A useful statistics class
shawn
I've found this class useful for collecting statistics for a stream of data in a single pass. Simply call `update()` with the new sample and it does single-pass calculation of the mean and variance. Note that I've used floats, but it's possible you may wish to use doubles.
// Stat.h defines statistics collection for a stream of data.
// (c) 2022-2023 Shawn Silverman
#ifndef STAT_H_
#define STAT_H_
#include <algorithm>
#include <limits>
// Holds statistics for one stream of samples.
template <typename T>
class Stat {
 public:
  // Creates and initializes the stats.
  Stat() {
    reset();
  // Returns the current count.
  uint32_t count() const {
    return count_;
  // Returns the current minimum.
  T min() const {
    return min_;
  // Returns the current maximum.
  T max() const {
    return max_;
  // Returns the current mean.
  float mean() const {
    return mean_;
  // Returns the current variance.
  float var() const {
    return m2_ / count_;
  // Returns the current sample variance.
  float sampleVar() const {
    return m2_ / (count_ - 1);
  // Resets all the stats.
  void reset() {
    count_ = 0;
    min_   = std::numeric_limits<T>::max();
    max_   = 0;
    mean_  = 0.0f;
    m2_    = 0.0f;
  // Updates the statistics with one sample.
  void update(T sample) {
    count_++;
    min_ = std::min(min_, sample);
    max_ = std::max(max_, sample);
    // Welford's online algorithm
    // https://en.wikipedia.org/wiki/Algorithms_for_calculating_variance#Welford's_online_algorithm
    float delta = (sample - mean_);
    mean_ += delta / count_;
    m2_ += delta*(sample - mean_);
 private:
  uint32_t count_;
  T min_;
  T max_;
  float mean_;
  float m2_;  // Aggregates the squared distance from the mean
  // Variance is m2/count and sample variance is m2/(count - 1)
#endif  // STAT_H_
Note: I call this 'Stat' rather than 'Stats' because I think of the final values as coordinates of a single point in some space, i.e. a "stat".
Seems @tonton81 did a buffer class and added stats to them as well
Yes: github.com/tonton81/Circular_Buffer
Circular_Buffer
This is pretty much an advanced version of a circular buffer that follows the STL naming conventions of std::queue,deque,vector, etc...
It supports multiple circular buffer creations without the use of reallocation, new, or malloc. The system uses a template for the configuration of the buffers for the class.
Both circular buffers and circular arrays all support FIFO, LIFO, and MIXED (FIFO+LIFO); This can lead you to design a priority queue system where front entries for priority items and back entries for least priority.
For some reason when I saw that title I was expecting this:
Since you templated the class, I'm wondering why you don't use "T" as type of the mean/m2 and the return type of your value functions? Am I missing something?
Because the mean and variance should be floating point. For example, say you template with an `int` and update with values 2 and 3. The mean is 2.5, not expressible as an `int`. The min and max functions return type T because those select specific values of the stream, which is a list with elements of type T.
(Update: that’s weird. I tried to edit my post in “mobile mode”, and it got deleted. This is a repost. As opposed to a repast, for when you’re hungry.)
