Page 1 of 5 1 2 3 ... LastLast
Results 1 to 25 of 106
Thread: Teensyduino 1.58 Released
    Administrator Paul's Avatar
    Oct 2012
    448
    Teensyduino 1.58 has been released
    Quick summary: Updates ARM toolchain, adds support for MacOS Ventura, and brings many bug fixes and small improvements.
    Support for Arduino IDE 2.0.4 is available by adding this package index URL in File > Preferences.
    https://www.pjrc.com/teensy/package_teensy_index.json
    The change since 1.58-beta4:
    Fix AVR toolchain for Teensy 2.0 with Arduino 2.0.x
    Fix SdVolume compatibility on Teensy 2.0
    USBHost_t36 more cautious date transfer queuing (KurtE)
    Changes since Teensyduino 1.57:
    Updated toolchain to gcc 11.3.1 for Teensy LC, 3.x, 4.x
    Update core library for gcc 11.3.1
    Update Wire library for gcc 11.3.1
    Update teensy_size for gcc 11.3.1
    FlexIO_t4 FlexSerial support more baud rates (KurtE)
    AudioEffectEnvelope fix release name conflict (Jonathan Oakley)
    Add audio DynamicPatching example (Jonathan Oakley)
    Audio design tool fix control name on export (Jonathan Oakley)
    USBHost_t36 improved HID device diagnostic info (KurtE)
    Improve C & C++ library access to Teensy 3 & 4 RTC hardware
    Audio use IntervalTimer for updates if no hardware update available
    automatically create .lst file after linking
    include time.h with Arduino.h
    fix FNET on gcc 11
    update MFRC522
    fix Snooze errors with gcc 11
    update TeensyThreads
    USBHost_t36 bluetooth and HID improvements (KurtE)
    New gcc 11.3.1 toolchain supported on all systems
    Fix compiler warnings, many libraries
    Fix missing serial receive with Arduino 2.0.x on Windows after Teensy reboots
    Fix unable to start Teensy Loader on MacOS Ventura with Arduino 1.8.x
    fix USB MIDI transmit on Teensy 4.x when running at only 12 Mbit/sec speed
    Arduino 2.0.x "Invalid FQBN" workaround
    Print warning message is "serial port" not "teensy port" selected
    Fix Teensy Loader startup problem on Raspberry Pi 4 running Raspbian Buster
    FlexIO / FlexSerial improvements (KurtE)
    USBHost_t36 - update storage examples (KurtE)
    ST7735_t3 - fix screen width check (KurtE)
    C++11 move semantics on File (ScottDuckworth)
    MTP.loop() would wait 1ms with no messages (KurtE)
    Allow unconnected AudioConnection (Jonathan Oakley)
    Fix Serial1.availableForWrite() on Teensy 2.0
    AudioSynthWavetable fixes & docs (Jonathan Oakley)
    USBHost_t36 Bluetooth improvements (KurtE and mjs513)
    Improve String support for 64 bit integers
    Allow programs to override gettimeofday (Shawn Silverman)
    Improve bare (without Serial, Serial1, File) printf() support
    Handle null pointer gracefully in Serial.write(string)
    Fix Serial.write() return value (Shawn Silverman)
    Fix IntervalTimer end() when timer interrupt pending
    Speed up HardwareSerial FIFO size calculation (Shawn Silverman)
    Fix startup with -Os and -Og optimization
    Allow programs to override sbrk (Timo Sandmann)
    Stream String readStringUntil() default to allow unlimited length
    Define WIRE_INTERFACES_COUNT for Arduino compatibility
    Fix TIMSEL field width in FlexIO SHIFTCTL register (squidcc)
    Allow SdVolume to access card, but with deprecated warning
    Fix compiler warnings with -Wextra (Shawn Silverman)
    Change Print::write_error for Arduino compatibility (Shawn Silverman)
    Call yield() from second/third USB serial bool (Geert Uytterhoeven)
    Audio design tool fix import with AudioEffectDelayExternal (Jonathan Oakley)
    Audio design tool import space objects for better visibility (Jonathan Oakley)
    Audio tutorial examples updated for Teensy 4.0
    Aduio examples updated with comments for Teensy 4 hardware
    USBHost_t36 fix compiler warnings
    USBHost_t36 improve startup on USB disks (Warren Watson)
    USBHost_t36 fix USB disks endpoint issue (jmarsh)
    USBHost_t36 fix Ant+ infinite loop (Gbertaz)
    USBHost_t36 fix compiler warning (Jonathan Oakley)
    USBHost_t36 support more Xbox One controllers (Dave Madison)
    USBHost_t36 support CP2105 USB serial (jammerx19)
    ILI9488_t3 support multiple displays (mjs513)
    ILI9488_t3 update Digitizer4 example (KurtE)
    LittleFS fix FRAM on alternate SPI ports (mjs513)
    RA8875 fix fft_example2 example
    WS2812Serial Remove 400 Hz refresh rate limit
    XPT2046_Touchscreen further document alternate SPI ports
    Linux warning if 00-teensy.rules missing
    New York
    8,760
    Install went fine - no issues.
    Did rerun a couple of tests using the Quad Encoder basic sketch on a MM and @luni's EncoderSim on a T4.1, which worked no issues.
    Second quick test I ran was the resolution of the issue with some USB drives not working (@wwatson fix) as well as the resolution of the issue with MIDI/USB/HUB that was fixed with @KurtE and @jmarsh fixes
    Senior Member skpang's Avatar
    Jan 2015
    UK
    242
    Install, compile and upload ok on Mac Studio with Ventura 13.3
    11,795
    Installed on Ubuntu 22.04 - Note: yesterday I was forced to reinstall Ubuntu on that machine... But I guess this time I can not blame Ubuntu as the hard disk failed
    Booting off of USB stick and running the diskcheck failed...
    But after I completed that I installed 2.0... Nightly build - has some nicer fixes since 2.0.4. Installed the released Teensy version
    Note: It would not program a teensy as I had not installed the udev rules. Wish with 2.x version the install could do this automatically!
    But downloaded it did the sudo cp... Now fully works.
    But Suggestion: on the Teensyduino install page: https://www.pjrc.com/teensy/td_download.html
    You may want to add something in the newer stuff talking about Arduino 2.x installs about the udev rules on linux.
    Windows 11:
    Update from my postings on the Beta 4 page on not working on Windows. Fixed
    In this case it was not the Antivirus, that caused the issue. What happened was that I updated the preferences to use the correct file and not yesterdays temporary test file (additional boards).
    Note: I had done a build and Teensy app was running. This time instead of selecting to use a different version like 1.57.2, I instead tried to simply uninstall teensy and reinstall.
    So when I did the uninstall, it tried to remove all of the Teensy stuff from C:\Users\kurte\AppData\Local\Arduino15\packages\te ensy\tools\teensy-tools\1.58.0
    But Teensy.exe was in use, so the directory (and the app) were not removed. So then when I said to install Teensy 1.58, the installer said that the tools were already installed and did not install all of the rest of the tools... Fixed by: choosing 1.57.2 (which was in the same state), I deleted all other version out of the directory: C:\Users\kurte\AppData\Local\Arduino15\packages\te ensy\tools\teensy-tools and then told it to update. So it then properly installed all of the tools
    4,462
    You might or might not want to update the following line in https://www.pjrc.com/teensy/td_download.html:
    Teensyduino 1.57 supports Arduino versions 1.8.5 and 1.8.9 and 1.8.13 and 1.8.15 and 1.8.16 and 1.8.19.
    28,474
    Updated the supported versions footnotes.
    How can this happen? (1.58 and also 1.57 do it)
    First these screen shots say a lot:
Name:	Screenshot 2023-03-31 183415.jpg
Name:	Screenshot 2023-03-31 183527.png
    I deliberately erased a semicolon in the source file, but instead of a compiler error message I got that message.
    From the windows explorer screenshot, you can see the directory with all those numbers in it does not exist.
    Normally it would be there and have the .hex and the .elf and all those other files that get generated.
    I have a tenuous grasp of how teensyduino and the IDE interact. I have been having random problems with this file not found,
    and often it happens on the compile AFTER I had an error in a previous upload (but not after every error, thus 'random').
    If this is definitely not a teensyduino issue, I plan to report it on the Arduino board. Just want to be sure.
    - Wes, W5ZZO
    11,795
    Maybe something runs in background that cleanup stuff on disk, like temp folder…. And it cleaned this out. Been there done that…
    IDK, there's around another 1 GB in there, so this mystery daemon needs to shake a tail feather if it's of a mind to break everything.
    I am guessing that the IDE creates the directories and invokes the Teensy loader after generating the .hex file?
    I have a real issue, but who owns the problem is the question.
    - Wes, W5ZZO
    17,435
    Does it reproduce? In any other situation, i.e. alternate sketch?
    Does it work properly with the ';' in its place?
    If a missing ';' is really there, it should throw a build error - note it and not attempt to upload.
    28,474
    Quote Originally Posted by W5ZZO View Post
    Before contacting the Arduino developers, can you give us a bit more info. Maybe it is a problem with the Teensy utilities.
    Two questions...
    1: Turn on verbose output (both compiling and upload) in File > Preferences. Does Arduino IDE give more info about the exact command it tried to run before this error?
    2: Can you give us a sample program which reproduces the problem?
    I'll try the verbose output route first. If I could get a reliable test case discovered this would be easy.
    - Wes
    This is as fresh as I could make it. I deleted a curly brace and got the expected cascade of errors. I replaced the brace and recompiled the program (I can upload it if wanted, eventually I will release this one anyway).
    This is very curious, as the entire directory appears to have been created, then deleted.
Name:	Screenshot 2023-04-01 080225.png
Name:	Screenshot 2023-04-01 075349.png
    Using board 'teensy41' from platform in folder: C:\Users\BobbaFett\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.0
    Using core 'teensy4' from platform in folder: C:\Users\BobbaFett\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.0
    Detecting libraries used...
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\sketch\\6800Emu.ino.cpp" -o nul
    Generating function prototypes...
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\sketch\\6800Emu.ino.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/precompile_helper" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0/cores/teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0/cores/teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch/Arduino.h" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch/Arduino.h.gch"
    Using previously compiled file: C:\Users\BobbaFett\AppData\Local\Temp\arduino\sketches\3226CF8D12A4BC5AE371E1AE69289286\pch\Arduino.h.gch
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\sketch\\6800Emu.ino.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\sketch\\6800Emu.ino.cpp.o"
    Compiling libraries...
    Compiling core...
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\AudioStream.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\AudioStream.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial8.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial8.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial1.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial1.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\Print.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\Print.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\CrashReport.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\CrashReport.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\DMAChannel.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\DMAChannel.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial3.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial3.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial2.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial2.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\IPAddress.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\IPAddress.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial5.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial5.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial4.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial4.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\IntervalTimer.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\IntervalTimer.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial6.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial6.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\EventResponder.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\EventResponder.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\HardwareSerial7.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial7.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\WMath.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\WMath.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\Tone.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\Tone.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\Time.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\Time.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\Stream.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\Stream.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\analog.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\analog.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\WString.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\WString.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\bootdata.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\bootdata.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\clockspeed.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\clockspeed.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\debugprintf.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\debugprintf.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\delay.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\delay.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\digital.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\digital.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\eeprom.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\eeprom.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\extmem.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\extmem.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\fuse.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\fuse.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\interrupt.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\interrupt.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\keylayouts.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\keylayouts.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\libc.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\libc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\main.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\main.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\memcpy-armv7m.S" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\memcpy-armv7m.S.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\memset.S" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\memset.S.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\new.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\new.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\nonstd.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\nonstd.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\pwm.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\pwm.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\rtc.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\rtc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent1.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent1.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent2.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent2.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent3.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent3.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent4.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent4.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent5.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent5.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent6.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent6.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent7.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent7.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEvent8.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent8.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEventUSB1.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEventUSB1.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\serialEventUSB2.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEventUSB2.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_alloc_valid.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_alloc_valid.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_free.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_free.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_calloc.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_calloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_hash.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_hash.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_malloc.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_malloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_malloc_stats.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_malloc_stats.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_pool.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_pool.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_realloc.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_realloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_realloc_i.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_realloc_i.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_realloc_move.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_realloc_move.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_szalloc.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_szalloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_util.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_util.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\sm_zalloc.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_zalloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\startup.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\startup.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\tempmon.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\tempmon.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_audio.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_audio.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_desc.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_desc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_flightsim.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_flightsim.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_inst.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_inst.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_keyboard.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_keyboard.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_joystick.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_joystick.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_midi.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_midi.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_mouse.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_mouse.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_mtp.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_mtp.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_rawhid.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_rawhid.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_seremu.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_seremu.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_serial.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_serial.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_serial2.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_serial2.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_serial3.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_serial3.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\usb_touch.c" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_touch.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/pch" "-IC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4\\yield.cpp" -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\yield.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\AudioStream.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\CrashReport.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\DMAChannel.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\EventResponder.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial1.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial2.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial3.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial4.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial5.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial6.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial7.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\HardwareSerial8.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\IPAddress.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\IntervalTimer.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\Print.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\Stream.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\Time.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\Tone.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\WMath.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\WString.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\analog.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\bootdata.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\clockspeed.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\debugprintf.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\delay.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\digital.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\eeprom.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\extmem.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\fuse.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\interrupt.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\keylayouts.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\libc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\main.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\memcpy-armv7m.S.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\memset.S.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\new.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\nonstd.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\pwm.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\rtc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent1.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent2.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent3.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent4.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent5.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent6.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent7.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEvent8.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEventUSB1.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\serialEventUSB2.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_alloc_valid.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_calloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_free.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_hash.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_malloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_malloc_stats.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_pool.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_realloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_realloc_i.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_realloc_move.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_szalloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_util.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\sm_zalloc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\startup.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\tempmon.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_audio.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_desc.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_flightsim.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_inst.cpp.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_joystick.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_keyboard.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_midi.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_mouse.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_mtp.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_rawhid.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_seremu.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_serial.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_serial2.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_serial3.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\usb_touch.c.o"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\core.a" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\core\\yield.cpp.o"
    Archiving built core (caching) in: C:\Users\BobbaFett\AppData\Local\Temp\arduino\cores\teensy_avr_teensy41_usb_serial,speed_600,opt_o2std,keys_en-us_cf6ab48901ef4bce8552275a6ec029a1\core.a
    Linking everything together...
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.0\\cores\\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.elf" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286\\sketch\\6800Emu.ino.cpp.o" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/core\\core.a" "-LC:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286" -larm_cortexM7lfsp_math -lm -lstdc++
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.elf" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.eep"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.elf" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.hex"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/teensy_secure" encrypthex TEENSY41 "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.hex"
    No key .pem file found, skipping .ehex encryption
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/teensy_post_compile" -file=6800Emu.ino "-path=C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286" "-tools=C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/" -board=TEENSY41
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/stdout_redirect" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.sym" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.elf"
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/teensy_size" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.elf"
    Memory Usage on Teensy 4.1:
      FLASH: code:62284, data:12236, headers:8420   free for files:8043524
       RAM1: variables:78656, code:59648, padding:5888   free for local variables:380096
       RAM2: variables:12416  free for malloc/new:511872
    "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/stdout_redirect" "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.lst" "C:\\Users\\BobbaFett\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduino\\sketches\\3226CF8D12A4BC5AE371E1AE69289286/6800Emu.ino.elf"
    Compiled sketch not found in C:\Users\BobbaFett\AppData\Local\Temp\arduino\sketches\3226CF8D12A4BC5AE371E1AE69289286
    11,795
    Strange!
    Sorry in advance I am just throwing out darts, to see if we can get any clues on what is going on.
    Which Arduino 2.x build are you using? 2.0.4? If older version, might try update... Doubt will make any difference. Note I am mostly running the nightly builds as there are some fixes since 2.0.4 that I want.
    By file names obviously Windows. 10? 11?
    When this happens is the directories like in the case above: C:\\Users\\BobbaFett\\AppData\\Local\\Temp\\arduin o\\sketches\\3226CF8D12A4BC5AE371E1AE69289286
    totally gone? Or only some files?
    Are you running some antivirus software? If so which one?
    If so, might try checking a couple of things:
    a) if it is running something like an active-scan that looks at all newly created files and ones it does not like, either deletes or moves into "Quarantine"? If something like that is running, you might check it's logs and or if it can display a list of the current quarantined files. And see if anything was flagged...
    b) Might try a quick file test to see if thinks you may have a virus. Hopefully not.
    Sorry I know not much help
    Edit: Another random thought... Name of the sketch starts with numbers. Perfectly valid (I believe), but I know that in some builds of Arduino 2.x, the developers were starting to try in enforce some rules on naming, and for example sketch names can not contain a blank nor start with an _ ...
    And there were several issues with that, but as far as I know, this was either sketch did not show up in the list or did not compile... SO again a real long shot.... But wondering if you changed the name to start with a letter does it still reproduce?
    New York
    8,760
    @W5ZZO
    As @KurtE said - strange. Think you should just break down and post your sketch. Tried just haphazardly removing semi-colons but as @defragster said the IDE always gives me a compile error.
    Sep 2020
    Massachusetts
    229
    My project using sm_malloc on Teensy 4.1 is blowing up.
    Just asking, has something major changed there?
    Thanks,
    Ben
    28,474
    Nope, no changes to sm_malloc.
    But we did upgrade from gcc 5.4.1 to gcc 11.3.1, so the same code is getting built by a newer compiler.
    11,795
    Quote Originally Posted by blakeAlbion View Post
    Thanks,
    Ben
    I assume this is the issue you posted about in a couple of other threads?
    I will try to look for one of my T4.1's with one memory chip on it...
    OK. I am using IDE 2.0.4 with teensyduino 1.58 on Windows 10, on a machine with 300 GB (2/3) of the SSD free.
    I will attach the sketch.
    I am not sure about the timing of this issue (whether it started with 2.0.4) because this is the only thing I have worked on for a few weeks.
    The real issue is not the no-error compile, but the missing output files. I have verified that without closing the IDE or Teensyduino that the directory is totally absent. When I have a successful build (probably 3 of 4 times even after compile errors) it is there afterwards, and has all the expected outputs in it.
    - Wes, W5ZZO
    6800Emu.zip
    17,435
    sketch builds and uploads and runs as provided in p#19.
    removed a ';' in setup() and expected error halted build.
    Where was syntax fail edit made for repro? It is a multi .INO and file program.
    Parsing of source can get confused depending on where it is.
    Perhaps make a zip in the failed edit state and upload for direct compare/repro.
    New York
    8,760
    @W5ZZO @defragster
    I will confirm that I compiled with IDE 2.0.5 nightly 3.11.23 with out issue. Even if I randomly removed semi-colons it would throw an error message. So not seeing what you are seeing.
    There are a couple of things that come to mind:
    1. you have a corrupted install of the Arduino IDE
    2. you have a corrupted install of the Teensy Cores.
    11,795
    Like the others not seeing this...
    other longshot thoughts:
    A few days ago I was getting some strange compiler errors... I finally fixed it by clearing out a lot of junk out of the temp directory.
    There are some existing Arduino issues that they are not cleaning up the temporary directory very well and leaving lots of files. Recently I believe they integrated in at least one that cleaned up some stuff, and I know that there are some others pending. Butt ogive you an idea, yesterday I cleaned out a lot of this stuff, and for example if you
    browse to %temp%
    So things I cleared out of temp
    I currently have > 100 files *.clangd (There is an open issue not leave all of these...)
    I also removed all of the directories that started with the name arduino.
    names like arduino-ide2-<quid>
    arduino-language-server<numbers>
    There are also probably lots of others as well.
    When I cleaned out most of temp, my compiler issue went away...
    Also a few days ago I was having problems building Ubuntu, plus several other things not working. Turned out my hard disk was going bad. I finally ran a linux utility, which confirmed it. So if you have not done so in awhile, you might want to run something like scandisk, to make sure something is either not corrupted or failing.
    I don't keep all those old versions, but to answer your question I am pretty sure I edited the main (6800Emu.ino) file.
    I ended up with all those .ino files because I was trying to share a multi-dimension array without declaring the first dimension in a #external line. I learned it just won't work.
    But with the multiple .ino files I get to divide my code by topic and the compiler puts it all together. I suspect this would compile if I changed all the names to end in .c or .cpp
    but why bother now?
    - Wes
    17,435
    without a reliable repro there - and the code that does it for others to attempt it seems a build software or machine problem that might resolve as noted above with cleanup or remove and reinstall.
    It is very odd not seen or seen as reported, but odd things happen with corrupted files or installed tool sets.
    I figured out how I got the compile to happen with the missing semi-colon. I have autosave set to 6 seconds in my preferences.
    It's probably an omission or a bug, but you can run "compile" or "upload" with a dirty file... you won't get prompted to save, and the disk image is yet unchanged.
    That is masking what is the real problem, and that is that the directory for the project outputs gets deleted prior to teensyduino obtaining the .hex file. This seems to happen mostly after there was a failed compilation, and you fix the issue and try a new compilation.
    That said, if none of you can reproduce this, the odds of anyone ever looking at it and fixing it are pretty slim.
    - Wes, W5ZZO
