//#include <Arduino.h>
#include <USBHost_t36.h>
#include "usbh_common.h"
#include "razersb.h"
static USBHost myusb;
static USBHub hub1(myusb);
static RazerSB razersb(myusb);
// #define print Serial.println
#define println Serial.println
typedef struct _sb {
Device_t *device;
Pipe_t *txpipe;
Pipe_t *rxpipe;
uint16_t tx_size; // wMaxPacketSize
uint16_t rx_size; // wMaxPacketSize
uint8_t tx_ep;
uint8_t rx_ep;
uint8_t tx_ep_adr;
uint8_t rx_ep_adr;
int32_t pipeType;
int32_t pipeDir;
uint8_t rxpacket[4];
USBDriver *driver;
}razerdev_t;
static razerdev_t razerdev[10];
#define LIBSBUI_EP_DISPLAY_PAD 0x01
#define LIBSBUI_EP_DISPLAY_KEYS 0x02
#define LIBSBUI_EP_IN_TOUCH 0x81
#define LIBSBUI_EP_IN_KEYS 0x82
#define LIBSBUI_EP_IN_DONTKNOW 0x83
#define RAZERSB_INT_0 0
#define RAZERSB_INT_DISPLAY_PAD 1
#define RAZERSB_INT_DISPLAY_KEYS 2
#define RAZERSB_INT_INPUT_TOUCH 3
#define RAZERSB_INT_INPUT_KEYS 4
volatile static int klen = 0;
volatile static int tlen0 = 0;
volatile static int tlen = 0;
void usb_start ()
myusb.begin();
void usb_task ()
myusb.Task();
void razersb_setCallbackFunc (int (*func)(uint32_t msg, intptr_t *value1, uint32_t value2))
razersb.callbackFunc = func;
void RazerSB::init ()
lineLength = 0;
start = 0;
callbackFunc = NULL;
//contribute_Pipes(mypipes, sizeof(mypipes)/sizeof(Pipe_t));
contribute_Transfers(mytransfers, sizeof(mytransfers)/sizeof(Transfer_t));
driver_ready_for_device(this);
void RazerSB::Task ()
//println("RazerSB Task: enum_state = ", device->enum_state);
//Serial.printf("RazerSB Task: enum_state %d\r\n", device->enum_state);
if (device->enum_state == USBH_ENUMSTATE_END){ // 15
if (!start){
start = millis();
}else if (millis() - start > 2500){ // display startup time
device->enum_state++;
driverReady();
void RazerSB::driverReady ()
// println("RazerSB driverReady = ", (uint32_t)this, HEX);
if (callbackFunc)
(*callbackFunc)(USBD_MSG_DEVICEREADY, NULL, 0);
// type 0: claim complete device
// type 1: claim per interface
bool RazerSB::claim (Device_t *dev, int type, const uint8_t *descriptors, uint32_t len)
// only claim at interface level
if (type != 1) return false;
if (dev->idVendor != RAZERSB_VID || dev->idProduct != RAZERSB_PID){
//println(" device is not a RazerSB");
return false;
}else{
//println(" found a RazerSB");
device = dev;
//Serial.printf("\r\n\r\n\r\n###############\r\nRazerSB claim this %p\r\n", (uint32_t)this);
//Serial.printf("claimType = %d\r\n", type);
//Serial.printf("idVendor = %X\r\n" , dev->idVendor);
//Serial.printf("idProduct = %X\r\n" , dev->idProduct);
const uint8_t *p = descriptors;
const uint8_t *end = p + len;
// http://www.beyondlogic.org/usbnutshell/usb5.shtml
int descriptorLength = p[0];
int descriptorType = p[1];
//Serial.printf("descriptorType = %d\r\n", descriptorType);
//Serial.printf("descriptorLength = %d\r\n", descriptorLength);
if (!descriptorLength){
//Serial.printf("3\r\n");
return false;
if (descriptorType != USBH_DESCRIPTORTYPE_INTERFACE /*|| descriptorLength != 9*/){
//Serial.printf("2\r\n");
return false;
//descriptor_interface_t *interface = (descriptor_interface_t*)&p[0];
//Serial.printf("bInterfaceClass = %d\r\n", interface->bInterfaceClass);
//Serial.printf("bInterfaceSubClass = %d\r\n", interface->bInterfaceSubClass);
//if (interface->bInterfaceClass != USBH_DEVICECLASS_VENDOR || interface->bInterfaceSubClass != 0)
// return false;
//println(" Interface is RazerSB");
p += descriptorLength; // == sizeof(descriptor_interface_t)
rx_ep = 0;
tx_ep = 0;
//int interfaceCt = 0;
while (p < end){
int interfaceLength = p[0];
if (p + interfaceLength > end){
//Serial.printf("1\r\n");
return false; // reject if beyond end of data
int interfaceType = p[1];
//Serial.printf(":: interfaceType = %d\r\n", interfaceType);
if (interfaceType == USBH_DESCRIPTORTYPE_ENDPOINT){
println(" ");
//Serial.printf("interface number : %d\r\n", interfaceCt++);
//Serial.printf("interfaceType = %d\r\n", interfaceType);
//Serial.printf("interfaceLength = %d\r\n", interfaceLength);
descriptor_endpoint_t *endpoint = (descriptor_endpoint_t*)&p[0];
//Serial.printf("bEndpointAddress = %X\r\n", endpoint->bEndpointAddress);
//Serial.printf("bmAttributes = %X\r\n", endpoint->bmAttributes);
//Serial.printf("wMaxPacketSize = %d\r\n", endpoint->wMaxPacketSize);
//Serial.printf("bInterval = %d\r\n", endpoint->bInterval);
//const int pipeType = endpoint->bmAttributes&0x03;
//const int pipeDir = (endpoint->bEndpointAddress&0x80) >> 7;
// type: 0 = Control, 1 = Isochronous, 2 = Bulk, 3 = Interrupt
//Serial.printf(" endpoint type : %d\r\n", pipeType);
//Serial.printf(" endpoint dir : %d\r\n", pipeDir);
//Serial.printf(" endpoint addr : %X\r\n", endpoint->bEndpointAddress/*&0x0F*/);
if (endpoint->bEndpointAddress == LIBSBUI_EP_DISPLAY_PAD && endpoint->wMaxPacketSize == 512){
razerdev_t *rdev = &razerdev[RAZERSB_INT_DISPLAY_PAD];
rdev->device = dev;
rdev->tx_ep = endpoint->bEndpointAddress&0x0F;
rdev->tx_size = endpoint->wMaxPacketSize;
rdev->pipeType = endpoint->bmAttributes&0x03;
rdev->pipeDir = (endpoint->bEndpointAddress&0x80) >> 7;
if (!rdev->txpipe)
rdev->txpipe = new_Pipe(rdev->device, rdev->pipeType, rdev->tx_ep, rdev->pipeDir, rdev->tx_size);
//Serial.printf("### pad rdev->txpipe = %p\r\n", rdev->txpipe);
rdev->driver = this;
}else if (endpoint->bEndpointAddress == LIBSBUI_EP_DISPLAY_KEYS && endpoint->wMaxPacketSize == 512){
razerdev_t *rdev = &razerdev[RAZERSB_INT_DISPLAY_KEYS];
rdev->device = dev;
if (!rdev->txpipe)
//Serial.printf("### keys rdev->txpipe = %p\r\n", rdev->txpipe);
#if 0
else if (endpoint->bEndpointAddress == LIBSBUI_EP_IN_TOUCH && endpoint->wMaxPacketSize == 64){
razerdev_t *rdev = &razerdev[RAZERSB_INT_INPUT_TOUCH];
rdev->device = dev;
rdev->rx_ep = endpoint->bEndpointAddress&0x0F;
rdev->rx_size = endpoint->wMaxPacketSize;
rdev->rxpipe = new_Pipe(rdev->device, rdev->pipeType, rdev->rx_ep, rdev->pipeDir, rdev->rx_size, endpoint->bInterval);
if (rdev->rxpipe){
rdev->rxpipe->callback_function = rx_callback_touch;
queue_Data_Transfer(rdev->rxpipe, rdev->rxpacket, rdev->rx_size, this);
}else if (endpoint->bEndpointAddress == LIBSBUI_EP_IN_KEYS){
razerdev_t *rdev = &razerdev[RAZERSB_INT_INPUT_KEYS];
rdev->device = dev;
if (rdev->rxpipe){
rdev->rxpipe->callback_function = rx_callback_keys;
//queue_Data_Transfer(rdev->rxpipe, rdev->rxpacket, rdev->rx_size, this);
}else if (endpoint->bEndpointAddress == LIBSBUI_EP_IN_TOUCH && endpoint->wMaxPacketSize == 8){
razerdev_t *rdev = &razerdev[RAZERSB_INT_0];
rdev->device = dev;
if (rdev->rxpipe){
rdev->rxpipe->callback_function = rx_callback_touch0;
}else if (0){
razerdev_t *rdev = &razerdev[interfaceCt];
rdev->device = dev;
if (rdev->rxpipe){
p += interfaceLength;
//Serial.printf(" endpoint txpipe : %d\r\n", (uint32_t)txpipe);
//Serial.printf(" endpoint rxpipe : %d\r\n", (uint32_t)rxpipe);
//Serial.printf("***********************************************\r\n");
return true;//(rxpipe || txpipe);
#if 0
static int tx_state = 0;
void RazerSB::tx_callback (const Transfer_t *transfer)
//// println("RazerSB tx_callback");
if (transfer->driver){
if (tx_state == -1){
//// println("RazerSB tx_callback tx_state ", tx_state);
((RazerSB*)(transfer->driver))->drawScreenSetup();
}else if (tx_state == 1){
tx_descript_t *context = &((RazerSB*)(transfer->driver))->tx_writeCtx;
int ret = (*((RazerSB*)(transfer->driver))->callbackFunc)(USBD_MSG_WRITEREADY, (intptr_t*)context, 0);
if (ret){
//printf("tx_callback %i %i\r\n", (int)context->frame, (int)context->row);
((RazerSB*)(transfer->driver))->writeData(context->buffer, context->len);
context->row += context->rows;
}else{
tx_state = 0;
(*((RazerSB*)(transfer->driver))->callbackFunc)(USBD_MSG_WRITEEND, (intptr_t*)context, 0);
void dump (char *buffer, int len)
for (int j = 0; j < len; j++)
Serial.printf("%.2x ", buffer[j]);
Serial.printf("\r\n");
#if 0
void RazerSB::rx_callback_touch0 (const Transfer_t *transfer)
//println("RazerSB rx_callback_touch0");
//((RazerSB *)(transfer->driver))->new_data(transfer);
int32_t len = transfer->length - ((transfer->qtd.token >> 16) & 0x7FFF);
Serial.printf("rx_callback_touch0 %d\r\n", len);
//dump((char*)transfer->buffer, len);
queue_Data_Transfer(rdev->rxpipe, rdev->rxpacket, len, rdev->driver);
if (len < 1 || len > 8){
//razerdev_t *rdev = &razerdev[RAZERSB_INT_0];
//queue_Data_Transfer(rdev->rxpipe, rdev->rxpacket, 8, rdev->driver);
tlen0 = 0;
}else{
tlen0 = len;
void RazerSB::rx_callback_touch (const Transfer_t *transfer)
//println("RazerSB rx_callback_touch");
Serial.printf("rx_callback_touch %d\r\n", len);
if (len < 1 || len > 64){
//razerdev_t *rdev = &razerdev[RAZERSB_INT_INPUT_TOUCH];
//queue_Data_Transfer(rdev->rxpipe, rdev->rxpacket, 64, rdev->driver);
tlen = 0;
}else{
tlen = len;
void RazerSB::rx_callback_keys (const Transfer_t *transfer)
//println("RazerSB rx_callback_keys");
Serial.printf("rx_callback_keys %d\r\n", len);
if (len < 1 || len > 16){
//razerdev_t *rdev = &razerdev[RAZERSB_INT_INPUT_KEYS];
//queue_Data_Transfer(rdev->rxpipe, rdev->rxpacket, 16, rdev->driver);
klen = 0;
}else{
klen = len;
void RazerSB::control (const Transfer_t *transfer)
// println("RazerSB control()");
void RazerSB::disconnect ()
// println("RazerSB disconnect()");
// TODO: free resources
device = NULL;
start = 0;
lineLength = 0;
bool RazerSB::usb_control_msg (Device_t *dev, uint32_t orequestType, uint32_t omsg, uint32_t ovalue, uint32_t oindex, void *buff, uint32_t len)
setup_t setup;
mk_setup(setup, orequestType, omsg, ovalue, oindex, len);
return queue_Control_Transfer(dev, &setup, buff, NULL);
bool RazerSB::usb_bulk_write (USBDriver *drv, Pipe_t *pipe, const void *buffer, const uint32_t len)
//printf("usb_bulk_write %i\r\n", len);
return queue_Data_Transfer(pipe, (void*)buffer, len, drv);
int RazerSB::writeData (void *data, const size_t size)
//__disable_irq();
//NVIC_DISABLE_IRQ(IRQ_USBHS);
int ret = usb_bulk_write(this, rdev->txpipe, data, size);
//NVIC_ENABLE_IRQ(IRQ_USBHS);
//__enable_irq();
return ret;
volatile uint16_t swap16 (const uint16_t src)
volatile unsigned char *tmp = (unsigned char*)&src;
return (tmp[0] << 8 | tmp[1]);
int razersb_writeImage (sbuiwriteop_t *idesc, void *pixelData)
return razersb.writeImage(idesc, pixelData);
// todo: int RazerSB::writeImage (sbuiwriteop_t *idesc, void *pixelData, flags)
int RazerSB::writeImage (sbuiwriteop_t *idesc, void *pixelData)
uint16_t header[6];
header[0] = swap16(1);
header[1] = swap16(idesc->left);
header[2] = swap16(idesc->top);
header[3] = swap16(idesc->right);
header[4] = swap16(idesc->bottom);
header[5] = header[0] ^ header[1] ^ header[2] ^ header[3] ^ header[4];
if (writeData((void*)header, sizeof(header))){
delayMicroseconds(500);
sbuiwriteop_t r = *idesc;
const int len = ((r.right - r.left)+1) * ((r.bottom - r.top)+1) * 2;
int ret = writeData((uint8_t*)pixelData, len);
// ISV requires at least 18ms to complete the write otherwise jittering will occur
// if your design does not allow successive calls within this period, then this delay may not be necessary
delay(19);
//arm_dcache_flush((void*)pixelData, len); // shouldn't be here
return (ret == len);
return 0;
