Hi everybody,
using the pcjr-forums seems to be complicated compared to arduino-forum.
I'm asking this for another user who encountered IP-blocking when trying to access the PCJR-forum himself
first of all a test if I can insert a picture-link as drag and drop seems not to work
no preview here so I will see the result only after posting it.
https://europe1.discourse-cdn.com/a...6920a59ad7f1fb17ba6c1076d955e_2_1035x211.jpeg
Is this possible with a teensy 3.5 to read in at this clock-speed?
Are any special configurations nescessary like setting a higher interrupt-priority?
Does the teensy 3.5 (Arm-4-Cortex) offer any kind of internal hardware that can read in the bits?
As there are ony 20 databits would it be possible to use an UART?
I guess the hardware-UARTs want to read in 8 bits per byte which would not match 20 bits
would it still be possible?
Can the receiving into the hardware-UART be interrupted after each 3 bytes?
8 bit byte 1
8 bit byte 2
8 bit last 4 bits ignore next 4 bits
drop 16 bits
start over receiving
Can the I2S-interface receive at 2 MHz?
If a teensy 3.5 is to slow. Would a teensy 4.0 clocked with 600 MHz be fast enough?
Do you happen to know any other kind of microcontroller that would be able to read in the 20 bits at 2 MHz clock?
best regards Stefan
8 bit byte 1
8 bit byte 2
drop 16 bits
best regards Stefan
