Results 1 to 4 of 4
Thread: PT8211 Oversampling deprecated? :s
    When I activate Oversampling on output_pt8211_2.h and compile I get the following error:
    'define' does not name a type define AUDIO_PT8211_OVERSAMPLING
    All I did was uncommenting the lines:
    define AUDIO_PT8211_INTERPOLATION_LINEAR
    Any idea what might be happening? I'm on Teensy 4.0.
    Aug 2013
    Ohio
    128
    Preprocessor definitions require "#" character
    It looks like a "#" character is missing.
    The way to enable these things is with a preprocessor macro, so use "#define" preprocessor operator.
    #define AUDIO_PT8211_OVERSAMPLING
    #define AUDIO_PT8211_INTERPOLATION_LINEAR
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    1,096
    Oversampling is enabled by default in output_pt8211_2.h:
    By the way: it's 4x oversampling, see here.
    Paul
    Thanks a lot, a lapsus made me think uncommenting also meant deleting the # symbol :s
    It works fine, using it with a TDA1387 after changing the corresponding line on the .cpp file.
