Page 2 of 2 FirstFirst 1 2
Results 26 to 49 of 49
Thread: PJRC Server Change
  1. #26
    2,771
    ping times from TN rtt min/avg/max/mdev = 39.860/42.676/52.315/2.578 ms
  2. #27
    Aug 2018
    Brisbane, Australia
    168
    Ping times from Brisbane, Australia
    64 bytes from 66-232-106-106.static.hvvc.us (66.232.106.106): icmp_seq=7 ttl=47 time=231 ms
    ^C
    --- forum.pjrc.com ping statistics ---
    7 packets transmitted, 7 received, 0% packet loss, time 6249ms
    rtt min/avg/max/mdev = 230.129/230.649/231.222/0.313 ms
  3. #28
    17,119
    Note: no incoming mail " ... has just replied to a thread " for the post:
    Still not seeing usual 'Subscribed' emails for new posts?
  4. #29
    New York
    8,668
    I will second that comment. Haven’t received any notifications on updates to this thread or the usbhost thread that gave updates since yesterday
  5. #30
    Cheltenham, UK
    1,239
    Pinging pjrc.com [162.254.150.250] with 32 bytes of data:
    Reply from 162.254.150.250: bytes=32 time=106ms TTL=54
    Reply from 162.254.150.250: bytes=32 time=107ms TTL=54
    Reply from 162.254.150.250: bytes=32 time=108ms TTL=54
    Ping statistics for 162.254.150.250:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 106ms, Maximum = 108ms, Average = 107ms
    Pinging forum.pjrc.com [66.232.106.106] with 32 bytes of data:
    Reply from 66.232.106.106: bytes=32 time=107ms TTL=55
    Reply from 66.232.106.106: bytes=32 time=106ms TTL=55
    Ping statistics for 66.232.106.106:
    Minimum = 106ms, Maximum = 107ms, Average = 106ms
    Above is the result from the UK (Gloucestershire, England)
  6. #31
    11,656
    Quick update, this morning:
    C:\Users\kurte>ping pjrc.com
    Reply from 162.254.150.250: bytes=32 time=105ms TTL=44
    Reply from 162.254.150.250: bytes=32 time=88ms TTL=44
    Reply from 162.254.150.250: bytes=32 time=87ms TTL=44
        Minimum = 87ms, Maximum = 105ms, Average = 91ms
    so not as bad as yesterday
  7. #32
    Still 37-38 ms here. Not much beats that except Google (11 ms).
    - Wes, W5ZZO
  8. #33
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    1,092
    From the Netherlands:
    Pinging 162.254.150.250 with 32 bytes of data:
    Reply from 162.254.150.250: bytes=32 time=110ms TTL=48
    Reply from 162.254.150.250: bytes=32 time=108ms TTL=48
    Reply from 162.254.150.250: bytes=32 time=109ms TTL=48
        Minimum = 108ms, Maximum = 110ms, Average = 109ms
    Pinging 66.232.106.106 with 32 bytes of data:
    Reply from 66.232.106.106: bytes=32 time=108ms TTL=49
    Reply from 66.232.106.106: bytes=32 time=107ms TTL=49
    Reply from 66.232.106.106: bytes=32 time=109ms TTL=49
        Minimum = 107ms, Maximum = 109ms, Average = 108ms
    Similar to the times from the UK.
    Paul
  9. #34
    17,119
    Still no email notifications - for this post or the usbhost thread.
    Also earlier post took some time in browser 'spinning' then said - "leave and the post dies" I ignored and the post had completed :: This has happened in the past but not recently here.
    Also seeing a DOUBLE post from mjs513 - I assume he may have gotten the above and hit save again for a double post.
    @Paul - seems some issue unique about the forum server setup?
  10. #35
    17,119
    Hit save and got the WAIT and this LEAVE - hit Cancel and then this double post:
  11. #36
    Dec 2013
    East Stroudsburg PA.
    339
    I had the same issue today with the 'spinning' but I just posted in Audio Projects with no issues.
    Edit: well the spinning is back
  12. #37
    17,119
    @strud had a DUPE post I removed. {was #6 after Faster-way-to-read-in-digital-inputs-into-a-byte-value
    Seems there may be a timing issue with the wait then failed coordination recognizing 'posted'
  13. #38
    17,119
    Edit: This gave the 'Leave' warning - I hit 'Esc'ape and see it double posted after refresh
  14. #39
    New York
    8,668
    @PaulStoffregen - @defragster - @mjs513
    Got the double post when I received the pop up and clicked Leave. Have seen it before but as you said not recently. And still no notifications on a couple of recent threads as @deefragster mentioned.
    EDIT: Leaving the double post as it happened again
    Note: added me to see if I get a notification
  15. #40
    New York
    8,668
  16. #41
    May 2022
    298
    No notifications (from threads I have posted in) have been received. Should have gotten one today. Apparently the switchover didn't preserve some settings?
  17. #42
    27,968
    Looks like the mail server had the old forum IP number on its list of places allowed to send. Edited just now. Hopefully it will fix the missing notifications.
  18. #43
    17,119
    If this was posted after fixing ... no notice was sent/received.
    <edit>: oppps - probably marked 'sent once' with prior messages since last logged on
  19. #44
    17,119
    Double posted? - no 'spinning dots' - but 'hourglass' - completed and double posted this DUPE when it returned up a level ..
  20. #45
    New York
    8,668
    Just saw this post from @defragster by no notification was received from the server?
  21. #46
    New York
    8,668
    EDIT: Duplicate posts still occurring with the Leave/cancel pop up.
  22. #47
    27,968
    Fixed another problem where the forum server was looking for the old main server. Hopefully it will fix some of the ongoing problems?
  23. #48
    New York
    8,668
    Good morning Paul
    Looks like that fix the issue with not getting notifications, received the email about the update to this thread.
    Update: Looks like it fixed the dup issue as well.
  24. #49
    17,119
    I got Mail!
    edit: As with mjs513 that post was no delay and no dupe.
