I have a board with a Teensy 4.1 that is powered by a 5VDC power supply to VIN. However, I have been upgrading the firmware through the Teensy's USB (while also powered from VIN) numerous times without a problem ....
I understand that it is not recommended. But what may happen to the Teensy 4.1 if it is powered from both the USB cable and VIN input at the same time?
Will this potentially damage the Teensy, or the USB port or both?
Is the likelihood of damage high?
Thanks.
Thanks.
