Results 1 to 6 of 6
Thread: 4.1 How to use RTC ram
    Nov 2020
    near Lansing, Michigan, USA
    3
    Greetings all,
    Here https://www.pjrc.com/store/teensy41.html#tech it says that there are 16 bytes of RTC ram and "This memory is accessed as 32 bit registers LPGPR0-LPGPR3.". I coded the following to test this and get LPGPR[0-3] not defined errors. What magic incantation am I missing to make this work? Thank you in advance.
    // Test sketch to access RTC registers
    float w = 123.45;
    float x = 789.101112;
    int   y = 218;
    unsigned long z = 123456;
      LPGPR0 = w;
      LPGPR1 = x;
      LPGPR2 = y;
      LPGPR3 = z;
    Mar 2017
    Oakland, CA, USA
    701
    Hi! Welcome to the forum!
    This thread may help:
    https://forum.pjrc.com/threads/66076...AM-on-RTC-unit
    17,136
    Good link @shawn
    As shown there the missing piece is this line. It wasn't easy to find, but it was found as noted in the SDK to enable and made the access work:
    	SNVS_LPCR |= (1 << 24); //Enable NVRAM - documented in SDK
    Nov 2020
    3
    Thanks much, that works. Follow up questions, what and where is this "SDK" (I've never heard of it), and how to access the RTC ram on the 3.6?
    17,136
    Quote Originally Posted by tdc View Post
    Glad it works. No idea of the SDK - just a rumor in that comment from the person that saw it there - noted in posts - likely the SDK from NXP for the processor ...
    There is a similar older post for RTC of the T_3.6. It has 8 DWords but one is used by PJRC to track the need to init the RTC startup with compile time.
    Nov 2020
    3
    I took a lot of digging but I found the answer (in case someone else comes looking) at https://forum.pjrc.com/threads/67449...l=1#post315138. The subject says Teensy 4 but it contains 3.5 code which also works on the 3.6.
    Still don't know what the "SDK" referred to above is but hopefully I won't need to going forward.
    Thank you for the assist.
