Hi, I'm new to embedded development so please correct me if I'm wrong here.
Currently AudioStream.cpp uses allocate() and release() functions to allocate memory to audio blocks. These functions call __disable_irq() and __enable_irq(), which can lead to problems if the user has disabled interrupts beforehand, since allocating or releasing memory will re-enable interrupts. I discovered it when working on some issues with usb audio transfers, and replacing __disable_irq() and __enable_irq() inside of allocate/release functions with ATOMIC_BLOCK(ATOMIC_RESTORESTATE) from avr-libc util/atomic.h seems to solve this problem. By this I mean
As far as I understood atomic block macro checks global interrupt state when entering its scope, disables interrupts and enables them again only if they were set when entering its scope.
void AudioStream::release(audio_block_t *block)
//if (block == NULL) return;
uint32_t mask = (0x80000000 >> (31 - (block->memory_pool_index & 0x1F)));
uint32_t index = block->memory_pool_index >> 5;
//__disable_irq();
ATOMIC_BLOCK(ATOMIC_RESTORESTATE){
if (block->ref_count > 1) {
block->ref_count--;
//Serial.print("reles:");
//Serial.println((uint32_t)block, HEX);
memory_pool_available_mask[index] |= mask;
if (index < memory_pool_first_mask) memory_pool_first_mask = index;
memory_used--;
//__enable_irq();
