clearskyer
Hi ! Im aiming at building a step sequencer ! I come here in a total state of humbleness, absolutely no code experience here hehe.
For now, im just trying to add an encoder to increase and decrease the BPM and its been already 2 full days on that with no result hehe.
1- Can anyone could help me with the issue in that code ?
2- Also i was wondering which path should i take to achieve the tighter, stable and efficient clock for a musical sequencer. For now im guessing between timerOne and uClock ? But maybe there are better ways ?
Teensy 4.1
Thanks a lot !
My code for now:
#include <TimerOne.h>
// Define the initial BPM and the corresponding interval in microseconds
int bpm = 120;
int interval_micros = (60000000 / bpm);
// Define the pins for the encoder inputs
#define ENCODER_PIN_A 33
#define ENCODER_PIN_B 34
// Define the pin for the clock output
#define CLOCK_PIN 23
// Initialize the timer interrupt
void timerISR() {
static boolean state = false;
digitalWrite(CLOCK_PIN, state);
state = !state;
pinMode(CLOCK_PIN, OUTPUT);
pinMode(ENCODER_PIN_A, INPUT_PULLUP);
pinMode(ENCODER_PIN_B, INPUT_PULLUP);
// Attach interrupt to the encoder pins
attachInterrupt(digitalPinToInterrupt(ENCODER_PIN_A), encoderISR, CHANGE);
attachInterrupt(digitalPinToInterrupt(ENCODER_PIN_B), encoderISR, CHANGE);
// Set up Timer1 to generate interrupts at the initial interval
Timer1.initialize(interval_micros);
Timer1.attachInterrupt(timerISR);
// do nothing
// Interrupt service routine for the encoder pins
void encoderISR() {
static int encoder_pos = 0;
int new_encoder_pos = encoder_pos;
if (digitalRead(ENCODER_PIN_A) == digitalRead(ENCODER_PIN_B)) {
new_encoder_pos--;
new_encoder_pos++;
if (new_encoder_pos > encoder_pos) {
// Encoder turned clockwise
bpm++;
} else if (new_encoder_pos < encoder_pos) {
// Encoder turned counterclockwise
bpm--;
encoder_pos = new_encoder_pos;
// Constrain the BPM to reasonable values
bpm = constrain(bpm, 30, 240);
// Update the interval based on the new BPM
Timer1.setPeriod(interval_micros);
BTW: I know that the encoder physically working since I've tested it with the serial monitor.
Teensy 4.1
Thanks a lot !
My code for now:
int bpm = 120;
void timerISR() {
state = !state;
// do nothing
void encoderISR() {
new_encoder_pos--;
new_encoder_pos++;
bpm++;
bpm--;
