put()
Description
Write any data type or object to the EEPROM.
Syntax
COPY
EEPROM.put(address, data)
Parameters
address: the location to write to, starting from 0 (int)
data: the data to write, can be a primitive type (eg. float) or a custom struct
Returns
A reference to the data passed in
Note: This function uses EEPROM.update() to perform the write, so does not rewrites the value if it didn't change.
Example
COPY
#include <EEPROM.h>
struct MyObject {
float field1;
byte field2;
char name[10];
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
float f = 123.456f; //Variable to store in EEPROM.
int eeAddress = 0; //Location we want the data to be put.
//One simple call, with the address first and the object second.
EEPROM.put(eeAddress, f);
Serial.println("Written float data type!");
/** Put is designed for use with custom structures also. **/
//Data to store.
MyObject customVar = {
3.14f,
65,
"Working!"
eeAddress += sizeof(float); //Move address to the next byte after float 'f'.
EEPROM.put(eeAddress, customVar);
Serial.print("Written custom data type! \n\nView the example sketch eeprom_get to see how you can retrieve the values!");
void loop() { /* Empty loop */ }
