Unable to read data from left and right line in at the same time
milos1
New member
Hey sorry to bother I am unable to read data from the left and right line-in at the same time.
I am using Teensy 4.0 with the Audio Board Rev D.
I have checked my (3.5mm jack) out with an oscilloscope and seems like the correct sinewaves are showing up, also the code works for the left channel if patchcord1 is set to pin 0 and patchcord2 is set to 0 I am able to get readings on the left side if patchcord1 is set to pin 1 and patchcord2 is set to I can read right side but I cannot read both when I have patchcord1 set to 0 and patchcord2 set to 1 or patchcord1 set to 1 and patchcord2 set to 0.
I am pretty sure my connections are correct and of course, I do have a ground.
I know the issue might be with me setting up stuff incorrectly but I am unable to fix the issue even after hours of looking at the Forum/GitHub/Sketches, so I hope you do not mind me asking here.
Thanks for any guidance or links to a post where this is resolved!
#include <FastLED.h>
#include <deque>
// Create the Audio components.  These should be created in the
// order data flows, inputs/sources -> processing -> outputs
AudioInputI2S audioInput;
AudioSynthWaveformSine sinewave;
AudioAnalyzeFFT1024    fftLeft;
AudioAnalyzeFFT1024    fftRight;
AudioOutputI2S         audioOutput;        // audio shield: headphones & line-out
AudioConnection patchCord1(audioInput, 0, fftLeft, 0);
AudioConnection patchCord2(audioInput, 1, fftRight, 0);
//AudioConnection patchCord1(sinewave, 0, myFFT, 0);
  AudioMemory(12);
  audioShield.enable();
  audioShield.inputSelect(myInput);
  audioShield.lineInLevel(0,0);
  //audioShield.volume(0.5);
  audioShield.micGain(0);
  //myFFT.begin(true);
  //myFFT1.begin(true);
  fftLeft.windowFunction(AudioWindowHanning1024);
  fftRight.windowFunction(AudioWindowHanning1024);
  sinewave.amplitude(0.8);
  sinewave.frequency(1034.007);
  float n;
  int i;
  if (fftLeft.available()) {
    float left_subbass = 0, left_bass = 0, left_midrange = 0, left_highfreq = 0, left_presence = 0, left_brilliance = 0;
    float right_subbass = 0, right_bass = 0, right_midrange = 0, right_highfreq = 0, right_presence = 0, right_brilliance = 0;
    for (i=0; i<512; i++) {
      float left_n = fftLeft.read(i);
      float right_n = fftRight.read(i);
      if (i >= 0 && i <=6) {
         left_subbass += left_n;
         right_subbass += right_n;
      else if (i >= 6 && i <= 20) {
        left_bass += left_n;
        right_bass += right_n;
      else if (i >= 20 && i <= 40) {
        left_midrange += left_n;
        right_midrange += right_n;
      else if (i >= 40 && i <= 180) {
        left_highfreq += left_n;
        right_highfreq += right_n;
      else if (i >= 180 && i <= 277) {
        left_presence += left_n;
        right_presence += right_n;
      else if (i >= 278 && i <= 512) {
        left_brilliance += left_n;
        right_brilliance += right_n;
    Serial.print("Left: ");
    Serial.print(left_subbass);
    Serial.print(",");
    Serial.print(left_bass);
    Serial.print(",");
    Serial.print(left_midrange);
    Serial.print(",");
    Serial.print(left_highfreq);
    Serial.print(",");
    Serial.print(left_presence);
    Serial.print(",");
    Serial.print(left_brilliance);
    Serial.print(", ");
    Serial.print("Right: ");
    Serial.print(right_subbass);
    Serial.print(",");
    Serial.print(right_bass);
    Serial.print(",");
    Serial.print(right_midrange);
    Serial.print(",");
    Serial.print(right_highfreq);
    Serial.print(",");
    Serial.print(right_presence);
    Serial.print(",");
    Serial.print(right_brilliance);
    Serial.println(",");
#include <deque>
	AudioMemory(12);
	audioShield.lineInLevel(0, 0);
	float n;
	int i;
		for (i = 0; i < 512; i++) {
			if (i >= 0 && i <= 6) {
		Serial.print(",");
		Serial.print(",");
		Serial.print(",");
		Serial.print(",");
		Serial.print(",");
		Serial.print(", ");
		Serial.print(",");
		Serial.print(",");
		Serial.print(",");
		Serial.print(",");
		Serial.print(",");
Can I please request that if future you post your code between CODE tags using the # button on the form.
This makes your code much easier to read for others to help you.
You also have not stated what hardware you are using.
Unfortunately I am unable to help you as I have no knowledge of using the AUDIO card nor FFT but hopefully someone else will be able to.
EDIT: A photo of you connections may also help.
Hey, thanks a lot! I did not know about the # button previously. I have now edited the post with more information you suggested!
FIXED THE ISSUE
Using the mixer in the correct way.
AudioMixer4          mixer;
AudioAnalyzeFFT1024  fft;
AudioConnection c1(audioInput, 0, mixer, 0);
AudioConnection c2(audioInput, 1, mixer, 1);
AudioConnection c3(mixer, fft);
