Results 1 to 4 of 4
Thread: IntervalTimer question
    Jun 2017
    5
    In the simple example here I start an IntervalTimer with 20 msec. callback. In the function called I have a 10 msec. delay. My question is does this delay eat up half of my computational time, or is the delay handled in the background. Timer_example.ino
    volatile int usec_F = 10000;
    IntervalTimer timerFront;
    timerFront.begin(front_Servos, 20000);
    void front_Servos()
    digitalWrite(2, HIGH);
    delayMicroseconds(usec_F);
    digitalWrite(2, LOW);
    17,136
    Use of any delay will block and not return to loop() or other code - except higher priority interrupts
    Code shown has 20 msec delay - then sits 10 msec. If this is the desired behavior the timer could be set to 10 msec and just toggle the pin #2 HIGH then LOW on alternate calls.
    Jun 2017
    5
    Actually I'm running RC servos, so the pulse is around 1,500 microseconds every 20 milliseconds.
    17,136
    ... after reading "20 msec. callback. In the function called I have a 10 msec. delay" delay of 1.5 ms wasn't known
    @luni has timers that can do a one shot - assume it could be triggered for interrupt in the needed 1,500 us.
    Or a second intervalTimer could be started when desired with digitalWrite(2, HIGH); and stopped perhaps with the digitalWrite(2, LOW);
    So the delayMicroseconds(usec_F); would block execution - but only for the noted time usec_F in delayMicroseconds(usec_F);...
