIRECTIONS. */
v = h < 4 ? y : h==12||h==14 ? x : z;
return ((h&1) == 0 ? u : -u) + ((h&2) == 0 ? v : -v);
#define P(x) p[(x) & 255]
float pnoise(float x, float y, float z) {
int X = (int)floorf(x) & 255, /* FIND UNIT CUBE THAT */
Y = (int)floorf(y) & 255, /* CONTAINS POINT. */
Z = (int)floorf(z) & 255;
x -= floorf(x); /* FIND RELATIVE X,Y,Z */
y -= floorf(y); /* OF POINT IN CUBE. */
z -= floorf(z);
float u = fade(x), /* COMPUTE FADE CURVES */
v = fade(y), /* FOR EACH OF X,Y,Z. */
w = fade(z);
int A = P(X)+Y,
AA = P(A)+Z,
AB = P(A+1)+Z, /* HASH COORDINATES OF */
B = P(X+1)+Y,
BA = P(B)+Z,
BB = P(B+1)+Z; /* THE 8 CUBE CORNERS, */
return lerp(w,lerp(v,lerp(u, grad(P(AA ), x, y, z), /* AND ADD */
grad(P(BA ), x-1, y, z)), /* BLENDED */
lerp(u, grad(P(AB ), x, y-1, z), /* RESULTS */
grad(P(BB ), x-1, y-1, z))), /* FROM 8 */
lerp(v, lerp(u, grad(P(AA+1), x, y, z-1), /* CORNERS */
grad(P(BA+1), x-1, y, z-1)), /* OF CUBE */
lerp(u, grad(P(AB+1), x, y-1, z-1),
grad(P(BB+1), x-1, y-1, z-1))));
