Teensy is connected with Processing software.
In Processing I read data from serial1 and I send other data to serial.
It works fine with Teensy 3.5
I do the same thing with Teensy 4.1, but it doesn't work.
After ports displayed, I have an error message
[0] "/dev/cu.Bluetooth-Incoming-Port"
[1] "/dev/cu.usbmodem116574201"
[2] "/dev/cu.usbserial-0001"
[3] "/dev/tty.Bluetooth-Incoming-Port"
[4] "/dev/tty.usbmodem116574201"
[5] "/dev/tty.usbserial-0001"
Error, disabling serialEvent() for /dev/cu.usbmodem116574201
null
According to this error message the data of serialEvent() would come from serial1 and not from serial.
In teensy I set
serial "dev/cu.usbmodem116574201" is to send data to the Teensy 4.1
serial1 "/dev/cu.usbserial-0001" is to read from the UART connected to the Teensy 4.1
with this bauds
Serial.begin (115200);
Serial1.begin (100000);
Here the program from Processing
import processing.serial.*;
Serial encoderReceiveUSBport101; // The serial1 port. I read data from serial1 in serialEvent sending
Serial teensyport; // serial port. I send data to teensy with serial
int [] formerFrameCountFromSerialEvent =new int[6]; //;
int formeFrame;
int encodeur[]= new int[6]; //
int dataTosendToSerial[] = new int [6]; //
public void settings() {
size(600, 600, P3D);
frameRate(15);
for (int i = 0; i < 6; i++) {
dataTosendToSerial= 0;
fill(255, 0, 0, 50);
frameRate(15);
printArray(Serial.list()); // print serial port
println("Start port setup");
setPort();
void draw() {
if (frameCount ==5) noLoop();
if (frameCount >=5) { printArray(encodeur);}
if (frameCount >= 15 ){
println ( frameCount);
dataTosendToSerial-= 100;
println("send actual datas");
send24DatasToTeensy6motors(10, -3, -3, -1);
else println("send before datas");
void setPort() {
String[] ports = Serial.list();
//*************** TEENSY connected with serial
teensyport = new Serial(this, ports[1], 115200);//
//*************** TEENSY connected with serial1
encoderReceiveUSBport101 = new Serial(this,ports[2], 1000000); //
// Read bytes into a buffer until you get a linefeed (ASCII 10):
encoderReceiveUSBport101.bufferUntil('\n');
void send24DatasToTeensy6motors(int accelerationRatio, int driver0_On_Off, int computeData, int eraseProcessingData) { // dataMarkedToTeensyArevoir
String dataFromMode;
dataFromMode ="<"
+ dataTosendToSerial[5]+ ","+ dataTosendToSerial[4]+ ","+ dataTosendToSerial[3]+","+ dataTosendToSerial[2]+ ","
+ dataTosendToSerial[1]+ ","+ dataTosendToSerial[0] + "," //
+0+","+0+","+0+","+0+","
+ accelerationRatio +","+ driver0_On_Off +","+ computeData +","+ eraseProcessingData + ","
+0+","+0+","+0+","+0+","+0+","+0+","
+0+","+0+","+0+","+0+">";
teensyport.write(dataFromMode);
// serialEvent method is run automatically by the Processing applet
// whenever the buffer reaches the byte value set in the bufferUntil()
// method in the setup():
void serialEvent(Serial encoderReceiveUSBport101) {
String myEncodeur = encoderReceiveUSBport101.readStringUntil('\n');
myEncodeur = trim(myEncodeur);
int values[] = int(split(myEncodeur, ',')); // dispatch receive datas splited with ,
if (values.length == 6) {// encodeur de 0 a 4000
encodeur[0] = (int) map (values[0], 0, 4000, 0, 800)%800;
encodeur[1] = (int) map (values[1], 0, 4000, 0, 800)%800;
encodeur[2] = (int) map (values[2], 0, 4000, 0, 800)%800;
encodeur[3] = (int) map (values[3], 0, 4000, 0, 800)%800;
encodeur[4] = (int) map (values[4], 0, 4000, 0, 800)%800;
encodeur[5] = (int) map (values[5], 0, 4000, 0, 800)%800;
Thanks for helping
null
In teensy I set
with this bauds
int formeFrame;
frameRate(15);
frameRate(15);
setPort();
void draw() {
void setPort() {
dataFromMode ="<"
Thanks for helping
